    [Plugin] Sculpt Tools (help)
    193 Posts 47 Posters 102.3k Views 47 Watching
    • B
      BTM
      Okay, I've got a planar lock working. It's still a bit iffy though.
      v1.0 of Sculpt Tools should be released by friday.
      • mitcorbM
        mitcorb
        Hi, -BTM:
        Man, you've really got that model sliced and diced, judging by the barely visible facets. About what radius is depicted by the brush over the deep crease in png2?
        I am really impressed by your determination. And the way this process is playing out I would say writing ruby scripts is not for the squeamish, at least not for scripts of this magnitude.
        You, sir, have my deep respect!
        mitcorb
        • EarthMoverE
          EarthMover
          Look forward to it BTM! Thanks for all the time you put into this revolutionary script of yours.
          Content Creator at Skapeup
          • majidM
            majid
            dear BTM thanx alot for your great job, you coders are developing the "ability Borders" of sketchup..., I thought that it is now time to also have a "soft selection" tool , like what there is in 3dsMAX, and I guess you are close enough to this point.
            if yes plz add this feature to your set of tools too 😄
            • C
              chango70
              What method do people use to create the initial grid? Is there a Ruby that can do it? I know Subdivide and smooth does it however in this case the surface only need to be divided into squares not triangles.
              • Chris FullmerC
                I use the sandbox tools to make a grid. Or I make a sphere, and I think it does need to be in triangles.
                Have you seen the other thread with the official release? This thread is now outdated.
                • mitcorbM
                  mitcorb
                  chango70:
                  Try the plugin Triangulate by TIG (I believe this is what it is called and the author), then select the geometry and apply Sandbox "Add Detail". This in effect doubles, or subdivides the selection by one "degree". Continue adding detail to suit, but be mindful of Sketchup's low poly tolerance.
                  I have found this to work in the couple of experiments I have done. This is just my experience. I do not have Subdivide and Smooth.
                  Others may use some other methods.
                  • mitcorbM
                    mitcorb
                    By the way, if you were not already aware, Sculpt Tools is now at Version 1.0 with a separate thread, here http://forums.sketchucation.com/viewtopic.php?f=180&t=20781
                    I am guessing any further discussion should occur in that thread. And sorry that the url is not a link. I will figure out how to do that eventually.
                    Edit: nevermind, it turned into a link when I viewed my post.
                    • C
                      chango70
                      Cheers I will check the other thread.
                      • majidM
                        majid
                        how that "lock" feature works?
                        I've tried several times and the result was, 2times of crash, and 2 times "nothing happening".. 😄
                        • romboutR
                          rombout
                          @solo said:
                          With a bit of playing, your code will be able to produce this faster than I did using SDS.
                          http://img19.imageshack.us/img19/982/1solocurtain4.png
                          ehhh sorry SDS???
                          • Chris FullmerC
                            SDS is SubDivide and Smooth by Dale Martens, also known as Whaat on this forum.
                            File Not Found
                            (www.smustard.com)
                            costs $22USD.
                            • romboutR
                              rombout
                              oke chris,
                              thanks for explaining it to me... feel so dumb. Really want this script for a long time and still need to find someone with a credit card which can buy it for me!!! 😞
                              • Chris FullmerC
                                Smustard does take paypal if you have an account with them. They are nice, they will hook up directly to your bank account, so you don't need a credit card at all. And you can also recieve payments from other people via paypal.
                                • L
                                  lapx
                                  Does sculpt tools work with v 8?
                                  • P
                                    popfunky
                                    NEED PLUGIN NOW THANK YOU SO MUCH
                                    • BoxB
                                      http://i155.photobucket.com/albums/s296/storeben/Bike/caps-lock.jpg
                                      • KrisidiousK
                                        Krisidious
                                        Yes, Smustard has always honored my hatred of Paypal with google checkout invoices for products I want.
                                        By: Kristoff Rand
                                        • KrassK
                                          Krass
                                          This post is deleted!
                                          • KrassK
                                            Krass
                                            Thanks a lot, a lot for this plugin ! !
                                            Would it be possible to increase the strength and radius using keyboard shortcuts, rather than having to open the settings window?
                                            It’s not very convenient when using it frequently.
                                            Perhaps this feature is already available?
                                            Thanks.
                                            TIGT 1 Reply Last reply
                                            • 9 / 10
