    How to choose a renderer for SketchUp
    extensions
    33 Posts 12 Posters 10.0k Views 12 Watching
    • N Offline
      notareal
      For my understanding there is no build in renderer in SU, only some OpenGL acceleration, so "features in native SketchUp" is what eryone can see without a renderer - everything else is added feature. Naturally a render pluging should be able to repeat SU functionality, but honestly does one need a renderer just for that?
      Certainly some of the advanced global illumination features available from various render plugins, might be overkill for some, but those can be essential to others. For example if interior designer or a architect is using indirect light, should the render plugin produce a acceptable solution. And what if translusent materials are used - blurry reflections and subsurface scattering is fairly native feature of these materials in real world, like caustics for glass, water or metals - all find from SU buildin materials.
      Therefore if the video where a real tutorial and not a advertorial, these features should be atleast mentioned, even if this was ment to be focused to basic features (sorry cannot recall if that kind of focus was mentioned in the video).
      • soloS Offline
        If I may....
        I just watched the video, read this thread and I have a few questions and observations.
        Does Dennis work for Irender?, I think he does as once it was announced here, so for him to set the parameters of what a renderer should have is kinda self serving.
        At one point in the video Dennis does a render and says "not a lot has changed, that's the point" really? then why render in the first place?
        He uses 2d face-me photo cutouts which when rendered will look like 2d photo cutouts, what's the point of rendering?
        Then you have the whole 2d clock, that once rendered looks exactly as it did before rendering...am I missing something here? Is SU not a 3D app? why using all 2d faces? why render at all if you are using photo textures?
        Then there is the cutout tree that when rendered looks like a 2d tree with soft shadows, that's why top renders have 3d trees as they actually look 3d. I suppose the argument for 2D trees would be because SU cannot handle too many poly's, if this indeed is the case then the whole beginning of the video makes no sense when Dennis says that an integrated render solution is best as that will limit you to use 2D cutouts that look well...2D, where if your render solution was stand alone you could then import your vegetation separately and not be forced to count the polys.
        The well/pond thing, who models like that? a face with two material applied on either side, that's elementary modeling mistakes and should not be a renderers problem to solve but rather a users skills not to do.
        I do not think this video in anyway should be a guide as IMO it's biased and setup so that only one product can qualify to it's strange requirements of what a render should be like.
        I believe if the final product in the video is what a user is hoping to achieve then they need not bother rendering as setting up all those 2d images is enough, and if that is the quality you are after then maybe modeling is the first step to achieving a good render.
        IMO a good render solution does not have to be integrated, in fact there are pros and cons to this that needs a long discussion, what about biased verses unbiased rendering?
        There is no one solution that works for all renders, that's why it's important for a user to look at galleries and see the quality of what can be achieved, then once they have their modeling skills tuned enough to create a render worthy model with good texturing they can download all the free trials and demo apps and find the one they enjoy to use that will give them the results they need. They also need to take int account that today's needs will change as they get better they will require better and better results, so make sure you choice of renderer is not limited to your initial skill set but as you get more advanced so does your ability to use more advanced render setting, and more realistic features, make sure that your render solution does not limit your skills and results because it's limited to being 'easy'.
        • Al HartA Offline
          Al Hart
          @solo said:
          If I may....
          I just watched the video, read this thread and I have a few questions and observations...
          Dennis does work for Render Plus. I asked him to create this tutorial as a starting point for people who are looking for a renderer, who do not know much about rendering, and who are overwhelmed by the thought of trying out all 30 renderers mentioned in the SketchUcation forum.
          We are not saying that these are the only qualities you want in a renderer. I guess what we are saying is: If a renderer cannot render the Photo cutouts, or cannot render the 2D clock, or other basic SketchUp features, then perhaps you should consider a different renderer.
          Al Hart
          IRender nXt from Render Plus
          • soloS Offline
            Al, please do not get me wrong, I'm not on a witch hunt, I just do not agree as to what y'all believe a renderer should be.
            We are sent lots of models with 2D faces. Maybe people should not create models like that - but they - especially in massing studies where they create a basic shape for a building and want to wee what it will look like.
            If indeed they are using SU for a massing study why in the world would they want to render it? as the photo textures and cutouts would be sufficient IMO.
            Why is it necessary for a 'good renderer" to need to be able to render a photo texture?
            I guess the real question that begs to be asked is What is a render? and why do we render?
            Rendering photo textures IMO is silly and not needed, seen any renders on Google earth? as that's pretty much what the model in the video looks like.
              d12dozr
              @solo said:
              If I may....
              Thanks for this assessment of the the video, Pete. As a rendering newbie, I was wondering what to make of the the 'tutorial'. Judging from the quality of your renders in the gallery, you clearly know what you are talking about, and this helps me alot.
              I was also wondering who makes models like that clock or well from the video 😕
              http://goo.gl/f7ooYh
              • honoluludesktopH Offline
                honoluludesktop
                Hi Solo, Very informative post. I did not stop to consider the implication of photographic textures on surfaces, and upon further examination, realized that the 2D trees are such that they do not cast correct shadows in SU.
