    Needed: Examples of flood proof / flood resistant buildings
    13 Posts 7 Posters 826 Views 7 Watching
      linea
      Hi all
      New job, new assignment. I am researching a trip to the Netherlands to look at flood proof and flood resistant architecture. Ideally buildings that accept that water is part of the environment and work with it, not against it. All suggestions welcome. Even if you aren't in the Netherlands, if there are good examples you know of elsewhere I would be very interested.
      Jon
        Hi Jon,
        My country is rather floody (in fact, believe it or not, there are more extensive dam systems than in the Netherlands due to it lying in a basin which collects all the surrounding waters but lets them out in a single river).
        The only "real" solution here so far (beside NOT building in flood areas - i.e. on hills only) is that you build your house on pillars higher than the top of the dam.
        Now of course most people use that space under the house (so mostly the "walls" are built in) but in case of necessity, things can be moved upstairs and (probably) water isolation prevents the water from soaking higher than the "bottom of the real building" above.
        • W Offline
          watkins
          Dear Jon,
          Would this be of interest?
          301 Moved Permanently
          (www.bris.ac.uk)
          Regards,
          Bob
          • BepB Offline
            Bep
            Or this?
            301 Moved
            (images.google.nl)
            Bep van Malde
            "History is written by the winners"
              linea
              Thanks Bep, Bob and Csaba,
              All very good info
              Please keep them coming!
              • BepB Offline
                Bep
                http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=paalwoning+water&btnG=Afbeeldingen+zoeken&aq=f&oq=
                http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=woonboten&btnG=Afbeeldingen+zoeken&aq=f&oq=
                http://www.waterbestendigbouwen.nl/index.htm
                Bep
                • DanielD Offline
                  Daniel
                  The vernacular architecture of southern Louisiana and Mississippi are built up off the ground, frequently with substantial masonry pillars supporting a classical porch above. Sometimes the space below is used for a garage or other minor uses. This seems to be the universal design solution for flood prone areas, until modern man decided technology can conquer nature.
                  My avatar is an anachronism.
                  • olisheaO Offline
                    olishea
                    Tom Kundig's "Delta Shelter"
                    Built on stilts in a flood plain.
                    http://www.oskaarchitects.com/Projects/38/Delta-Shelter
                    I had the pleasure of meeting this guy! Probably one of my all time favourite architects, master of the vernacular.
                    Check out the internal images as well......the whole facade can be opened by the turn of a wheel hahaha
                    oli
                    • W Offline
                      watkins
                      Download the .pdf files from these sites:
                      http://www.communities.gov.uk/publications/planningandbuilding/improvingflood
                      Redirecting to https://buildingscience.com/documents/digests/bsd-111-flood-and-hurricane-resistant-buildings
                      (www.buildingscience.com)
                      Here is another, but the doc costs 59 USD
                      (www.techstreet.com)
                      Also:
                      Unified Facilities Guide Specifications (UFGS) | WBDG - Whole Building Design Guide
                      (www.wbdg.org)
                      http://www.longboatkey.org/Departments/PZB/FIA-TB-2-93.pdf
                      This also looks interesting:
                      http://www.topsider.com/
                      • olisheaO Offline
                        olishea
                        also look at borneo island in amsterdam........"scheepstimmermanstraat"
                        i think thats how u spell it.
                        oli
                          linea
                          Thanks Oliver, Bob, Daniel & Bep
                          I really appreciate it
                          Jon
                          • Alan FraserA Offline
                            Alan Fraser
                            (www.inhabitat.com)
                            3D Figures
                              linea
                              Thanks Alan
