    Sketchup model converted into solids using VectorWorks 2009
    16 Posts 6 Posters 13.0k Views 6 Watching
    • GaieusG
      OK, done - and thanks! πŸ‘
      • EdsonE
        Edson
        bohdan,
        did you use the plugin created by nemetschek to import the sketchup file? why did you export it as v6 before importing it?
        http://www.mahfuz.arq.br
          Starling75
          @edson said:
          bohdan,
          VW 2009 has built-in importer but it can import only SU6 format. VW 2010 supports SU7 ...
          http://www.starlingarch.cz
            Starling75
            Here is fastest method for less complex models.
            Import SU model as a plain geometry, select whole object - all 3D polygons and press Ctrl+Alt+A (solid addition).
            • EdsonE
              Edson
              bohdan,
              being a user of both sketchup and VW (i have been using it since 1995!) in my daily work i ask you: why do you need to import a sketchup model into VW? i find VW's 3D very awkward and would never prefer working on it.
              • honoluludesktopH
                honoluludesktop
                Edson, In your experience, is the difficulty with VW inherent to solid modelers, or VW's interface? I tried a solid model in the 90's, and found it unsuitable for the kind of Architectural models I did, but have not tried to work with one since. Currently I prefer to begin design with a vector Cad program, then to port surfaces to SU for visualization, and rendering. Occasionally, I will port revised parts of the SU model back to amend the Vector Cad drawing in preparation for construction docs.
                • EdsonE
                  Edson
                  i am not sure about why it is so, but i never liked it, even when i used VW for everything, 2D and 3D. the fact that you have to model in a colorless environment annoys me, plus the fact that you have to wait for it to render. discovering sketchup brought back the pleasure i felt when i designed using pencil and lead.
                  my workflow usually involves going back and forth between VW and sketchup. i usually create reference plans and sections in VW which i import into sketchup to develop the idea in 3D. i actually build the form in 3D but the 2D plans from VW are very helpfull.
                    Starling75
                    @edson said:
                    bohdan,
                    Some pieces of equipment, complex shapes etc can be very quickly and efficiently modeled in SU (I didnt find VW modelig capabilities that bad, but SU is definitely faster..) . After importing into VW I can use them as semiproducts for creating plugin hybrid objects.
                    There is another way how to profite from interoperability of these 2 programs too. It is possible import well organized SU model into VW and create reports, elevations, section viewports, floor plans with hatches and dimensions directly from the model .... (great for conceptual study) ... and later I can utilize formed "dumb" SU model as scaffolding during creation of final BIM model in VW.
                    Modeling in SU is pretty fast and you are right - it is pleasure, but there are no solids, no NURBS, no BIM (I know about these wall and door scripts .. but there is still long way to go..)
                    One word - synergy πŸ˜„
                    • EdsonE
                      Edson
                      bohdan,
                      thanks for the explanation. i will definitely look into more integration between SU and VW.
                        Starling75
                        @edson said:
                        bohdan,
                        Your welcome πŸ˜„
                        Btw .. modeling in solid based modeler does not have to be such a pain ...
                        http://www2.spaceclaim.com/stream/video.aspx?v=SpaceClaim_Overview.flv
                          Starling75
                          Looks good but I sputtered at "we'll send you a quote".
                          http://www.novedge.com/brands/89
                            Starling75
                            Quite a step forward from my present solid modeler. My models are used in a design application for builders. The application engine uses a pretty obscure solid model engine. It is a great piece of code but a very poor modeling environment. So I use SU and convert to solid. I export the solid as a .stl file. My native solid modeler recognizes and validates .stl. If it cannot be validated it will return an error listing the incorrect primitives. So you can imagine the workflow when the models are complex. I have to make many iterations of the conversion process...back and forth sometimes for an hour or more, on a small component, patching holes or removing redundant geometry you could not otherwise see in SU.
                            I would be happy to just bring it in solid but I have no real solid skills. It would take some learning. In the new year I plan to look a little closer at solid modelers. I'll start with your suggestion. We start to slow in January so it is the best time for this kind of play. Thanks for you suggestion.
                            Do you know this?
                            http://www.bonzai3d.com
                            http://moi3d.com
                              aliakbar
                              Wow, thanks. You just saved me so much time. I never knew this. Previously whenever my solid objects turn into nonsolids for reasons I don't know, I would rebuild it again from zero.
