    20/20 and SketchUp
    12 Posts 6 Posters 9.7k Views 6 Watching
      Carrye
      Is there a simple way to convert 20/20 models into SketchUp models without first converting them to DWGs?
        Carrye
        The .dwg I have received are not good at all. They are wire mesh and not only do they have to be gutted but smoothed out. I can only smooth them so far or I end up losing too much detail so I go in and hide lines manually after a certain point. Can 20/20 models be exported as smoothly-curved AutoCAD solids instead of meshes? Is it better to export to .dxf than to .dwg?
          Carrye
          My client is paying 20/20 to produce the models and to have them converted to dwgs. I am just trying to learn why the quality is lost in the conversion. I am just working from the dwgs that are available to anyone on the internet. It may be that copyright is the reason the for the degradation in quality. Maybe my client only pays for the dwg while 20/20 owns rights to the original model for use in their electronic catalogs. Trying to get to the bottom of this.
            Carrye
            Why would they be using SketchUp if they have their own modeling software?
            • E Offline
              ericschimel
              I use 20/20 and Sketchup every day for just what you are trying to do. You are correct, there is a lot of excess geometry imported. The import is pretty good though. There is no other way then to export to DWG and then import into Sketchup though.
              It makes for some pretty heavy models, but here at the office we keep the computers pretty high spec so we can deal with the extra geometry.
              It would be a real boon if you could convert the catalogs into seperate Sketchup models automatically... Although, I think 20/20 would be rather upset about that...
              -Eric
              http://plugin.sketchthis.net
              Sketchup Kitchen Design Plugin
              Custom Models
              • Al HartA Offline
                Al Hart
                Are you using 20-20 for Kitchen Cabinets or Office Furniture.
                Al Hart
                IRender nXt from Render Plus
                • E Offline
                  ericschimel
                  Me? I use it for kitchen design, and these days, I try to use it as little as possible....
                  -Eric
                  Custom Models
                    Carrye
                    If you don't mind...why are they hiring 20/20 to do this? Why wouldn't you build them using Sketchup in the first place?
                    The point of my research is to prove to my client that having 20/20 produce the models is an unnecessary step. I hope that eventually I will be building them in Sketchup in the first place. I really love that you said that - makes perfect sense to me too.
                      kwistenbiebel
                      Can you get 20/20 in the 7/11 or in a 24/7 ?
                      (in other words: what does 20/20 mean? sorry for being such a noob 😳 )
                        kwistenbiebel
                        Aha, thanks for that link. Learning every day 😛
                          Carrye
                          I'm not exactly sure what you mean by solids - do you mean smooth surfaces instead of mesh?
                          What I really need to know is how I can export Sketchup models to a dwg or dxf without having all of the hidden lines show up. I am working with complex curves and it just turns into a big mess when I export it. Is there a way to maintain smoothness?
                            jpbernier
                            You can view the meshed objects in plan, or elevation view and then use the Autocad command "Flatshot" and it will create 2D a block of what is visible on your screen. Then you can explode the block and delete out any little bits that you don't want. It's still a bit of work, but it's way faster than exploding an entire 3D object and sorting through the garbage that happens when you do that.
                            JP. Bernier
                            Draw! Studio
