    Firefox not remembering
    12 Posts 5 Posters 1.2k Views 5 Watching
      Aerilius
      Did you check if cookies are still allowed? Maybe the configuration was a bit confused.
      • boofredlayB
        boofredlay
        I will check in the morning when I get back to the office. Thanks for the reply.
        • GaieusG
          Maybe clear sketchucation cookies if nothing else helps and log in again.
          • boofredlayB
            boofredlay
            Well it is happening with every forum or form I log onto, not just SketchUcation. When I get into the office this morning I think I will clear all the cookies and restart. Hopefully that will do the trick. Maybe our power outage (surge) burned the cookies.
            http://picon.ngfiles.com/402000/portal_402149.gif
            • boofredlayB
              boofredlay
              Well no go.
              Dang this is getting frustrating. Firefox is remembering my passwords but not logging me in automatically to anything 😑
              I tried Internet Explorer and it is functioning properly so it has to be a Firefox setting that is not right.
              Grrr.
              • boofredlayB
                boofredlay
                I just reinstalled Firefox and the problem is still there. I am going to feel real stupid when I find out the problem I am sure 😳
                  This happened to me before and i was advised to install 'cCleaner' http://www.ccleaner.com
                  Analyse with this program and then run cleaner
                  Restart PC and next thing it worked fine?
                  Also i disabled plugins for FF and see if that helps?
                  • boofredlayB
                    boofredlay
                    Thanks Rich but that would not have helped. I do have CCleaner.
                    I have fixed the problem. After reading help logs on Mozilla it turns out to be a couple of corrupt files in the Profile way down deep:
                    C:\Documents and Settings\eric.LOCAL\Application Data\Mozilla\Firefox\Profiles\ucobnvhd.default
                    The two that were corrupted were:
                    cookies.sqlite
                    cookies.sqlite-journal
                    Delete and restart.
                    I am glad I found it and I don't feel so embarrassed as it was not a simple setting.
                    • GaieusG
                      Hm. Should I (no - I WILL) bookmark this post.
                      Does it really work?
                      • boofredlayB
                        boofredlay
                        Works fine now. Evidently this is a common problem. There were a number of topics I found regarding the issue dating back a few years.
                        • PixeroP
                          Pixero
                          I have this exact problem with IE8 but NOT with Firefox. Any ideas?
                          (Every forum not just Sketchucation.)
