    Sketchup 7.1 Pro Upgrade Fails
    22 Posts 7 Posters 9.3k Views 7 Watching
      john.warburton
      @andrews said:
      @john.warburton said:
      It looks like I'm heading towards a complete reinstall of Vista and my software. A couple of days at least that I can't afford.
      John:
      I sent you a PM yesterday with other suggestions, but have not heard back. Try those first...
      Thanks Andrew, but I have not received any PM's. Last one in my inbox was in February.
      Life's a reach, and then you gybe.
        john.warburton
        Just to be clear, by the way - I don't blame Sketchup for this problem. It seems to be a Microsoft issue.
        • honoluludesktopH
          honoluludesktop
          Hi John, Sorry to read about your problems. I binged the error from MSs site, and noted that a lot of error messages referred to exchange, and outlook. As a last ditch effort (something VERY DANGEROUS that has worked for me in the past), just before you reinstall your OS. If you have access to a clean working copy of SU v7.1, locate the SU register (find with "regedit", and save it), and copy to the problem machine, and install it (just click on it). If that fails, you are going to reinstall anyway.
          In order to avoid this kind of problem, when possible, I always keep a copy of the last 2 installers.
          • AndrewSA
            AndrewS
            John,
            Something is apparently broken with the forums. I did send you a PM the other day and I even went back to my sent messages to reference it the next day and it was still there. Now however, the message is no longer in my sent items and in fact, I don't even get the option to send you a private message; it's as if you're blocked. I wish I knew what happened to that message, as it took me a long time to write. Oh well.
            The problem is with the Microsoft Visual C++ 2005 Runtime module. For some reason, Windows is not allowing you to install it. This is not a problem with SketchUp, as we simply distribute the Microsoft-provided installer for that.
            Of course, you take responsibility for any troubleshooting steps you decide to take and any fallout that occurs as a result. It's all at your own risk... That said, here's something you can try.
            Rather than reinstall your whole OS, a better approach would be to start by trying to manually uninstall any existing copies of the MS Visual C++ 2005 Redistributable package and then reinstalling the newest copy from the web. If you can do this successfully, you might get SketchUp to install cleanly without tripping over the component you're stuck on at present.
            In the add/remove programs menu, look for something having to do with Visual Studio or Visual C++ 2005 Redistributable. If you find it, uninstall it. It'll be nice if you can uninstall this without any problems, but since it's an MS module that other programs on your system may already rely on, the system may not let you uninstall it.
            After you've uninstalled, or if you don't find it already installed, or if you can't uninstall it, then move forward with installing the newest available copy:
            Invalid URL
            (www.microsoft.com)
            Note that there are different versions for 32-bit vs 64-bit, so you have to get the correct one for your OS.
            After you've installed the newest version of that package, try to reinstall SketchUp and see if it works for you.
            Andrew S.
            SketchUp Release Engineer
            • GaieusG
              @andrews said:
              ...Something is apparently broken with the forums. I did send you a PM the other day and I even went back to my sent messages to reference it the next day and it was still there. Now however, the message is no longer in my sent items and in fact, I don't even get the option to send you a private message; it's as if you're blocked. I wish I knew what happened to that message, as it took me a long time to write. Oh well...
              Hi Andrew, can you send anyone PM's? Try to send me one, please. I tested your permissions and they seem to be okay
              I haven't encountered with this issue yet (indeed we have some however).
              (Is it not still in the Outbox folder? Sent but unread messages are there - sent and read messages go to the Sent folder).
              Edit - John, don't you have PM's disabled by any chance in your preferences?
                john.warburton
                Oops! That would explain, that. 😳 Got the PM now!
                  john.warburton
                  Well, I managed to uninstall the MS Visual C++ 2005 Redistributable without encountering any errors.
                  Installing the latest version failed, though, with an error suspicously similar to the SU installation error.
                  Windows Update has ceased working too (with a useless generic error code 8000FFFF.) This may be due to my over aggressive use of a registry cleaner, though. Unfortunately restoring my registry backup did not fix this.
                  I have a current backup and details of my software installations, so I am thinking that reinstalling the OS from scratch is my only solution at this point.
                    Yea - registry cleaners could potentially cause more problems than what they fix.
                    • AndrewSA
                      AndrewS
                      That's a step in the right direction!
                      D'oh. I had really hoped we might get lucky by installing it outside of the context of SketchUp, but this is what I was afraid of. The pre-packaged Microsoft assembly just can't be installed for some reason.
                      Unfortunately, that is often a problem with registry cleaners. I know there are a lot of proponents out there who suggest the use of registry cleaners, but I'm not one of them. I recognize the occasional need to clean things out, but in my experience, registry cleaners cause more problems than they solve. These days, with almost all programs using Windows Installer to perform their installations, registries stay a lot cleaner than they used to. That being said, I am a proponent of reinstalling Windows from scratch every couple of years on computers that get a lot of use, just to be sure everything is operating at peak efficiency. Full reinstallation is something I prefer over registry cleaning.
                      I'm guessing that right now isn't an optimal time to perform such a procedure, but it may be necessary if you wish to continue installing SketchUp 7.1, or any other software package that requires the newest version of the Visual C++ 2005 redistributable package. The newest version of that package came out in July, so there are lot of software vendors who are in the middle of migrating over to using it in favor of the old one. SketchUp may be the only program you've found to give you this error so far, but it's only a matter of time before you try to install something else that requires it and run into the same problem for that program as well.
                      Good luck.
                      Andrew S.
                        john.warburton
                        I came across a lot of posts on various forums that identified 80070057 as an HTTP proxy error. I'm assumming that this is the same as the code with the hex prefix and not a completely different decimal code.