                For me, the value of a renderer is found in its integration into my Cad work flow in order to produce conceptual, as well as final renders. Looking for ease, speed, and beautiful:-)
                • Al HartA Offline
                  Al Hart
                  You would use a similar "distorted texture" technique to place an image of a painting on a painting in the model - if the image of the painting was not head on.
                  Most images of painting are "head on" - but the ease of "distorting" an image in SketchUp to make an oblique image fill a rectangular area it one of SketchUp's important features.
                  http://www.unisanet.unisa.edu.au/art/Colour Theory Painting III -.jpg
                  Also, a Landscape Designer may want to place trees and bushes around an existing house and render it - for example to have a reflective pond - and may want to use a photo image for the existing house.
                  Une "undercurrent" of this discussion is the difference between really good users of rendering software - who probably already have a preferred renderer and are just glad that a SketchUp renderer is available and beginning renderers who want a lot less. We were working with a local firm last year whose main desire for the renderer we to get reflections of adjacent building into windows of building they were designing. They weren't looking for wonderful renderings - just something better than SketchUp could offer. This is a very simple application which just wants to add reflection to windows - but want the rest of the rendering to look pretty much the same as the SketchUp model they had already created.
                  Al Hart
                  • soloS Offline
                    "By the way, 3,000 people have watched this video on You Tube so far. (I am exaggerating slightly - but it will probably be 3,000 by the time you read this post.)"
                    Al, this is what concerns me the most. The author of the video has a Renderplus logo that leads straight to your You tube expose page, and then there are postings referring to the renderer used for the video, so in essence it's an advert that is disguised as a decision making tool.
                    I post here as a user and a moderator, and consider myself pretty unbiased, however I do see this as a marketing ploy in order to get more sales for your product and not an informative and constructive way of educating new users into making a true decision as your video is totally biased and set up for your product.
                    I also noticed you had a banner ad purchased on this forum to advertise this video too, unless you had something to gain why would you pay to advertise this video?
                    http://img9.imageshack.us/img9/9828/alhartad.jpg
                    My point here is if we are going to help folk decide on a render solution then let it be from an unbiased source, let it be fair and most of all let it be accurate.
                    "If you have other things people should look for in a good rendering engine, go ahead and add them to this thread"
                    I'd rather say a new thread needs to be started where this video does not get more exposure, where users can contribute as to what they feel is important in a render solution.
                    I hope I'm not coming across to hard or rude, I just think that this video is biased in favour of your product and not accurate to what a renderer should be, I suggest the users decide what's important then a video can be made based on researched needs and not features your product has which others do not.
                    • Al HartA Offline
                      Al Hart
                      If you have other things people should look for in a good rendering engine, go ahead and add them to this thread. (I promise not to get into a debate on whether other ideas are important or not. I only get on my high horse when certain posts suggest that my own thoughts and ideas are not valid.)
                      I think that healthy discussions of third part renderers will be good for all of us. (I know that we have discussions about renderers every 6 to 8 weeks or so - but new users and new forum participants are not always familiar with old threads.)
                      I did not mean, in an earlier thread, to imply that Caustics (and other features) were not important - but rather to point out that they were beyond the scope of this beginning video.
                      What are the most important features to look for? (I think we would all like to know)
                      Al Hart
                      • E Offline
                        Ecuadorian
                        When I've been new to a field and knew nothing about a certain type of product, be it cameras, printers, monitors, projectors, etc., I've relied on "how to choose an X" and "buying guides" in magazines and well-reputed sites in those fields.
                        These guides often first introduce you the different kinds of products available, and the general pros and cons of each kind. For example, if you're looking for a camera, they explain the difference between point-and-shoot, dSLR models and hybrid (camcorder/still camera) models, for printers, they explain how laser ones and inkjet ones work, and for projectors, the first guide I read was about LCD, DLP and LCOS imaging technologies.
                        Within each category, these guides often tell you the pros and cons of each design decision the manufacturers make. For example, in compact cameras, there are very small ones with proprietary batteries that allow them to be ultra small, and there are those using stadard AA batteries, which are bigger but you can find batteries anywhere in the world. So you see, what might be a desired feature to someone might be a drawback to someone else. What's more, you might want to have two or more cameras for different tasks.
                        These guides also place emphasis on the fact that there is no single product that can cover the needs of every user, so they often show charts of features, and no product can fill every single chart item with a positive. Within each different category, these guides give "Editor's choice" badges to the product that offered the most balanced performance/features/price combination at the time of printing, but they also give "special interest" badges to other outstanding products that might cover more specific needs.
                        Those are truly guides.
                        Now, imagine a "guide" on "how to choose a camera" that told you:
                        "It must be a point-and shoot model so you can carry it around, it must use AA batteries instead of proprietary ones so you can buy spares while in the countryside, and it must have a vari-angle LCD screen so you can shoot above crowds in rock concerts."
                        There are only one or two models fulfilling these seemingly reasonable requirements, but that would not be a guide; that would be a product brochure. And no magazine or reputable tech site would allow this to be passed as a buyer's guide.
                        -Miguel Lescano
                        • N Offline
                          notareal
                          Thanks Pete & Miguel, could not agree more.
                          • 2 / 2
