    [WIP] Interiors -will be my first PR renderings
    64 Posts 16 Posters 7.5k Views 16 Watching
    • tinanneT Offline
      tinanne
      Thanks Richard, good point.
      There is no molding at the ceiling line, only on the columns so I think we are set there.
      More to come. 😄
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • tinanneT Offline
        tinanne
        Progress on the test runs.... not so good! I'm already frustrated!
        I'm using Podium 1.7. I've used podium on some smaller projects and loved the output, but every time I try to use it for a larger project I have nothing but problems! Constantly crashes, I don't get the "quick" results that everyone else seems to get, and the lighting is horrible. 😞
          sepo
          What exactly are the problems? Maybe I could help.
          • olisheaO Offline
            olishea
            sometimes changing preset can solve the problem. I seem to get crashes (or white renders) when I use optimalem preset with lots of omnis......try quality or noisy. If you post problems on podium forum everyone will help, its a very friendly place!
            oli
            • tinanneT Offline
              tinanne
              Thanks Sepo. I keep trying Podium, but I just keep giving up. SU constantly crashes. That is the most frustrating part.
              Puter specs:
              AMD Athlon 64 x2 5400 3GHz
              4GB of RAM
              Video-I can't remember but I'll get you stats later
              I've set up my scene, shadows on. I've tried every setting I have and most of them crash. I've tried default, sepos smooth setting, fab interiors, optimalem... the list goes on.
              • soloS Offline
                Tina, I also run a 64 bit rig, if you want to send me the model and I will see if it happens to me also, I guess that way we can eliminate it being Podium if it does as my Podium seems very stable.
                • tinanneT Offline
                  tinanne
                  Thanks Pete, it's on the way!
                  • soloS Offline
                    Tina, it did render on my side, but it took a while to process geometry and warm up, I tested it on default (I have not got the other presets loaded besides the standards on my new rig).
                    I guess it may be overloading your machine as the scene has 821 lights, 2593 reflective surfaces.
                    I then reset the model, and it rendered in 1m 40s, however when I tried to add lights (omnis) SU crashed and kept crashing after that, so it looks like it may indeed be a combination of model and Podium.
                    • olisheaO Offline
                      olishea
                      sounds like a geometry or texture issue to me, more likely geometry.
                      sometimes just one dodgy texture or component can cause the crashing. I would delete components one by one and reset all materials and keep testing til it stops playing up (oh and purge all if you haven't already). 2593 reflective faces isn't too excessive for podium, just one car has that amount and normally its very stable. Why so many lights?
                      oli
                      • E Offline
                        Eulgrand
                        • soloS Offline
                          The lights are LEM's, so it could be a sphere that's lit up.
                          • david57D Offline
                            david57
                            That looks beautiful, I like it. I dont know what PR or NPR is.
                            • E Offline
                              Eulgrand
                              Thanks for the explanation 😉
                              • FrederikF Offline
                                Frederik
                                Looking forward to see the progress of this...
                                The scene has a good potential... 😉
                                Cheers
                                Kim Frederik
                                • E Offline
                                  Ecuadorian
                                  Try using the Metropolis Light Transport render method. In MLT, the number of light emitters is totally irrelevant. You can have 8 or 2048 emitter faces and the render time will stay the same.
                                  Metropolis light transport - Wikipedia
                                  (en.wikipedia.org)
                                  -Miguel Lescano
                                  • tinanneT Offline
                                    tinanne
                                    Pete, thank you so much! I also took out the omnis and reset the model and got the same results. So.... problem with omnis... What do I do about that? What are my options for lighting the model? Why would I be having trouble with omnis?
                                    • tinanneT Offline
                                      tinanne
                                      Thank you. Now that we are getting to what the problems are I'm having more hope for it's outcome. 😄
                                      • tinanneT Offline
                                        tinanne
                                        @olishea said:
                                        Why so many lights?
                                        I've probably not set the model up correctly for podium is my guess. I'm just trying to get some light into the room. I placed two omnis that seem to be misbehaving.
                                        Thank You. NPR is Non-Photo Realistic (which is what the format I generally work in) PR=Photo Realistic
                                        You can go a long way down the wrong road if you are not watching.
                                        I suggest you start over....trying to disect that scene is going to take too long and I can't see you learning much as it will be hard to isolate what it is that is effecting the render. There are too many variables....and it is just too big to start....to much going on.
                                        Start with a very simple scene with very little reflection or lighting....work it up from there and you will see how the changes you make (the additional adjustments) effect the rendering each time. It is very frustrating to continue to preview settings and find that you don't understand how you have effected the change.
                                        I took your advice and took out the omnis and scene rendering very quickly and SU did not crash. Thanks for the tip!
                                        (en.wikipedia.org)
                                        Wow, I'm new to the PR stuff and that article flew right over my head.
                                        @frederik said:
                                        Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine... 😉
                                        Again, {SHOOO} and you messed up my hair!
                                        • tinanneT Offline
                                          tinanne
                                          My "successful" attempts...
                                          Default Settings
                                          Fab Interiors Setting
                                          Clay Render - Just for fun
Sepos Smooth Setting
                                          • FrederikF Offline
                                            Frederik
                                            Sure is going to be difficult using Podium, since unbiased methods are not supported by the engine used in Podium... 😉
                                            Cheers
                                            Kim Frederik
                                            • 1 / 4