                        Common wisdom said that the first solution would be to try running proxycfg.exe from the console with admin privileges, running it twice, the second time with a '-d' switch.
                        Of course I was one of the many who aren't running IIS and did not have proxycfg available. Just in case I did download it though, and ran it to no apparent effect.
                        The second solution recommended is to do a clean reinstall of Vista, which is about where I am at anyway. By 'clean' it seems that I have to remove the current installation first, presumably to be absolutely sure that the new installation does not pick up any crud from the current installation.
                        To be sure, I think a format of the HDD is in order. A job for the weekend, I guess. 😞
                        • AndrewSA
                          AndrewS
                          I suppose it's possible that Windows Update is failing due to a proxy error, but of course, since the part of the SU installer where your installation is dying does not access the internet, the proxy settings wouldn't impact the issues you're having with the VC++ 2005 redistributable.
                          The second solution recommended is to do a clean reinstall of Vista, which is about where I am at anyway. By 'clean' it seems that I have to remove the current installation first, presumably to be absolutely sure that the new installation does not pick up any crud from the current installation. To be sure, I think a format of the HDD is in order.
                          Again, it's a bummer that the job would require such an approach, but I do think it will fix your problem. Note that if your computer came from a big manufacturer like Dell, HP, Compaq, Gateway, etc., with Vista, it's almost a 100% certainty that there will be a recovery partition on your drive. The recovery partition contains a complete copy of Vista, exactly as it came from the manufacturer. If you boot in recovery mode, an automated system formats the main partition of your hard drive, copies all of the files over, and thereby restores the machine to factory spec. NOTE OF COURSE THAT THIS WOULD DESTROY ALL OF YOUR DATA, just like a regular format/reinstall would, so you need to back everything up first. Depending on the manufacturer of your PC, there are different ways to enter recovery mode. Just Google it the procedure. It takes a couple of hours to do this, but it's easy and reliable; I've done it lots of times with good results. Of course, if your PC is custom-built, there won't be a recovery partition and you'll have to reinstall from DVD.
                          Good luck!
                          Andrew S.
                            john.warburton
                            Well, I'm making progress.
                            Restoring the original configuration was painless. And seemed to take only a few minutes. The hard part was finding out how to do it! Silly me for thinking that I should use the "Recovery Disc" that came with the PC. No, I needed the "Application & Support-Disc". The "Recovery Disc" is used to either repair the existing installation or to replace it with a completely new installation. Nice one Medion. No documentation with the PC or on their web site of course. A README.TXT on the recovery partition would have been nice too.
                            Anyway, after several hours installing them one at a time, I managed to get all of the updates installed. One at a time because I have previously fallen foul of a known issue with Vista becoming unusable when trying to install multiple updates. Only one gave me an issue - the .NET 3.5 framework installation failed first time, but succeeded on the second attempt. Vista SP 2 was the last to go on - I did not even get offered that until all the other updates were installed.
                            SU 7.1 Pro was the first app that I installed. It went on straight away, no problems.
                            A long weekend now getting all my other apps on and validated, then several hours re-installing the data. Don't you just hate computers?
                            • AndrewSA
                              AndrewS
                              Great! I've seen it take an awfully long time on some systems, but I'm glad yours was fast. The 'old' way of doing reinstallations was so terrible in comparison to this. When it works, the recovery partition is awesome. When doesn't it work? When your hard drive is failing and the recovery partition is Swiss cheese.
                              This is my number one complaint with this procedure; it's different on all machines. I don't even know how to do it properly on my home computer, so I have to hack it into working using a partition editor.
                              You're lucky they even gave you any discs. I don't know of any other manufacturers who provide them anymore.
                              What a relief! I was 100% certain it would, but my wife had me a bit rattled when she asked me on Friday, "What happens if he does all this and it still doesn't work?" I didn't have an answer. πŸ˜„
                              Having caused plenty of problems for myself and run into countless others caused by bad software and hardware throughout the years, I've wasted a substantial amount of my life on such endeavors. And yet, I still keep coming back! What is the definition of insanity again?
                              Best of luck with SketchUp 7.1!
                              Andrew S.
                                john.warburton
                                Many thanks for your assistance Andrew. I'm almost back up and operational now.
                                Restored all my data yesterday afternoon (4 hours!)
                                Just need to recover my commercial Sketchup plugins from the backup and then re-apply all my custom settings to my CAD software (and I had it just right too!)
                                Tell your wife I was asking myself the same question ... πŸ˜„
                                  Dzuka
                                  Very easy and working solution.
                                  http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/321fe20a-ecc6-469e-93a4-b640f39c05b5
                                  I believe I've found a registry fix that may resolve your issue. Modifying REGISTRY settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of REGISTRY settings can be solved. Modifications of these settings are at your own risk.
                                  Before you make changes to a registry key or subkey, we recommend that you export, or make a backup copy, of the key or subkey. You can save the backup copy to a location you specify, such as a folder on your hard disk or a removable storage device. If you make changes that you want to undo, you can import the backup copy.
                                  1.Open the Registry Editor by clicking the Start button , typing regedit into the search box, and then pressing Enter.β€Œ If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
                                  2.Locate and click the key or subkey that you want to back up (in this case HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control).
                                  3.Click the File menu, and then click Export.
                                  4.In the Save in box, select the location where you want to save the backup copy to, and then type a name for the backup file in the File name box.
                                  5.Click Save.
                                  Once you've backed up your registry, you should see a key named RegistrySizeLimit. The default value is 5d00000. This needs to be changed to ffffffff.
                                  When you've made the change, reboot the system and try to install your software again.
