    Very heavy model.
    28 Posts 16 Posters 3.5k Views 16 Watching
    • AdamBA
      AdamB
      I think kwistenbiebel's toptip about not going nuts with nesting is a good one. Not particularly from a technical standpoint - there is no reason why a 3 nested model works but a 5 nested does not - but because its deceptive just how much geometry you're generating by adding a top level with many nested parts.
      One thing I added to my stuff is a Context (right-click) menu that will flip any component to a bounding box proxy component. So you can select your toplevel nested components and flip them into box proxies for positioning and fast navigation but they get rendered using the original geometry. The flip is pretty much instant (unlike exploding) so it doesn't break the workflow.
      So if I highlight all my top level complex nested components, it looks like this:
      Then I can orbit/navigate really fast using simple proxies
      And to flip back to the original geometry
      Adam
      • soloS
        Cool trick Adam, is this an available ruby or one of your personal ones?
        • AdamBA
          AdamB
          Thanks.
          No, its part of that glorious LightUp plugin.. πŸ˜„
          • GaieusG
            Cool feature for sure. Another reason to at least try it out! πŸ‘
              alpro
              Any chance of making it a seperate commercial ruby?
              Mike
              • Jean LemireJ
                Jean Lemire
                Hi Tiriki, hi folks.
                @tiriki said:
                Hi everyone!
                I pull up this discussion because I have the same problem... my model is too heavy (86 Mb) and it takes too much time to save and open... also I have some difficulty to go around into the model whit the orbit tool.
                Are only the texture that cause this problem? I tried to explode some components and groups and I pourged the model, but the file became heavier (94 Mb).
                Do you have some suggestion for me?
                Thank's πŸ˜’
                To speed up orbit, pan, zoom, etc with a heavy model, try to show as little of the geometry as you can before using these tools. Then, when done, show all that want.
                For example, I would use "Shaded" viewing mode instead of "Shaded with textures" or even "Wireframe" for more extreme cases. I would also set the profiles to 1 pixels instead of 3 (default value). I would set shadows to off. I would hide as many elements as possible, using layers made invisible and, of course, assigning the unneeded geometries to these layers. Etc, etc. Everything that requires computing power from the graphic engine would be minimalised.
                Then, I would create a scene and uncheck the "Camera location" from the items to update. This in order not to affect the actual view. Lets call this scene "Work".
                Then I would create another scene where all the wanted elements would be visible, the shadows on, if needed, the profiles at 3 pixels or whatever you want. Etc, etc, required for the nice view that you want. Again, I would make sure to uncheck the "Camera location" to avoid loosing a carefully defined view. Lets call this scene "Render".
                Then the workflow becomes:
                1 - Click on the scene tab for "Work".
                2 - Orbit, pan, zoom to set the view as you want it. Since there is very little to show, the actions shall be fluid.
                3 - When done, click on the scene tab "Render". It should not take too long for the image to improve with all hidden stuff now shown, etc.
                Just ideas.
                • AdamBA
                  AdamB
                  Mike
                  Sure. I'll need to get some feedback from LightUp users first - and get the next version out too! But after that, I don't see why not.
                  Adam
                  • Bob JamesB
                    Bob James
                    @adamb said:
                    Thanks.
                    Adam,
                    You may recognize my name from the LU Forum (I'm the one having all the problems with LU freezing the SU window).
                    My real question here is: where in LU is the proxy plugin that give the right click "Replace with Proxy" command? If I can ever get LU to work, this proxy capability would be a handy tool since most of my models are "heavy".
                    • AdamBA
                      AdamB
                      Its part of LightUp v1.5 which out in a few weeks.
                      However, in LightUp you have always been able to place a Component with a definition called "XYZ**_proxy**" and LightUp will replace it with the Component Definition called "XYZ". I've just added an easy UI to the functionality for v1.5
                      Adam
                      • AdamBA
                        AdamB
                        Posted the LightUp version here a little later than planned.
                        Adam
                        • 2 / 2
