    Ending a tool
    9 Posts 5 Posters 979 Views 5 Watching
    • Q
      Qverburg
      Hello there ruby scripters,
      Im having difficulties in ending a selfmade tool.
      I would like that the tool returns to the last selected tool after finishing a list of methods.
      It is not really an option for me to rescript the tool to a method.
      Another problem for me is getting to start the list of methods only when 1 component instance (or 1 selection even) is selected, when no of multiple instances are selected it should prompt you to select one instance.
      my code is something like this:
      if $selectie.single_object? == false
      UI.beep
      UI.messagebox("please select only 1 ")
      Sketchup.active_model.selection.clear
      else
      method1
      method2
      But now if not 1 instance is selected it keeps hanging in the tool. How do i fix it to wait untill one thing is clicked and then execute the methods?
      Kind regards,
      Quintus
      • Q
        Qverburg
        Solved it with a Sketchup.send_action("selectSelectionTool:").
        • Chris FullmerC
          Excellent, glad you got it working. It sounded like you were looking for something much complicated than activating the selection tool.
            I end most of my complex tools with that....
            • AdamBA
              AdamB
              I've always used Sketchup.active_model.tools.pop_tool so it returns to whatever you had before rather than forcing the use of SelectionTool.
              Adam
                Adam
                But a lot of plugins end with you perhaps wanting to select something... or if I for example I have made a group you will want to move then I make it the model.selection and invoke the 'Move' tool...
                • AdamBA
                  AdamB
                  @tig said:
                  Adam
                  Never ever ever second guess the user. πŸ˜„
                  • Q
                    Qverburg
                    Well at first I wanted it to be more complex indeed. But i found out that i could do what i wanted by ending the tool with that commando.
                    I had tried the pop tool but didnt get it working. But since you have to select something in order to use my tool selectSelectionTool gives the same result πŸ˜„
                    Thanks for your thoughts though!
                    regards,
                    Quintus
                      Adam
                      Do yo have to use Sketchup.active_model.tools.push_tool to activate the tool then? Because I tried Sketchup.active_model.tools.pop_tool when I had activated the tool using Sketchup.active_model.tools.select_tool - and that did not seem to do anything.
