    Synchronizing Multiple WebDialogs
    20 Posts 6 Posters 2.2k Views 6 Watching
      Ok - so when communicating with Webdialogs:
      • Initialize a Webdialog object.
      • Populate with HTML and display the dialog
      • Wait for a "ready" signal from the dialog before attempting any communication
      This sounds like the check-list you have to follow in order to reliably establish communication? One for your Webdialog gotacha-thread.
        RickW
        One thing I've learned is to include a callback at the end of my html telling the script that the WebDialog is ready to receive communication, as you mentioned, and as I have mentioned in other threads. 😄
        RickW
        www.smustard.com
        • chrisglasierC Offline
          chrisglasier
          Precisely, if you need a web dialog the web dialog has to run the show. Anything else is a pas de deux to nowhere.
            MartinRinehart
            I don't understand. Maybe you are solving a different problem. Here's my situation, simplified to a single WebDialog.
            User clicks button. (There is no button to click until the <body> is built, so calls from a button click can't happen prematurely - I think.) JS calls Ruby callback requesting data. Ruby fetches data and returns it to JS.
            I think the "Ruby, data please" call also implies "Ruby, I'm ready". No? What am I missing?
              Ah! Didn't notice that the .show and .show_modal where block methods. That's useful to know. Saves that extra callback from the webdialog.
                cjthompson
                This gets an alert from a file, at least for me:
                wd = UI;;WebDialog.new "foo", true, "", 100, 100, 100, 100, true
                wd.set_html "<html><body>Hello World</body></html>"
                wd.show{
                wd.execute_script( 'alert( "hello from foo" );' )
                What problem are you having, exactly?
                  MartinRinehart
                  Thomthom didn't have a problem. I did.
                  The problem was that if you called wd.execute_script() after wd.show() (instead of in a block passed to wd.show() ) it failed.
                  Thank you for your clear code. Do you happen to know any more about when the show() block is actually executed than what the docs report?
                  Thanks.
                    cjthompson
                    not really. I pretty much just stumbled across it, and saw that it worked.
                    I don't really know much about DOM events or even html in general. Maybe you know how to execute a script that will show what state the browser is in, and execute that on show?
                      Jim
                      I assume it would be possible to devise some tests to track when it happens, using a javascript logger or something.
                        MartinRinehart
                        Jim, this is a sensitive and tender area! My VisMap did not originally support the Mac because of timing/thread issues. The simple answer was to postpone the start of Ruby/JS chat by forcing the user to click an otherwise unnecessary startup button.
                        If you find a tool that actually lets you step through the states of the browser, it would be invaluable.
                          chrisglasier
                          ... for whom?
                          "This is commercial, for-profit work. At some point there will be a send-me-money feature added. At this point (mid-summer, 2009) that feature does not exist. The whole price right now is feedback. Tell me what works and what's unclear. Major mistakes and minor typos." [source]
                          Free content/editing from feedback seems as bad as free designs from competitions (much despised around here - example).
