    South wind #2
    51 Posts 15 Posters 8.6k Views 15 Watching
      mirjman
      texturing on that first render is great.. you can really see where the rock interacted with the water, however the water seems to ignore the rock in both renders!! gives it the impression of a floating rock
      • michaliszissiouM
        michaliszissiou
        this is for mirjman: thanks for these kind comments. IMO you need to spend some more time near sea. These sea rocks are really floating most of the time. Even whole islands are floating. Even Feidias's statues are floating. Today greek politicians and economists are floating too. 😆
        for solo: Pete, there's something I don't understand. I could use jpg too, but SU doc seems to have the same size. What exactly happens there? Even so, we should never use jpg for textures, not really a good choice.
        For everybody who doesn't know what a baked model is, please have a look in this UV map. It seems rendered already.
        • soloS
          The rock was screaming for a tropical make-over.
          All Vue, no post processing.
          Added two species palm ecosystem, texture of rock is as per above reduced map.
          Tropical water, slight wave algorithm, buoy is an old SU model of mine.
          http://img127.imageshack.us/img127/9351/tropicalrock.jpg
            The model is called tool (!), there's no save (!)
            Hum hum : Menu Tool/Save as 😉
            Cool seatime images! 😎
            • michaliszissiouM
              michaliszissiou
              For Pilou: Do you know how to use zbrush? I paid 600$ for this and I know how to use it. I also have some posts in zbrush forum but you already know this.
              Pourquoi tu n'arrêtes pas cette habitude, Pilou? C'est la deuxième fois que tu fais la même chose à mes "posts".
              For solo: So you don't need my textured model, just a cone. lol. Nothing to do with September in greek islands, anyway a great render, and I particularly like this model (I don't know how to spell this in english) I've admired in your site. I really had this in mind thinking about a sea scene.
                Sorry for the misunstanding 😳
                And I have edited the previous one
                Don't want any polemics 😄
                • michaliszissiouM
                  michaliszissiou
                  I'm proud just for one thing here. Rock model under 1000 polys. Unfortunately looks rather soft. But it gonna be the base of a lighthouse, so...
                  Podium render in 20 sec, full quality noisy preset (one reason to love baked models). Just a little PP for SU fog effect.
                  • david57D
                    david57
                    Looks professional.
                    • michaliszissiouM
                      michaliszissiou
                      Thanks david. I post this too so have an idea what's happening with a low polys model + a render engine that doesn't support displacement maps or even normal maps. Rendered in zbrush internal renderer in 10 sec, 2 000 000 polys here.
                      • michaliszissiouM
                        michaliszissiou
                        Here is a podium 20 sec render, not so bad this time, plus a simple SU lighthouse model. So I modeled something with SU after all.
                          remon_v
                          awsome. that quick render with what system specs?
                          • michaliszissiouM
                            michaliszissiou
                            Thanks remon. On a mac pro (2 nehalem xeon, 8 cores 16 threads 2.26 GHz, 6GB RAM)
                            Another two just for fun.
                              remon_v
                              here's my effort. It's not as nice as Michalis' and solos effort. Rendered with vray and a little ps. Suggestions and C%C's are welcome. BTW took me 20 min and 10 s to render with an amd phenom X4 940, 4 gig of ram.
                              http://i22.photobucket.com/albums/b336/remon_v/test7-2.png
                              • michaliszissiouM
                                michaliszissiou
                                IMO remon, this background sky is a wrong choice. Doesn't work with the sea (reflections?), it doesn't "explain" the light on the rock either.
                                  redot
                                  Those pics are fabulous Michalis.
                                  Texture baking is working a treat. You'd never know they were low poly.
                                  • N
                                    nomeradona
                                    this is just becoming a great exercise again. nice model and nice water surface. the sceond image of solo looks realistic.
                                    micha... the 20 sec render is my favorite....
                                      remon_v
                                      You're right Michalis... I did see it also, tried to fix it in PS but didn't come out nice.
                                      Ok I did some more testing... Trying to fix the reflections and reducing the rendertime. I setup a billboard at the back. I gave the ship a dark blue (nearly black) texture I put an omni light in front of the sun and removed the "sketchup sunlight". So here it is:
                                      http://i22.photobucket.com/albums/b336/remon_v/3.png
                                      as you can see reduced the time alot 😄
                                      • michaliszissiouM
                                        michaliszissiou
                                        Thats better remon. More reflections are needed though, or maybe try a simpler sky.
                                        Thanks nomer.
                                        Here's a heavier PP.
                                        BTW did you know that Victor Hugo was a great artist too? Do some search in google and I'm sure you wont be disappointed.
                                          remon_v
                                          nice Michalis... I did some other tests. The water is more reflective and I also edited the rock texture a bit. here it is:
                                          http://i22.photobucket.com/albums/b336/remon_v/8.png
                                          • michaliszissiouM
                                            michaliszissiou
                                            Better now remon but I have my doubts about this sky.
                                            I tried to do something similar here. Heavier PP this time.
                                            • 2 / 3
