    Conponent along path
    7 Posts 4 Posters 409 Views 4 Watching
      Jorgensen
      Does anyone know if there is a script that alow one to add compnents along a path (e.g. bizer curve)?
        410 Gone
        (www.sketchucation.com)
          Jorgensen
          Wow. Thanks thomthom. I wasn't aware of this Sketchucation feature 😄
            RickW
            I hope you found PathCopy in the list 😄
            RickW
            [www.smustard.com](http://www.smustard.com)
              Doh! I meant to link directly to the entry for PathCopy, not just the extension list itself.
              http://www.sketchucation.com/extensions-index/?row=372
                Jorgensen
                hi thomthom, rickw
                yes i found just that one 😄
                • takesh hT Offline
                  takesh h
                  When using complex curves (e.g. bezier curves) as a path, Pathcopy sometimes doesn't do what it's supposed to do.
                  If you see that happening, try the following method;
                  1. Get "Weld" Ruby script (also by RickW) from http://www.smustard.com/script/Weld , drop it in "Plugins" folder.
                  2. Select the entire path, right-click and "explode" or "explode curves".
                  3. Select the entire path again, call up "Weld" from [Plugins] menu.
                  4. When prompted "Close curve?" say yes, and no to "Find faces for this curve?".
                  5. Now you are ready to run Pathcopy script, but don't erase the unwanted connecting edge created by "Weld" until you finish running Pathcopy successfully.
