    Bad News for Architects in the next ver. of Google Sketchup
    109 Posts 42 Posters 69.2k Views 42 Watching
    • L
      linea
      First paragraph in the update sums it up
      I don't often talk about new things we're building before we nudge them gently out the door... We've been working hard ... and have cooked up a bunch of new stuff that I know you're going to like.
      And that is why Google have very little idea about what people want.
      I imagine they are removing the dwg/dxf import from the free version for one reason which seems so transparent. They aren't selling pro licenses anymore. At least by doing this they will realise how many architect and design practices use Sketchup.
      • H
        HPW
        Really bad news.
        Bad habit to remove features.
        Just finished an automated conversion process using autocad and SU in one toolchain to create 3D-content in DWG and SKP format.
        So either no upgrading or removing SKP from the offered formats.
          dedmin
          Seems to me strange to pay a tons to Autodesk for their crappy monopole and complain about Google decision! The problem is ALWAYS closed and proprietary file formats that holds you in companies prison! If thee were open drawing format for years...
          Can you open jpgs in any image viewer? 😡
          • GaieusG
            @kwistenbiebel said:
            ...taking out one of the most needed exportformats? I don't know...
            Chris,
            They are only talking about the free version and dwg/dxf exporthas always been only part of the Pro version (where dwg/dxf import / export will be kept as I understand).
            • GaieusG
              OK, I see, that's a different point then.
              • K
                kwistenbiebel
                Yes, 'import' I should have said.
                In my case, importing a DWG in SU is often the start of a new project.
                • honoluludesktopH
                  honoluludesktop
                  I came to (down graded 🙂 "free" sketchup when my solid modeler went from hundreds of dollars to thousands between v1.1, and v2.0. Because I use Su primarily to visualize, dxf import is essential to my work flow. I am less concerned with paying for Su, then what this implies for the future of Su as an Architect's tool.
                  To me, "Unfortunately, this improvement won't come without a cost. Import/export capability is tough for us to maintain and tough for you to use effectively. There are just so many fiddly little settings on both sides of a file exchange that it is always a challenge to get everything working just right. Looking forward, we decided to make a trade-off." suggest that at some point in the future, dxf may be abandoned.
                  This action implies that the Su database may under go massive change when v8 is released. Perhaps, animation will cease to be "free", as the documantation maintains. Maybe after they fix the shadow bug. Sigh........, I just hope that the cost of "Pro" doesn't jump into the thousands >_<
                  • H
                    HPW
                    I do not tell that I am happy to pay tons to Autodesk, but when I want to support customers with their prefered data-format, then I have no other chance.
                    (And I have to accept that they want tons of money every 3 years.)
                    But Autocad is still a lot better in producing drawings/3D-content in a professional/automated way. (You can not use Ruby for SU-Layout)
                    Also it has still much more options to customise it for your own needs (LSP/DCL/CUI/VBA).
                    Anyway I complain about Google that they are on the way to get the same behaviour like Autodesk.
                    And isn't SKP also a closed and proprietary file format?
                      dedmin
                      We originally assumed that our free Google SketchUp users would never really need to export models into other tools. As it turned out, folks wanted to use Google SketchUp models in all kinds of crazy ways. Things that we could never have imagined! We decided that Google SketchUp users should be able to export their models into some easy-to-read and fundamentally hackable file format to make this easier. Your models should be yours to do with as you see fit.
                      In our next release, we're going to make COLLADA an official first-class format for all modelers. You'll be able to import and export COLLADA models, as well as COLLADA models wrapped up in the KMZ format for Google Earth, with any version of SketchUp.
                      We are not talking about software capabilities, but data formats and data exchange! You have to own your files and exchange them freely with others. Draw with AutoCAD, save the files in an open file format and send to anybody even without AutoCAD licence.
                      • EdsonE
                        Edson
                        this is really odd. to my knowledge most modelling in sketchup starts with a dwg/dxf import whereas i never heard of anyone importing anything in collada format.
                        so why would google do this? to boost sketchup pro sales?
                        a question: can you export in collada from autocad? and would it be the same importing a plan in collada as it is today in dwg/dxf?
                        http://www.mahfuz.arq.br
                          dedmin
                          http://labs.autodesk.com/utilities/google_earth_extension_beta/updates/
                          • H
                            HPW
                            First autocad would have to support this open file format!
                            (And it is not sure that any other data-format transport the datat exactly as DWG.)
                            The Google Earth plugin from the autodesk labs seems to support this!
                            One drawback is that only Autocad 2007 and up are supported.
                            (I have currently Autocad 2006 running)
                              dedmin
                              Then ask Autodesk to fully support collada export - you are paying for their softwarae, not for the free SketchUP! Or to fully open dwg file format! Big boys always try to kill the small fishes - here in East Europe multinational companies are doing this since democracy!
                              • T
                                tomsdesk
                                I suspect this is the beginning of the end of the pro version: way to see how many dedicated pro users really exist before dumping the rowdy bunch we are.
                                2.5D Trees & Shrubs!
                                • soloS
                                  Let's not jump to negative conclusions just yet, remember he also said "I think you'll be pleasantly surprised by many of the changes we've made", 😉 , I would trust him on this one.
                                  • L
                                    linea
                                    I'm hoping you know something we don't Pete!
                                    • ely862meE
                                      ely862me
                                      If i remember well when i had skp 5 i was hoping for great improvements to skp6 and when comes out.. it was almost the same...same happened with skp7 which i almost find slower than 6 and i even don t use it..
                                      To believe they made great improvements I have to see first..
                                      My most wanted improvement is supporting high polys models...if this is fixed i almost don t need anything else..of course an integrated render engine will be high5,but that s something more difficult and much expensive .
                                      My 0.002$!
                                      Elisei
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                        jstanton8869
                                        Well, I have the Pro version so I'm more interested in what's actually coming - proper 64 bit and GPU support and therefore real improvements in performance maybe? I'm happy to pay for software that has real value and is up to date.
                                        I'd rather Google actually made money from Sketchup and then had a real incentive to keep supporting it. Ever since they bought @Last the momentum just seems to have slowed down IMHO
                                        John
                                          mhtaylor
                                          For those of you who depend on the importers we plan to remove, we'll be providing an optional download that enables them again. But remember! This installer will only be available for a limited time, and it will not be supported at all in our next major release.
                                          This statement in the post seems to indicate that it's not going totally away if that's hope to any of you.
                                          The Other Martin Taylor aka: The SketchUp Fanboy
                                          • david_hD
                                            david_h
                                            What are the ramifications for the Education Side of SU? I teach SU to Interior Designers at a private college and they use Google FREE Version (they are students after all) and they import their Acad Floor plans into SU For their presentations. This sounds like it would seriously interupt their work flow. I do not COLLADA at all, so I guess I need to look at it, but Some answers to these quesitons would be helpful.
                                            Let's all sing
                                            If you like Using Collada. .. or getting caught in the rain. . .If you like using PRO sketchup. . .if you have half a brain. ..
                                            • 1 / 6
