    Uv map import
    3 Posts 1 Posters 1.6k Views 1 Watching
      remon_v
      hey guys,
      I would like to import an object modeled in modo included an uv map into sketchup.
      What format + settings should I use so sketchup imports the uv map aswell.
      I did some research on the web and I found this workflow:
      in Modo, export to "Autodesk FBX" format (modo can't export to 3ds).
      in the Autodesk FBX converter, convert FBX to 3ds.
      import into SU.
      I tried it but I can't get the uv map in SU.
      anyone who can help me with this?
      cheers
      remon_v
        remon_v
        I also read exporting as OBJ doesn't work with uv map?
          remon_v
          problem solved... Michalis was so kind to explain to maybe.
          I was a bit wrong about OBJ not supporting uv maps.
          I'll explain the workflow quickly here for people who are intrested:
          • unwrap your object in Modo.
          • make an texture in gimp/photoshop.
          • apply it in modo.
          • export to OBJ.
          • import in blender.
          • export as 3ds in a different folder with the texture in the same map. Remember 3ds files can only contain 3-5 letters.
          • import into SU
