    Robot Photo Match [Updated]
    20 Posts 8 Posters 1.9k Views 8 Watching
    • olisheaO
      olishea
      What an image!! so dynamic! epic
      I have no idea about posing models etc because this is the first figure I have played with. Normally I just do architectural modeling etc.
      However, that radial bend tool for the FreeScale / FredoScale plugin (cant remember which one) is fantastic. Other than that, just group every limb separately.
      I think the hardest thing is matching the tone,hue and resolution of the background photo πŸ˜•
      Thanks Durant, poured one πŸ‘
      oli
        dacad
        Thanks for the tip with the radial blend! That must be great ofr posing more organic models.
        For robots and other types of machines i normally also so what you said, group everything, but i also atatch some help faces in the places that are supost to have be the joints of the robot (see the picture above). That help faces have to allow me to rotate correctly in any direction thats why i use a 3 faces joined at the center.
        Oh and in photoshop remember that you don't have to make everything match the background photo, it's better if you find a mid point between the render and the background picture, so don0t be afraid to change and edit a lot the background πŸ˜‰
        joint (help faces)
        • olisheaO
          olishea
          thanks, i understand, helps a lot. πŸ‘ πŸ‘
          oli
            sketchup_fan
            Hahaha, the robot soldier is on the wrong side of the road. He doesn't realize he is in England.
            • olisheaO
              olishea
              its a one way street!! πŸ˜•
              oli
              • marked001M
                marked001
                haha...this update is awesome! pose and shadow are great....
                is it safe to assume that he is pretty much 2d? since you used photomatch... it definitely comes off as 3d, just wondering..
                http://www.revision21vis.com
                instagram: revi21on
                  dacad
                  HAHAHHAH!! 🀣
                  That's great olishea!! You gave me the first laught of the day. πŸ‘
                  Congrats on a great evolution, a nice image composition and a very cool ideia πŸ˜‰.
                  David
                  • olisheaO
                    olishea
                    no no no. its a textured 3d model, but yeah the photomatch scene is 2d. (see screen grabs)
                    The render needed a lot of work cos the colours didn't match too well. Also the model is texture baked (from 3d warehouse) so the shadows needed faking a bit. good bit of fun!
                    I would post the skp but its 7 MB.
                    Cheers David, your crit helped me improve the image and find my faults. I used your technique for posing, worked v well. πŸ‘ πŸ‘ πŸ‘
                    thanks very much for comments
                    http://i654.photobucket.com/albums/uu269/olishea/Picture6.png
                    http://i654.photobucket.com/albums/uu269/olishea/Picture7.png
                    oli
                    • T
                      tomsdesk
                      "Gimme a lift" is a hoot-and-a-half! Nice work, Oliver!
                      2.5D Trees & Shrubs!
                      • GaieusG
                        Really cool, indeed!
                        If I may - just a minor crit; the shadow under the car looks much shorter (the sun being much more above) than the shadow of the robot. Since nowhere else the shadows are too apparent, I guess "correcting" the shadow of the car in PS would be the easiest way to fix this.
                        • olisheaO
                          olishea
                          yeah but the shadows to the railings behind were quite long so I tried to find a compromise. I set the time and date to the exact time/date/location the photo was taken but its still not quite right.
                          thanks for pointing it out, might correct it now actually cheers
                          oli
                          • olisheaO
                            olishea
                            How about this.
                            I call it "gimme a lift"
                            Imagine seeing that at the side of the street. Question is.....would you give him a lift?
                            http://i654.photobucket.com/albums/uu269/olishea/chiefmatch2small-5.jpg
                            oli
                            • marked001M
                              marked001
                              alright..i'm a zombie....not sure what i was thinking....haha...too many all-nighters! great stuff.
                              instagram: revi21on
                              • plot-parisP
                                plot-paris
                                really nice image. I am impressed, how well the colours of your soldier match the ones in the photo. how did you do it? match-colour function in photoshop?
                                • olisheaO
                                  olishea
                                  no...i wish.
                                  well i used match colour (background image as source) at first to get a general hue of the background photo, with v low opacity.
                                  then was just a case of curves, levels, hue/saturation, contrast, colour balance. selective colour, gradients, sharpness, high pass filter, offset grunge overlay for better texturing. playing with different belnding modes helps a lot
                                  I always make sure to use adjustment layers as clipping masks too so you can fade them in/out.
                                  once the shadows and general colour was right I flattened the image and worked on the photo and render together to add more warmth, sharpness, god rays (v pale), depth, saturation and finally a vignette at the end.
                                  the actual render was very off in colour (very yellow and saturated) and stuck out like a sore thumb cos its texture baked from in-game images.
                                  oli
