    [WIP] Interiors -will be my first PR renderings
    64 Posts 16 Posters 9.3k Views 16 Watching
    • E
      Ecuadorian
      Try using the Metropolis Light Transport render method. In MLT, the number of light emitters is totally irrelevant. You can have 8 or 2048 emitter faces and the render time will stay the same.
      http://en.wikipedia.org/wiki/Metropolis_light_transport
      -Miguel Lescano
      • tinanneT
        tinanne
        @solo said:
        Tina, it did render on my side, but it took a while to process geometry and warm up, I tested it on default (I have not got the other presets loaded besides the standards on my new rig).
        I guess it may be overloading your machine as the scene has 821 lights, 2593 reflective surfaces.
        I then reset the model, and it rendered in 1m 40s, however when I tried to add lights (omnis) SU crashed and kept crashing after that, so it looks like it may indeed be a combination of model and Podium.
        Pete, thank you so much! I also took out the omnis and reset the model and got the same results. So.... problem with omnis... What do I do about that? What are my options for lighting the model? Why would I be having trouble with omnis?
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
        • tinanneT
          tinanne
          @frederik said:
          Looking forward to see the progress of this...
          The scene has a good potential... πŸ˜‰
          Thank you. Now that we are getting to what the problems are I'm having more hope for it's outcome. πŸ˜„
          • tinanneT
            tinanne
            @olishea said:
            Why so many lights?
            I've probably not set the model up correctly for podium is my guess. I'm just trying to get some light into the room. I placed two omnis that seem to be misbehaving.
            @david57 said:
            That looks beautiful, I like it. I dont know what PR or NPR is.
            Thank You. NPR is Non-Photo Realistic (which is what the format I generally work in) PR=Photo Realistic
            You can go a long way down the wrong road if you are not watching.
            I suggest you start over....trying to disect that scene is going to take too long and I can't see you learning much as it will be hard to isolate what it is that is effecting the render. There are too many variables....and it is just too big to start....to much going on.
            Start with a very simple scene with very little reflection or lighting....work it up from there and you will see how the changes you make (the additional adjustments) effect the rendering each time. It is very frustrating to continue to preview settings and find that you don't understand how you have effected the change.
            I took your advice and took out the omnis and scene rendering very quickly and SU did not crash. Thanks for the tip!
            Wow, I'm new to the PR stuff and that article flew right over my head.
            @frederik said:
            Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine... πŸ˜‰
            Again, {SHOOO} and you messed up my hair!
            • tinanneT
              tinanne
              My "successful" attempts...
              Default Settings
              Fab Interiors Setting
              Clay Render - Just for fun
Sepos Smooth Setting
              • FrederikF
                Frederik
                Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine used in Podium... πŸ˜‰
                Cheers
                Kim Frederik
                • tinanneT
                  tinanne
                  Bruce, yes, very pleased! Like you said just getting it not to crash was a huge accomplishment. Now I just have to figure out how to get the room lit. Hmmmmm?
                    sepo
                    If you want to send the scene please do. I am quite keen to see if I can do it slightly differently.
                    • FrederikF
                      Frederik
                      Great idea...!
                      http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                      Really - I mean it... If possible, "Honey Dear", then you should make it available for all of us and make it a render challenge... πŸ˜‰
                      Previous render challenges have proved to be very interesting, where scenes have been rendered by many different users and the outcome have been really interesting...
                      Cheers
                      Kim Frederik
                        sepo
                        Did not have it in mind as a render contest....more like offering help as Tina is using Podium. πŸ˜‰ But hey.... maybe Tina would like to see what could be done with different render engines.
                        • tinanneT
                          tinanne
                          Wow, that would be a great idea. You will all put me to shame, I'm sure. The problem is I have quite a few FF models in the scenes. I could replace them?
                          • david57D
                            david57
                            You could use light groups, but no one uses this programs. Was thinking of this yesterday.
                            http://www.vimeo.com/5109661
                            • tinanneT
                              tinanne
                              Baked another one today.... I think I've figured out what I was doing wrong before. I was setting the light on the face of the omni not the group. Could that cause the problems?
                              Bedroom
                              Looks like it's time to start working on textures and yuck! the tree in the corner is NOT going to work. I need some Cherry Blossoms. Anybody have any?
                              • david57D
                                david57
                                Here's some maybes:
                                http://archiforge.com/browse/108359102472b60ed50ee84z54802733/
                                • RichardR
                                  Richard
                                  Well done on your first try, I was going to mention the plant!!!
                                  BUILTBRAND.COM.AU
                                    sepo
                                    Yes, setting light to face would make it LEM and not Omni. Ok so you are now moving forward. πŸ˜„
                                    • tinanneT
                                      tinanne
                                      Latest update on the living room....
                                      Questions...
                                      1. Why is the texture on the green stool near the column look checkerboard?
                                      2. Still having trouble lighting the room.
                                      3. I'd like to have DOF on the skyline. I'm thinking would be better to do PP. How would you do it?
                                      4. The walls at the ceiling line look "dirty". Why?
                                        sepo
                                        this looks good... πŸ˜„ well done
                                        • tinanneT
                                          tinanne
                                          Another pass on the bedroom. (still working on textures and hoping to find some Cherry Blossoms for the corner.
                                          • olisheaO
                                            olishea
                                            The walls look dirty.....colour banding.....up your quality or use noisy setting.
                                            Blurred skyline......use black&white.xml to make a mask of the render and then place blurry photo in photoshop (black solid, white void)
                                            Lighting the room: try podium soft spotlights at regular intervals ( i recommend around 1500-2000mm grid, personal preference).....normal omnis within a light fitting have sharp unrealistic shadows, as exampled in the close up of your bed. Search podium forum for soft spotlight-TBD had posted an example. Avoid tuts3d's soft spotlight as it has an LEM in (unless you have a fast computer)
                                            If you set the opacity of the omni group to zero.....the omni will no longer cast shadows......just produce light only (this will stop the triple shadows problem behind the bed)
                                            The green checkerboard texture problem: Right click texture, reset position (even if it looks correct). If this doesnt work.....reverse faces back and forth and retexture....or delete offending face, recreate and retexture.
                                            πŸ‘
                                            oli
                                            • 2 / 4
