    Needed: Examples of flood proof / flood resistant buildings
    13 Posts 7 Posters 1.1k Views 7 Watching
      Hi Jon,
      My country is rather floody (in fact, believe it or not, there are more extensive dam systems than in the Netherlands due to it lying in a basin which collects all the surrounding waters but lets them out in a single river).
      The only "real" solution here so far (beside NOT building in flood areas - i.e. on hills only) is that you build your house on pillars higher than the top of the dam.
      Now of course most people use that space under the house (so mostly the "walls" are built in) but in case of necessity, things can be moved upstairs and (probably) water isolation prevents the water from soaking higher than the "bottom of the real building" above.
      • W Offline
        watkins
        Dear Jon,
        Would this be of interest?
        Server Unavailable
        (www.bris.ac.uk)
        Regards,
        Bob
        • BepB Offline
          Bep
          Or this?
          http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&q=drijvend+huis&sa=N&start=0&ndsp=20
          Bep van Malde
          "History is written by the winners"
            linea
            Thanks Bep, Bob and Csaba,
            All very good info
            Please keep them coming!
            • BepB Offline
              Bep
              http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=paalwoning+water&btnG=Afbeeldingen+zoeken&aq=f&oq=
              http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=woonboten&btnG=Afbeeldingen+zoeken&aq=f&oq=
              http://www.waterbestendigbouwen.nl/index.htm
              Bep
              • DanielD Offline
                Daniel
                The vernacular architecture of southern Louisiana and Mississippi are built up off the ground, frequently with substantial masonry pillars supporting a classical porch above. Sometimes the space below is used for a garage or other minor uses. This seems to be the universal design solution for flood prone areas, until modern man decided technology can conquer nature.
                My avatar is an anachronism.
                • olisheaO Offline
                  olishea
                  Tom Kundig's "Delta Shelter"
                  Built on stilts in a flood plain.
                  NameBright - Coming Soon
                  (www.oskaarchitects.com)
                  I had the pleasure of meeting this guy! Probably one of my all time favourite architects, master of the vernacular.
                  Check out the internal images as well......the whole facade can be opened by the turn of a wheel hahaha
                  oli
                  • W Offline
                    watkins
                    Download the .pdf files from these sites:
                    http://www.communities.gov.uk/publications/planningandbuilding/improvingflood
                    404 - Unknown site
                    (www.buildingscience.com)
                    Here is another, but the doc costs 59 USD
                    http://www.techstreet.com/cgi-bin/detail?product_id=1250485
                    Also:
                    http://www.wbdg.org/resources/env_flood.php
                    http://www.longboatkey.org/Departments/PZB/FIA-TB-2-93.pdf
                    This also looks interesting:
                    Bad Request
                    (www.topsider.com)
                    • olisheaO Offline
                      olishea
                      also look at borneo island in amsterdam........"scheepstimmermanstraat"
                      i think thats how u spell it.
                      oli
                        linea
                        Thanks Oliver, Bob, Daniel & Bep
                        I really appreciate it
                        Jon
                        • Alan FraserA Offline
                          Alan Fraser
                          http://www.inhabitat.com/2009/07/29/the-citadel-europes-first-floating-apartment-complex/
                          3D Figures
                            linea
                            Thanks Alan
