Needed: Examples of flood proof / flood resistant buildings
Hi all
New job, new assignment. I am researching a trip to the Netherlands to look at flood proof and flood resistant architecture. Ideally buildings that accept that water is part of the environment and work with it, not against it. All suggestions welcome. Even if you aren't in the Netherlands, if there are good examples you know of elsewhere I would be very interested.
Jon
Hi Jon,
My country is rather floody (in fact, believe it or not, there are more extensive dam systems than in the Netherlands due to it lying in a basin which collects all the surrounding waters but lets them out in a single river).
The only "real" solution here so far (beside NOT building in flood areas - i.e. on hills only) is that you build your house on pillars higher than the top of the dam.
Now of course most people use that space under the house (so mostly the "walls" are built in) but in case of necessity, things can be moved upstairs and (probably) water isolation prevents the water from soaking higher than the "bottom of the real building" above. -
Or this?
Google Afbeeldingen
Google Afbeeldingen. De grootste zoekmachine voor afbeeldingen op internet.
(images.google.nl)
Bep van Malde
Thanks Bep, Bob and Csaba,
All very good info
Please keep them coming!
http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=paalwoning+water&btnG=Afbeeldingen+zoeken&aq=f&oq=
http://images.google.nl/images?hl=nl&lr=&safe=off&rlz=1G1GGLQ_NLNL250&um=1&sa=1&q=woonboten&btnG=Afbeeldingen+zoeken&aq=f&oq=
http://www.waterbestendigbouwen.nl/index.htmBep
The vernacular architecture of southern Louisiana and Mississippi are built up off the ground, frequently with substantial masonry pillars supporting a classical porch above. Sometimes the space below is used for a garage or other minor uses. This seems to be the universal design solution for flood prone areas, until modern man decided technology can conquer nature.
Tom Kundig's "Delta Shelter"
Built on stilts in a flood plain.
http://www.oskaarchitects.com/Projects/38/Delta-Shelter
I had the pleasure of meeting this guy! Probably one of my all time favourite architects, master of the vernacular.
Check out the internal images as well......the whole facade can be opened by the turn of a wheel hahaha
Download the .pdf files from these sites:
http://www.communities.gov.uk/publications/planningandbuilding/improvingflood
Here is another, but the doc costs 59 USD
Also:
This also looks interesting:
also look at borneo island in amsterdam........"scheepstimmermanstraat"
i think thats how u spell it.
Thanks Oliver, Bob, Daniel & Bep
I really appreciate it
Jon
Thanks Alan
