<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Uv map import]]></title><description><![CDATA[<p dir="auto">hey guys,</p>
<p dir="auto">I would like to import an object modeled in modo included an uv map into sketchup.<br />
What format + settings should I use so sketchup imports the uv map aswell.<br />
I did some research on the web and I found this workflow:</p>
<p dir="auto">in Modo, export to "Autodesk FBX" format (modo can't export to 3ds).<br />
in the Autodesk FBX converter, convert FBX to 3ds.<br />
import into SU.</p>
<p dir="auto">I tried it but I can't get the uv map in SU.<br />
anyone who can help me with this?</p>
<p dir="auto">cheers<br />
remon_v</p>
]]></description><link>https://community.sketchucation.com/topic/114726/uv-map-import</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 14:59:47 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/114726.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Sep 2009 19:46:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Uv map import on Wed, 16 Sep 2009 18:53:42 GMT]]></title><description><![CDATA[<p dir="auto">problem solved... Michalis was so kind to explain to maybe.<br />
I was a bit wrong about OBJ not supporting uv maps.</p>
<p dir="auto">I'll explain the workflow quickly here for people who are intrested:</p>
<ul>
<li>unwrap your object in Modo.</li>
<li>make an texture in gimp/photoshop.</li>
<li>apply it in modo.</li>
<li>export to OBJ.</li>
<li>import in blender.</li>
<li>export as 3ds in a different folder with the texture in the same map. Remember 3ds files  can only contain 3-5 letters.</li>
<li>import into SU</li>
</ul>
]]></description><link>https://community.sketchucation.com/post/1117951</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117951</guid><dc:creator><![CDATA[remon_v]]></dc:creator><pubDate>Wed, 16 Sep 2009 18:53:42 GMT</pubDate></item><item><title><![CDATA[Reply to Uv map import on Wed, 16 Sep 2009 09:36:45 GMT]]></title><description><![CDATA[<p dir="auto">I also read exporting as OBJ doesn't work with uv map?</p>
]]></description><link>https://community.sketchucation.com/post/1117832</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117832</guid><dc:creator><![CDATA[remon_v]]></dc:creator><pubDate>Wed, 16 Sep 2009 09:36:45 GMT</pubDate></item></channel></rss>
