    !Help - Wireframe Contours to Mesh - Sandbox ?
    6 Posts 3 Posters 1.1k Views 3 Watching
    • H
      haynesc
      Hi there ... i have a problem
      i have 3d contour information from autocad that i would like to turn into a 3d terrain
      can anyone help as my machine keeps crashing
      File:
      https://share.acrobat.com/adc/document.do?docid=2078ccff-de78-4fc4-9480-2d8105bb30ab
        Sir
        i think theres a plugin for this, it may be commericial
        • brodieB
          brodie
          First thing you'll have to do is connect the gaps in your contour lines so they're continuous. Then you can select all of your continuous contour lines and use the "From Contours" tool in the Sandbox toolbar. That will connect them all in a nice smooth fashion.
          -Brodie
          • H
            haynesc
            hey, i managed to get it too work finally .... yes i had to close the gaps in the lines ...
            although i tip i found using adobe illustrator to simplify the contour lines then import them worked well
            • brodieB
              brodie
              how do you import the illustrator lines?
              -brodie
              • H
                haynesc
                my workflow :
                Import cad lines to adobe illustrator ...
                then select all, object/ paths/ simplify ... play with settings
                Export to dxf/dwg from adobe illustrator
                open the new cad file in autocad ... check the scale as it will probably open up in different units, or if you know a particular dimension then you can just scale them once inside sketchup with the tape measure tool
