    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 31.3k Views 12 Watching
    • W Offline
      Wacov
      Got cloth smoothing working, and made it easier to change the scripting (everything's in the floor). Chris, it seems if there's a script error in onend, objects fail to move back to their starting positions... and it can't be undone 😕 Try sticking jargon in onend, and see for yourself.
      Anyway, the updated cloth!
      Cloth wth smooth faces.skp
        CPhillips
        Thanks. I fixed it.
          CPhillips
          This script is inspired by a new model on 3dwarehouse that ran really smooth... once I turned off shadows and edges.
          Paste this into one objects scripted field. It tries to speed up the rendering by disabling shadows and edges during the simulation. Don't worry if you dont understand it. It should be plug and play.
          onstart{
                #save current settings
             ropts=Sketchup.active_model.rendering_options
             sopts=Sketchup.active_model.shadow_info
             @saveROpts=ropts.collect{|k,v|[k,v]}
             @saveSOpts=sopts.collect{|k,v|[k,v]}
                #changes to speed up render
             ropts["EdgeDisplayMode"]=0
             sopts["DisplayShadows"]=false
          onend{
                #restore render settings.
             @saveROpts.each{|k,v|; Sketchup.active_model.rendering_options[k]=v}
             @saveSOpts.each{|k,v|; Sketchup.active_model.shadow_info[k]=v}
          Original model. http://sketchup.google.com/3dwarehouse/details?mid=3107b3d9c4c935b2b006aed51312d6bb&prevstart=0
            JaViXP
            Thanks, that script will be really helpful 👍
            The bot... Love playing with it! 😆 (I know it's Pecoler's)
            By the way, how do you keep the breakable objects already broken? I mean, they are crashed and the simulation didn't start.
            "Giving up is way harder than trying"
            JaViXP's Rendering
            • W Offline
              Wacov
              Uh... Chris... the Joystick commands don't work. I know you said it's all completely new, but that seems like a step backwards 😕
              You can bridge the gap using global variables, but that's the only way I can find... here's a demo:
              Fixed, hopefully
                phy
                Um, Wacov is the file supposed to not work?
                Okay it works now.
                Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                  phy
                  If you cut the script in box1, and run and reset the simulation, and then paste the script back into box1 it will work, I don't know why.
                    phy
                    Sketchyphysics isn't recognizing @@pos2 for some reason. To see for yourself open ruby console hit the play button.
                    • W Offline
                      Wacov
                      Thanks Phy! Since you pinpointed it, I found the problem. Seems it was trying to use @@pos2 before it had been created, I just had to add it into onstart and it worked fine!
                      • W Offline
                        Wacov
                        Okay, playing around with vectors (another toe in the API pond). Basically, I'm finding them, then changing their length with joystick inputs. I then use them to control the velocity of an object; in this case, the player in an FPS system; this works pretty sweet, so I'll continue to add features, and see where it takes me!
                        EDIT: Fixed. Tell me if it's not 😉
                        FPS Rig1.0.skp
                          Physicsguy1
                          there is an Error. double-clicking wont kick the object.
                            CPhillips
                            I removed double click = kick because it was seldom used and interfering with the new events.
                              CPhillips
                              Here is another useful script. It allows scripts to print text to the screen. In this case a log of whatever touches the floor.
                                 #add blank text to screen at 10,50
                              @@log=SketchyPhysics;;addWatermarkText(10,50,"")
                                 #place to store lines
                              @@lines=[]
                              ontouch{|t,s,p|
                                    #add new line
                                 @@lines.push(t.name+" touched "+self.name)
                                    #ensure only 5 lines on screen at once.
                                 @@lines.shift if @@lines.length>5
                                    #display lines
                                 @@log.text=@@lines.join("\n")
                              onend{
                                 @@log.erase!
                                 @@lines=nil
                              logging.skp
                                JaViXP
                                Very nice script! 👍
                                Can we upload with this version if we don't use the new features? 😉
                                JaViXP's Rendering
                                  Physicsguy1
                                  Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
                                    JaViXP
                                    Nice question, what do you want it for? 😉
                                    Something like this should work (this one doesn't work, just play around with it):
                                    ontouch{|toucher,speed,pos|
                                       if(toucher.name=="box"){
                                          split(self,1)
                                    Hope this helps! 😄
                                    JaViXP's Rendering
                                    • W Offline
                                      Wacov
                                      Any SU ruby would work, ao you might be able to load an external .rb file as an ontick func, or whatever. But you don't need that to do what you're asking, as Jav has shown; and anything that SU can detect can be acted upon.
                                        CPhillips
                                        Hi everyone. Sorry I have been quiet lately. Been taking some time off and enjoying the summer.
                                        I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
                                        Create a good sized cone and put this in its scripted field.
                                        b=copy
                                        b._setEvent("ontick",
                                        <<CODE
                                           push([0,0,1])#go forward
                                           if(frame>50)
                                              destroy #die after 50.
                                        CODE
                                        The cone will copy itself and then set the "ontick" event in the copy.
                                        I tried to make an example that uses "ontouch" but it didnt work for some reason. I will have to debug it.
                                        • N Offline
                                          NorviewsVeteran
                                          Sorry I don't have much to add, but there are a few things. I'm no programmer, I'm on the mechanical team.
                                          1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
                                          1. I needed an excuse to upload the Gopher.
                                          Gopher Armored Car.skp
                                          //This_Is_All(I)+=Know()About.Code;
                                            CPhillips
                                            Nice model!
                                            • 3 / 5
