    Window and door lines
    2 Posts 2 Posters 754 Views 2 Watching
    • K
      kahukusweet
      When I use top-view in Layout, is there a way to show where the windows and doors are? Most 2d software has lines at both edges, how to I indicate this using layout's 2D views?
      • GaieusG
        I would place a section cut somewhere high enough to "reach" the windows, too. Then make a top view scene with this and in the Tray > SU model you can set which scene you want to display.
        Also see the attached LayOut file and change between Page 1 and 2 to see how different scenes (with different views, camera settings and section cut visibility) of the same model can be inserted like this.
        (Now if we had dimensioning in LO, it would be perfect!)
        πŸ˜‰
        HouseWithSectio.layout
