    Better Bump Maps
    13 Posts 7 Posters 1.7k Views 7 Watching
    • olisheaO Offline
      olishea
      yeah dude, i tried playing with lighting effects too....onto a high pass filter overlay etc.....but i gave up eventually.
      what does rendered version look like with this? a comparison maybe?
      oli
      • michaliszissiouM Offline
        michaliszissiou
        Try gimp richard. Filters/maps, has normal maps too.
        BTW slightly blurry bump maps work better, but I think you already know this.
        • N Offline
          notareal
          When you playing with cam and light, why not to shoot normal maps πŸ˜„
          http://zarria.net/nrmphoto/nrmphoto.html
          • RichardR Offline
            Richard
            Thanks guys I've got a bunch of normal map generators.
            I think however your maybe missing the point of the exercise here!
            As is the normal way of creating bump maps is just to desaturate the image and adjust levels you end up with a map that is actually 90% of the time incorrect. In say a stone wall the normal way would actually push in darker stones, when they actually could be the ones protruding!
            As you can see from the centre image (sure the actual technique needs to be developed) it actually gives a close to correct bump map - being that it doesn't just push in the darker areas but actually picks and corrects those areas in the original image that are in shadow as depressed.
            BUILTBRAND.COM.AU
            • RichardR Offline
              Richard
              Thanks for that one mate! I reckon that is something certainly worth trying to work into it!
              BUILTBRAND.COM.AU
              • RichardR Offline
                Richard
                Ok another test, this time on a gravel texture.
                You can see the test with lights it has bought up a lot of detail in the gravel that can be evidenced from the colour map but not reflected in the normal method of producing a bump from the original colour map.
                Original colour map
                original colour map
                Normal method of producing bump map
                normal method to produce bump
                Test with lights accross surface
                BUILTBRAND.COM.AU
                • RichardR Offline
                  Richard
                  And possibly a better one!
                  BUILTBRAND.COM.AU
                  • marked001M Offline
                    marked001
                    pretty impressive results, richard.... especially the wood... you'd never even guess that that grain was present based on the photo.
                    http://www.revision21vis.com
                    instagram: revi21on
                    • EarthMoverE Offline
                      EarthMover
                      I had a chance to mess with this concept. I too was hoping for a one touch action solution that would produce these results, but it feels like each image will need the spotlights adjusted a little to get the most detail.
                      Here's one I was playing around with.
                      Content Creator at Skapeup
                      • soloS Offline
                        Adam, believe it or not but I have a project starting next week where the above texture is exactly what I need, talk about timing...
                        Thanks a bunch.
                          marked001
                          yeah, that'd be great if it were as simple as setting up an Action sequence in pshop...
                          instagram: revi21on
                            michaliszissiou
                            Sorry not so seamless. Seamless (almost) is a difficult thing.
