    Silvershadow's Eye Candy 3 - H.M.C.S SNOWBERRY
    117 Posts 85 Posters 99.8k Views 85 Watching
      silver_shadow
      i bought this cool plugin, scene exporter, and this allowed me to set up a main model, and the made 3 separate files with portions of the model in. Then imported those scenes, and rendered them. Because it has less information to handle, it did render nicely and quite big, 3000 pixels. So in photoshop, i just opened my 3 renders, put all 3 renders on top of each other and cut it out with the alphas. Is really fast. It does render longer tho, but at least it rendered.
        Ampa
        Utter genius - Congratulations
          john.warburton
          Just staggering. Beautiful work. ๐Ÿ˜ฒ
          Life's a reach, and then you gybe.
            Physicsguy1
            I'm stunned. ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
              mike d
              picks jaw up from floor. ๐Ÿ‘ ๐Ÿ‘
              The grass is always GREENER on the roof.
                You have a French challenger ๐Ÿ˜‰ (scroll to access to the boat) ๐Ÿ˜„
                • majidM Offline
                  majid
                  @urgen said:
                  ....BRAVO
http://img248.imageshack.us/img248/300/appl.gif
                  ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    bahri
                    the first time i look the very detailed model like this...
                    and this is amazed me...
                    i say WOW..... ๐Ÿ˜ฎ
                      accabrera
                      Just...the best! ๐Ÿค“
                      • plot-parisP Offline
                        plot-paris
                        absolutely mindblowing, once again, silvershadow!
                        have been away from the forum for quite a while (involuntarily of course). and now I am back - and here it is, your third, long anticipated Eye Candy! such a incredible amount of detail. stunning. although I also think you can do even better renderings, when going a bit closer, so one can behold the high level of detail...
                        by the way. do you know, when it will be possible do download your models again? do we have to wait until august? or are there maybe some resources left at the scf server, Coen? can't wait to lay my hands on these models
                        • Chris FullmerC Offline
                          I could put it on my ftp. If you are interested silvershadow, I can give you an ftp login. Once uploaded, it has a standard url for download.
                          • majidM Offline
                            majid
                            dear Silvercandy, if you don't bother let me know what is your machine property plz, and how much is the file size? does your machine works smooth with that file and doesn;t jump out or crashes?
                              smokinbakin
                              The detail on this model is simply insane!!!! If you actually textured the rest of that thing, you would definitely need to split it into a thousand layers.
                              "Set your goals low, and hope you don't get lower"
                                Khai
                                what plugin was this? I use the same workflow in other apps so being able to do so in SU....
                                  silver_shadow
                                  i got a pretty slow machine, dual core 3.4 with 2 gig ram and 8600 gt card.Windows 32 bit.
                                  Im gonna upgrade the end of the year to a 8 core yay.
                                  this plugin is a simple plugin you buy at http://www.smustard.com/script/PageExIm
                                  I took my model with everything in it, set up the scenes i would like. Made 3 files for example, and copied the parts into that to make the model smaller. So then i have 3 files all containing parts of the model, and with this plugin i just import my scenes to them. Because its smaller file sizes and less detail, it can be rendered bigger in vray without crashing.
                                  • majidM Offline
                                    majid
                                    thanx for descriptions mate ๐Ÿ˜„
                                    • pbacotP Offline
                                      Is it possible to see these images somewhere else? All I see here is icons saying "bandwidth exceeded".
                                      Thanks, Peter
                                        silver_shadow
                                        we are working on this issue, thanx for the notify.
                                          Thunderaijin
                                          Hello Silver_Shadow
                                          I can not download your files, is there a problem due to your files?
                                          • pbacotP Offline
                                            These are now visible to me, and this deserves a bump! The modeling is incredible and all the images are just beautiful. Just as I expected, but still... congratulations and many thanks for posting, SS. I appreciate the background information and your opening comments.
                                            Peter
                                            • 5 / 6
