    Twilight render...
    113 Posts 37 Posters 28.2k Views 37 Watching
    • F Offline
      fymoro
      very nice mood on this render, where the curtain come from ?
      👍 Fred
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        Khai
        so far all I've been able to render with it is bugsplats...
        open Twilight render splat
          tomsdesk
          Wow, Majid!
          2.5D Trees & Shrubs!
          • N Offline
            notareal
            Paul, setting skyportals should give some benefit in a scene like the this.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            • N Offline
              notareal
              Cant remember when I have got a bugsplat and I use this daily. Maybe some other ryby does not like it... sorry no clues. Did you try 1.0.6 that was just released? If so, better post a bug report
                Khai
                yup it's 1.0.6. load SU, press 'Open Twilight Render' bugsplat
                edit :
                ok it's actually install twilght. try to do anything bugplat
                remove twilight, everything works fine again.
                • artysmediaA Offline
                  artysmedia
                  This a try of my Bucklen theater with Twilight demo
                  I dont have touched anything. No lights, nor textures
                  Made with the Prelim setup
                  http://farm3.static.flickr.com/2551/3878458073_0db1cbe2fb_o.jpg
                  Made with the Low+ setup
                  http://farm3.static.flickr.com/2653/3878550423_cd106eb479_o.jpg
                  Made with the Medium+ setup
                  http://farm4.static.flickr.com/3522/3878610097_2be5a24feb_o.jpg
                  Is it good enough? 😉
                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                  Blog: Artysmedia
                  • majidM Offline
                    majid
                    👍 Fred
                    thanx mate 😄 , curtains are shared over here : http://forums.sketchucation.com/viewtopic.php?f=81&t=21516
                    • F Offline
                      Fletch
                      Khai,
                      are you the one who was running an old version of XP INSIDE OF VMWARE on a Mac?
                      if not, at least give us some specs one what you are running it in... as we've tested this thing for over a year and a splat is very rare indeed. There's obviously something different about your setup than the 'average joe'.
                      Fletch
                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                        Khai
                        @fletch said:
                        Khai,
                        nope
                        XP Pro, 2GB Ram, AMD Athlon X2 64 5600+, Geforce 9400 1gb, Spacenav PE, Wacom Graphire 4, Dual 17" Samsung LCD's
                        nothing out of the ordinary.
                        • F Offline
                          Fletch
                          XP Pro
                          did you allow it to install the .dll libraries as it asks upon installation? if not, this would be the problem. If your XP is not up to date with latest Service Pack, could also be a problem.
                          Fletch
                            Khai
                            @fletch said:
                            XP Pro
                            installed all the DLL's, running on SR3, all drivers and updates installed.
                            I reinstalled it and once again the same behavior. plus, it's icons are duplicated in it's tool bar.
                            I'll take another look later..right now I don't have the time 😞
                            • F Offline
                              Fletch
                              Just downloaded the demo....cooking my first twilight rendering. So far I really like the simplicity of this renderer and that it is fairly seamlessly integrated into SU. the intro price is such that I think I'd be silly not to buy it.
                              Any plans for future material presets or in general is there a method for adding more material presets easily....I guess I should read the instructions first ...but heck I always just start playing with toys right out of the box before reading the manual..
                              Hi Phil! Glad you like it. Thank you for the kind words, we worked hard to make it so.
                              regarding material presets - We felt we covered the bases with Material Templates... there are very few materials I would need as an architect that aren't already in a Template, or easily created by starting with a template, or that isn't already in one of the provided libraries.
                              Can you tell us what you need/are looking for as far as a missing Template? We will be looking into adding a way to save any tweaks you've made to a template into a custom file you can load again.
                              Fletch
                                Rob D
                                A little test animation done in Twilight with SketchyPhysics. I've been waiting to be able to output SketchyPhysics as a rendered animation for soooooo long!
                                sketchyp.mov
                                  d12dozr
                                  Great little movie - how long did it take to render?
                                  http://goo.gl/f7ooYh
                                  • X Offline
                                    xrok1
                                    i'd love to see it but i refuse to have quicktime on my machine! (QT's a piece of shit)
                                    • E Offline
                                      Ecuadorian
                                      You can also play it with VLC:
                                      http://www.videolan.org/vlc/download-windows.html
                                      -Miguel Lescano
                                      • X Offline
                                        xrok1
                                        thanks for the reminder, i forgot i had VLC on this machine!
                                        PS, very nice video 😄
                                        • michaliszissiouM Offline
                                          michaliszissiou
                                          xrok1, you could install just a QT codec in your machine, so every viewer could play these pieces. Its easy. You really don't need to install this s...
                                            Rob D
                                            Apologies for the file format, guys and gals. This forum wouldn't allow the mp4 format which plays in flash viewer, so I had to go for quicktime.
                                            The animation took about 2 hours for 120 frames.
                                            • 5 / 6
