    Twilight render...
    113 Posts 37 Posters 40.2k Views 37 Watching
    • majidM
      majid
      that is really cool , man... 👍
      I've experienced that adding an interior light source will reduce the noise efficiently..
      • Paul RussamP
        Paul Russam
        Bruce,
        Thanks for that, I'm going to do a couple more setups/test over the next few nights, I'll post um as I do um.
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        • majidM
          majid
          my 5th try on Twi, less post pro as possible (just noise reduction) :tw-5th.jpg
          • F
            fymoro
            very nice mood on this render, where the curtain come from ?
            👍 Fred
            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
            • K
              Khai
              so far all I've been able to render with it is bugsplats...
              open Twilight render splat
              • T
                tomsdesk
                Wow, Majid!
                2.5D Trees & Shrubs!
                • N
                  notareal
                  Paul, setting skyportals should give some benefit in a scene like the this.
                  • N
                    notareal
                    Cant remember when I have got a bugsplat and I use this daily. Maybe some other ryby does not like it... sorry no clues. Did you try 1.0.6 that was just released? If so, better post a bug report
                    • K
                      Khai
                      yup it's 1.0.6. load SU, press 'Open Twilight Render' bugsplat
                      edit :
                      ok it's actually install twilght. try to do anything bugplat
                      remove twilight, everything works fine again.
                      • artysmediaA
                        artysmedia
                        This a try of my Bucklen theater with Twilight demo
                        I dont have touched anything. No lights, nor textures
                        Made with the Prelim setup
                        http://farm3.static.flickr.com/2551/3878458073_0db1cbe2fb_o.jpg
                        Made with the Low+ setup
                        http://farm3.static.flickr.com/2653/3878550423_cd106eb479_o.jpg
                        Made with the Medium+ setup
                        http://farm4.static.flickr.com/3522/3878610097_2be5a24feb_o.jpg
                        Is it good enough? 😉
                        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                        Blog: Artysmedia
                        • majidM
                          majid
                          👍 Fred
                          thanx mate 😄 , curtains are shared over here : http://forums.sketchucation.com/viewtopic.php?f=81&t=21516
                          • FletchF
                            Fletch
                            Khai,
                            are you the one who was running an old version of XP INSIDE OF VMWARE on a Mac?
                            if not, at least give us some specs one what you are running it in... as we've tested this thing for over a year and a splat is very rare indeed. There's obviously something different about your setup than the 'average joe'.
                            Fletch
                            • K
                              Khai
                              @fletch said:
                              Khai,
                              nope
                              XP Pro, 2GB Ram, AMD Athlon X2 64 5600+, Geforce 9400 1gb, Spacenav PE, Wacom Graphire 4, Dual 17" Samsung LCD's
                              nothing out of the ordinary.
                              • FletchF
                                Fletch
                                XP Pro
                                did you allow it to install the .dll libraries as it asks upon installation? if not, this would be the problem. If your XP is not up to date with latest Service Pack, could also be a problem.
                                Fletch
                                • K
                                  Khai
                                  @fletch said:
                                  XP Pro
                                  installed all the DLL's, running on SR3, all drivers and updates installed.
                                  I reinstalled it and once again the same behavior. plus, it's icons are duplicated in it's tool bar.
                                  I'll take another look later..right now I don't have the time 😞
                                  • FletchF
                                    Fletch
                                    Just downloaded the demo....cooking my first twilight rendering. So far I really like the simplicity of this renderer and that it is fairly seamlessly integrated into SU. the intro price is such that I think I'd be silly not to buy it.
                                    Any plans for future material presets or in general is there a method for adding more material presets easily....I guess I should read the instructions first ...but heck I always just start playing with toys right out of the box before reading the manual..
                                    Hi Phil! Glad you like it. Thank you for the kind words, we worked hard to make it so.
                                    regarding material presets - We felt we covered the bases with Material Templates... there are very few materials I would need as an architect that aren't already in a Template, or easily created by starting with a template, or that isn't already in one of the provided libraries.
                                    Can you tell us what you need/are looking for as far as a missing Template? We will be looking into adding a way to save any tweaks you've made to a template into a custom file you can load again.
                                    Fletch
                                      Rob D
                                      A little test animation done in Twilight with SketchyPhysics. I've been waiting to be able to output SketchyPhysics as a rendered animation for soooooo long!
                                      sketchyp.mov
                                        d12dozr
                                        Great little movie - how long did it take to render?
                                        http://goo.gl/f7ooYh
                                        • X
                                          xrok1
                                          i'd love to see it but i refuse to have quicktime on my machine! (QT's a piece of shit)
                                          • E
                                            Ecuadorian
                                            You can also play it with VLC:
                                            http://www.videolan.org/vlc/download-windows.html
                                            -Miguel Lescano
                                            • 5 / 6
