    South wind #2
    51 Posts 15 Posters 8.6k Views 15 Watching
    • soloS
      Michalis, try this texture, it's reduced from 12MB .bmp to 181kb .jpg I kept the size, so you can replace the original with this and it will stay mapped.
        mirjman
        texturing on that first render is great.. you can really see where the rock interacted with the water, however the water seems to ignore the rock in both renders!! gives it the impression of a floating rock
        • michaliszissiouM
          michaliszissiou
          this is for mirjman: thanks for these kind comments. IMO you need to spend some more time near sea. These sea rocks are really floating most of the time. Even whole islands are floating. Even Feidias's statues are floating. Today greek politicians and economists are floating too. 😆
          for solo: Pete, there's something I don't understand. I could use jpg too, but SU doc seems to have the same size. What exactly happens there? Even so, we should never use jpg for textures, not really a good choice.
          For everybody who doesn't know what a baked model is, please have a look in this UV map. It seems rendered already.
          • soloS
            The rock was screaming for a tropical make-over.
            All Vue, no post processing.
            Added two species palm ecosystem, texture of rock is as per above reduced map.
            Tropical water, slight wave algorithm, buoy is an old SU model of mine.
            http://img127.imageshack.us/img127/9351/tropicalrock.jpg
              The model is called tool (!), there's no save (!)
              Hum hum : Menu Tool/Save as 😉
              Cool seatime images! 😎
              • michaliszissiouM
                michaliszissiou
                For Pilou: Do you know how to use zbrush? I paid 600$ for this and I know how to use it. I also have some posts in zbrush forum but you already know this.
                Pourquoi tu n'arrêtes pas cette habitude, Pilou? C'est la deuxième fois que tu fais la même chose à mes "posts".
                For solo: So you don't need my textured model, just a cone. lol. Nothing to do with September in greek islands, anyway a great render, and I particularly like this model (I don't know how to spell this in english) I've admired in your site. I really had this in mind thinking about a sea scene.
                  Sorry for the misunstanding 😳
                  And I have edited the previous one
                  Don't want any polemics 😄
                  • michaliszissiouM
                    michaliszissiou
                    I'm proud just for one thing here. Rock model under 1000 polys. Unfortunately looks rather soft. But it gonna be the base of a lighthouse, so...
                    Podium render in 20 sec, full quality noisy preset (one reason to love baked models). Just a little PP for SU fog effect.
                    • david57D
                      david57
                      Looks professional.
                      • michaliszissiouM
                        michaliszissiou
                        Thanks david. I post this too so have an idea what's happening with a low polys model + a render engine that doesn't support displacement maps or even normal maps. Rendered in zbrush internal renderer in 10 sec, 2 000 000 polys here.
                        • michaliszissiouM
                          michaliszissiou
                          Here is a podium 20 sec render, not so bad this time, plus a simple SU lighthouse model. So I modeled something with SU after all.
                            remon_v
                            awsome. that quick render with what system specs?
                            • michaliszissiouM
                              michaliszissiou
                              Thanks remon. On a mac pro (2 nehalem xeon, 8 cores 16 threads 2.26 GHz, 6GB RAM)
                              Another two just for fun.
                                remon_v
                                here's my effort. It's not as nice as Michalis' and solos effort. Rendered with vray and a little ps. Suggestions and C%C's are welcome. BTW took me 20 min and 10 s to render with an amd phenom X4 940, 4 gig of ram.
                                http://i22.photobucket.com/albums/b336/remon_v/test7-2.png
                                • michaliszissiouM
                                  michaliszissiou
                                  IMO remon, this background sky is a wrong choice. Doesn't work with the sea (reflections?), it doesn't "explain" the light on the rock either.
                                    redot
                                    Those pics are fabulous Michalis.
                                    Texture baking is working a treat. You'd never know they were low poly.
                                    • N
                                      nomeradona
                                      this is just becoming a great exercise again. nice model and nice water surface. the sceond image of solo looks realistic.
                                      micha... the 20 sec render is my favorite....
                                        remon_v
                                        You're right Michalis... I did see it also, tried to fix it in PS but didn't come out nice.
                                        Ok I did some more testing... Trying to fix the reflections and reducing the rendertime. I setup a billboard at the back. I gave the ship a dark blue (nearly black) texture I put an omni light in front of the sun and removed the "sketchup sunlight". So here it is:
                                        http://i22.photobucket.com/albums/b336/remon_v/3.png
                                        as you can see reduced the time alot 😄
                                        • michaliszissiouM
                                          michaliszissiou
                                          Thats better remon. More reflections are needed though, or maybe try a simpler sky.
                                          Thanks nomer.
                                          Here's a heavier PP.
                                          BTW did you know that Victor Hugo was a great artist too? Do some search in google and I'm sure you wont be disappointed.
                                            remon_v
                                            nice Michalis... I did some other tests. The water is more reflective and I also edited the rock texture a bit. here it is:
                                            http://i22.photobucket.com/albums/b336/remon_v/8.png
                                            • 1 / 3
