    [Plugin] Selection Toys
    594 Posts 121 Posters 414.3k Views 121 Watching
      publied
      what i can saying? thanks!
      hire me@ http://www.publied.it !
        kwistenbiebel
        Great work Tom!
        I didn't have time to read through all the 9 pages of this thread ( 😳 )....so I'll bluntly post my question: Does the plugin work in SU6?
        I ask this because 'dynamic components',a typical SU7 feature, is part of the selection toys plugin...
          It should work, yes. The DC filters simply checks the DC meta data stored in components, and that can be read in SU6.
            kwistenbiebel
            Thanks Thomas!
              su30
              Yes it works well this version, I used it for a few days, and the grey out problem never happens again!
              Thanks, Thomas
              su30
                accabrera
                cool plugin!
                  New selection tool to select a face's loops.
                    Big speed improvement for most selection functions. Noticeable when dealing with large selections.
                    Some functions are yet not optimized. I need some more time to ensure they work as they should. These are mostly functions related to connected geometry.
                      Quad-face Loop works as expected. I tried to illustrate it with that gif animation. It selects connected faces and edges in a row.
                      Can you illustrate your expected result?
                      (You're not confusing it with the new Face Loop feature I just added? The new feature is accessed from the Tools menu. See comment over the first illustration.)
                      • N Offline
                        NewOne
                        Yes I did confused that two features! 😄 sorry. I like that feature. It saves me lots of clicks - and therefore it saves my mouse! 🤣
                          Got any suggestions for better names?
                          They do have all too similar names - no wonder it leads to confusion.
                          Maybe the new one should be named Select Edge Loops ?
                          • N Offline
                            NewOne
                            Yes, it's a better name. This one I think is a function that will be used very often, so why don't you make an icon for it instead of hiding it in Tools menu where is a little hard to find? 😄
                              Yea - I might add a toolbar for this now. Good idea.
                              Thinking it might be worth making a UI to choose what items to display in the menus and toolbars. This plugin has gained quite a few commands through it's lifespan.
                              • N Offline
                                NewOne
                                Is this normal? Select Quad-face loop doesn't mean to select closed loop edges that form a quad? Or I misunderstood ?
                                This is what happened:
                                BTW: I think you have an error on cursor code; Would you please take a look? ( as I know correct syntax is UI::create_cursor(cursor_path, x, y) )
                                • H Offline
                                  hamster3
                                  Thank you for contributing such a great tool!
                                  Very helpful!
                                    Ruturaj
                                    Thanks....... 💚 😄
                                    you are great man
                                    I find "Boolean Tool" but i can not find full version
                                    please help me
                                    can you send me "boolean tool" please.
                                    Thanks,
                                    RuturaJ
                                    • F Offline
                                      fossa
                                      Great tool. Thank you for sharing with the community.
                                      After reading Daniel Tal's book I was thinking that a tool like this would be very handy.
                                      Have you given any thought to trying to select like Blenders ring/chain command.
                                        I've not used Blender - how does these functions work?
                                        • mitcorbM Offline
                                          mitcorb
                                          Please pardon the intrusion.
                                          Fossa is talking about Blender's loop subdivide feature.
                                          One can invoke a loop around the target geometry and, with the scroll wheel, increase or decrease the number of loops. This is usually used on narrow, elongated solids. The command first sets the initial loop at the midpoint of the target region, and then replicates/multiplies that loop as the scroll wheel is advanced or reversed. This is very similar to the Sketchup Divide command, which only works on edges.
                                          After observing by using your Selection Toys and Fredo6's Tools on Surface plugins, I am guessing it's gonna be either you or he who will finally implement this in Sketchup. The clue may be in whatever SU is doing in the Divide command.
                                          I believe there is a Blender video tutorial on loop subdivide at gryllus.net, though I haven't been there in a while.
                                          • X Offline
                                            xrok1
                                            reat tool, thankyou.
                                            would it be possible to select loops in the other direction, without faces (rings)?
                                            • 29
                                            • 30
                                            • 7 / 30
