    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 118.4k Views 21 Watching
      OK, OK... 😎 Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=169956#p169956
      It now has a menu and traps for unsuitable selections...
      I only made it as a quick hack because Chris asked how to triangulate the quad faces of a sphere........................
        Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=169956#p169956
        Burkhard: To add extra detail sub-division to faces use my Advertex+.rb tools - using the appropriate modifier key you can add a vertex onto a face and new edges will then be added up to it from every face-vertex...
        It's a little different from the other script (which I don't recall seeing before) - mine only sub-divides quads - as Chris's request and it also traps for any possible new 'dividing' edges not falling on the face - e.g. with L-shaped or 3nr co-linear-vertex faces...
        B/Chris: It runs by selecting some faces and then typing triangulate in the Ruby-console... To add a menu item you can simply add these lines onto the end of the script using a plain-text editor...
        ### Menu ###
        UI.menu("Plugins").add_item("Triangulate 4-edged Face in Selection"){triangulate}if not file_loaded?(File.basename(__FILE__))
        file_loaded(File.basename(__FILE__))
          Here's v2.0, now new improved - 'triangulates' [almost] everything...
          • Chris FullmerC
            Thanks TIG, this is great!!!
              Here's v2.1, I've renamed the command triangulatefaces(array_of_faces) as 'triangulate' was already a defined command inside delauney/cloud scripts etc, used to triangulate points...
              Please replace earlier versions with this new file to avoid clashes...
                sepo
                Cheers Tig...nice one.
                • C
                  CPhillips
                  Here is the method I use:
                  def triangulateFace(face)
                      ents=Sketchup.active_model.active_entities
                      faces=face.mesh.polygons
                      verts=face.mesh.points
                      faces.each{|f|
                          ents.add_line(verts[f[0].abs-1],verts[f[1].abs-1])
                          ents.add_line(verts[f[1].abs-1],verts[f[2].abs-1])
                          ents.add_line(verts[f[2].abs-1],verts[f[0].abs-1])
                  The nice thing is it cant fail to triangulate regardless of the shape or number of holes. But it unfortunately adds faces to the "holes". Or rather Sketchup does. Does anyone a way to add an edge without Sketchup attempting the "heal" the face?
                    I thought of that approach but abandoned it because of that facing hole problem...
                    • K
                      kwistenbiebel
                      Thank you TIG for this plugin. 👍
                      Do we still need to add those extra lines in the ruby console to get the plugin in a menu?
                      I couldn't find it in the Plugins/Tools menu, thus my question...
                        Do we still need to add those extra lines in the ruby console to get a menu?
                        'Triangulate Faces in Selection' should be in the Plugins menu...
                        • K
                          kwistenbiebel
                          Strange, I can't find it anywhere in my long long plugin list 😳 .
                          Maybe it clashes with some other plugin? (I do have WxSU installed which caused me trouble with other plugins in the past).
                          By the way, I am on SU6 Pro.
                            If you have 2.1 open it in a text editor and read the last bit it should define the menu...
                            • C
                              CPhillips
                              I finally figured out how to triangulate any face without the side effect of filling holes.
                                  mesh=face.mesh(1)
                                  faces=mesh.polygons
                                  verts=mesh.points
                                  uvs=mesh.uvs(true)
                                  outmesh = Geom;;PolygonMesh.new
                                  faces.each{|f|
                                      outmesh.add_polygon(verts[f[0].abs-1],verts[f[1].abs-1],verts[f[2].abs-1])
                                  mat=face.material
                                  face.erase!
                                  grp = ents.add_group
                                  grp.entities.add_faces_from_mesh(outmesh)
                                  grp.entities.each{|e|
                                      if(e.class==Sketchup;;Edge)
                                          e.smooth=false
                                          e.soft=false
                                      elsif(e.class==Sketchup;;Face && mat!=nil)
                                             #handle materials and uvs.
                                          uva=verts.index(e.vertices[0].position)
                                          uvb=verts.index(e.vertices[1].position)
                                          uvc=verts.index(e.vertices[2].position)
                                          e.material=mat
                                          e.position_material(mat,[verts[uva],uvs[uva],verts[uvb],uvs[uvb],verts[uvc],uvs[uvc]],true)
                                  grp.explode
                              • C
                                Coronel
                                Could you please clarify for a 3D newie the purpose of triangulation in this case?
                                Does it means the model will be correct or will work better or is merely a way of get more detail?
                                  If you have a mesh that's rectangular it won't deform consistently. If you triangulate the faces they will... etc.
                                  • C
                                    CPhillips
                                    I needed the triangulation to prepare a model for export.
                                    Thanks for incorporating it into your script TIG! Why is it that back facing UV's didn't work?
                                    • C
                                      CPhillips
                                      There is only a method to 'place material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method...
                                      Do you mean position_material? It takes a bool for front or back material
                                      Error 404 (Not Found)!!1
                                      (code.google.com)
                                      • I
                                        ideas_arte
                                        Thanx really useful!
                                        where download? 😳
                                          Jim
                                          @ideas_arte said:
                                          where download?
                                          That's a valid question; it is not clear which version is the latest, and it is harder than necessary to locate the download.
                                          The download is about 5 posts before this one.
                                            There is only a method to 'position material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method ? ...
                                            • 1 / 5
