    Disappearing objects issue
    30 Posts 6 Posters 7.6k Views 6 Watching
      Coronel
      Thank you Jim.
      I think it has to be something related to measures in model as you point. I was probably scaling so far my model to make an interception of two groups that I was getting bad results from.
      Anyway I must say that when it happens to me, the objects disappeared don't return back when the document is reopened and manipulated again; contrary to google team this cause permanent damage to my model so I must be careful when resize it the first time.
      • Chris FullmerC Offline
        If they diapeeared and don't come back, they could have been deleted. There are plenty of ways to inadvertently delete things. Clipping though, is not one of them. So if stuff is being deleted, watch out for that.
        Is it possible that you had hidden it, and then never unhid it? Using "Unhide All" is deceptive as it does not unhide nested objects, for example.
          prismcnd
          I found that the clipping issue can be resolve by switching from perspective view to parallel projection and zooming out then switching back to perspective view
          โ€œWhatever the mind of man can conceive and believe, it can achieve.โ€ -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
            Coronel
            I have again an empty document and the backup I made. I did a try using your method prismcnd but not luck. Even the document size has changed from the original so there is no model to restore.
            This is a terrible bug, it can happen at any moment.
              Its very odd. I've never seen it reported before. Has it happened more than once to you? Could you upload a model where it happened?
                Coronel
                Here it is.
                Was trying to make a base model of winnie pooh planing to try the sculpt tools plugin to pulish it on a final stage.
                There are several versions, some simplified (I started again the model to discard file corruption).
                One of them is empty and you will see another with some parts disappeared.
                You can reproduce the problem using the scale tool for instance and panning the model.
                This is the first time I get this trouble. In the beginning was suspecting on the scale I used to intersect the different groups and then resizing the model again, but when I did the second one the problem persists.
                winnie.skp
                winnie2.skp
                winnie3.skp
                winniebz.skp
                  Coronel
                  Thank you Chris.
                  This is why I clarified that I have some experience now... hahaha
                  I was making some probes and getting the xtrange behavior. Show hidden geometry, unhidding... it was the same. I didn't delete anything, a simple pan or zoom with the mouse and some groups disappeared.
                    mac1
                    @coronel said:
                    Here it is.
                    some obversation => maybe this will help. Ref winnebz.After downloading exploded the group twice to also get the nose, selected all and regrouped. After that could scale and Pan ok, before was getting weird results??
                      Coronel
                      So you get problems without exploding it too?
                      I did what you say and it works, but I need to mantain the nose grouped and this one is already in one group and scaled close to the final size. But if you take a look at "winnie3" you will see that the body is not there, I just intersected one leg, grouped all and suddenly was erased when I tried to scale the entire model.
                      I'm trying to reproduce all the steps I did before it happens but don't see nothing special.
                        Coronel
                        Don't worry if you can't do anything. A friend of mine offered me to solve the problem definetively.
                          mac1
                          My guess at your problem.
                          When I initially download the winnebz model and double click on the group it disappears; if I select all from the tool bar and do a zoom extents nothing shows up but if I do the same under the group sub menu under edit, after select all, I get a strange display. If you do a reset scale at the downloaded group level you get a huge model height of >= 10 million cm. So it appears you have scaled down so far SU can not handle this. If you use the tape tool to scale down form the big dimensions(exploded case) things seem to work ok.
                          Hope this helps and I am not making an error โ“
                            Coronel
                            Ok, it was my first impression but I didn't know how to make the workaround. I was scaling up until the intersection worked.
                            Anyway if SU can't handle it should advert you before doing xtreme transformations, it may be dangerous... Clint could get very hungry.
                            hahahaha
                            ๐Ÿ‘ Thank you mate!
                              mac1
                              hahahaha
                              I rememebr reading about a scale limit in user manual or?? but cannot find it now. I even tried iterative incremental scales by exploding, select all, scaling like .10, regrouping and saving. About three steps the problem comes back so there seems to be some subtle difference between scale and tape re-size that is not clear in the user manual I can find. ๐Ÿ˜
                              Can you clarify scaling up? it looked to me like scaling down was the problem because the posted model has a group box dimension of 75cm while the re-scale value is the very large number??
                                Coronel
                                Yes, it was originally set to 60 or 70 cm but when I tried to make the intersections they failed so I scaled up gradually the model until it worked. Next is when I scaled down the model to the original size again but I didn't use the tape method, just the scale tool, and probably it caused the problem. In the document you say I could get the complete model to 75 cm but in other versions I couldn't or not entirely.
                                It was easier to make the rest of the room of my little son
                                  mac1
                                  For what is worth my search found this on pg 620 of the user manual :
                                  "Use the Scale Tool to re-size and stretch portions of geometry relative to other entities in
                                  your model. Activate the Scale Tool from the Modification Toolbar (Microsoft Windows), the
                                  Tool Palette (Mac OS X) or the Tools menu.
                                  Keyboard Shortcut:S
                                  Note - A Global Scale is an operation whereby the entire model is
                                  scaled simultaneously by applying a desired dimension to the distance
                                  between two points. The Scale Tool is only intended to perform scaling
                                  operations on portions of your model (not the entire model). Use the Tape
                                  Measure Tool's global re-scale functionality to perform global scaling
                                  operations." I don't know what this really means, have posted a question in the help group.
                                  Nice rendering ๐Ÿ˜„
                                    Here is how to do a glbal scale using the tape measure tool.
                                    Measure an object with the heasing tape tool. The side of the desk would be a good object. Lets say it measures as 1.5m. Right as you finsih measuring it, type 15m and hit enter (that is 10 times larger). It will scale everything in the model up by 10 times. That is a global scale.
                                    If you do that inside a group or component, the scaling will only affect the group or component that you are editing, not the entire model.
                                      mac1
                                      Thanks Chris for your effort to respond
                                      I have read page 620 of the user manual and know the tape tool is supposed to be used for global scale and the scale tool for relative scale and know how to use both tools. The question in my mind is this: I can scale a total group using the scale tool and things seem to work fine but, for this problem, that does not seem to be the case. If that is done for this case the cited problem comes up even when it is done in the context of the group ( when I double click on the winnebz model). This model has a nested component ( nose) and if the operation is done after exploding this then you can use the scale tool. Using the scale tool the reset scale menu is active but not if one uses the tape tool so there is a very important but subtle difference that should be throughly explained for the user. After a fairly extensive search for info on scaling pg 620 comment in the user manual was the only remotely relevant comment I could find.
                                      If the group or component I am scaling is the total model then??
                                      I opened a question in the group help to see if someone has further clarification.
                                        Coronel
                                        I agree with you, that's why I was not afraid of using the scale tool in my case.
                                          post removed pending further testing ๐Ÿ˜„
                                            ok, I've been playing with the winniebz-1 model. Its possessed. Definitely something to do with the scale of the model, and the model's internal scale. No way to access that though. It feels like there is a tiny piece of hidden geometry miles away from poohbear, but I never could find anything like that. Perhaps copy and paste him into a clean model might help?
