    Dynamic Component - Seating Platform
    Scheduled Pinned Locked Moved Dynamic Components
    12 Posts 2 Posters 1.9k Views 2 Watching
      Saluki TD
      Hello All,
      I would like to make a dynamic component of a seating riser for my
      theatre. Currently, because there are SO many different platform
      shape / leg height combinations, I have to create a different whole
      component for each iteration. What I'd like to do is have one
      component that I insert into a drawing or copy and then be able to
      specify the leg height.
      These are the four objects I'd like to have in the dynamic component:
      legs - editable
      platform - doesn't need to be edited
      railings - doesn't need to be edited
      chairs - doesn't need to be edited
      I would though, once I insert the DC into the drawing and adjust the
      leg height is to be able to remove one or more railings or chairs.
      I have tried going through the tutorials but am not getting anywhere.
      I'd be happy to share a leg/platform/railing/ chair combination to
      anyone who is interested in taking a look!
      Thanks a ton!
      Pat
      • Chris FullmerC Offline
        Sure Pat, upload an example of what you're thinking of. It sounds like it should be do-able!
          Saluki TD
          Thanks Chris!
          Here is the file. Like I said, The only thing I'd like to have change is the leg height.
          Pat
          leg plat rail chair combo.skp
            OK Pat, I got a version up and running. I've uploaded a model that contains the Dynamic component.
            Select the DC risers, and open the DC options window. And you can set how many legs it should have, and also turn on and off each chair individually and turn on and off the side rails.
            See if that is what you had in mind.
            EDIT: File removed because it was not quite right. A better moedl is posted below.
              Saluki TD
              VERY COOL!
              Toggling the chairs on and off = excellent
              Toggling the right and left rails on and off = fantastic
              Could you make a state for the "rear" rail?
              I am not sure of the correlation between the legs and the height. The platform will always have four legs, I just need to be able to directly specify the overall height of the legs.
              Again, I truly appreciate your willingness to share!
              Pat
                Saluki TD
                I just got to thinking of something you might like to know πŸ˜†
                These are the heights that our risers can be adjusted to: from a low of 4" to a high of 72" in 2 " increments.
                Not sure if this is useful but I thought I'd throw it out there!
                Pat
                  Oh I see, based on the component you posted, I thought that the legs could be added in 18" increments. So adding a leg, just adds 18" to the height.
                  I'll fix it so it goes from as low as 4, up to 72. And I'll make the back rail turn on and off. Maybe by tonight,
                    Saluki TD
                    Thanks Chris...that sounds right!
                    Can I ask, do you have a job that you use sketchup for or is this just a hobby?
                    Thanks again for your generosity!
                    Pat
                      Oh, its both. Its a hobby, but I do get to use it for work a lot. I started using it for school work in landscape architecture, but I'm interested in all sorts of 3d and visualization technologies (but I prefer SU and use it the most, along with the Adobe Suite).
                      So its both. But I do this kind of stuff as a hobby, and to keep me current with the things I don't get to do at work (I have not taken the time to work DC's into my work-workflow yet).
                        ok, I got it done! Hope its more along the lines of what you were thinking,
                        RISERS model.skp
                          Saluki TD
                          Right on man! That is beautiful!
                          Now what I am going to do is start breaking it apart so I can figure out how to do this on my own!
                          Thanks again,
                          Pat
                            Cool, good luck Pat. Let me know if you have questions.
