    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 28.4k Views 12 Watching
      CPhillips
      @phy said:
      Um, CPillips how do you use the breakit command or is it a command. I don't mean the split command by the way. Wacov that's fantastic. 👍
      "breakit" is an internal command called by "split". If you want to break an object into more than 2 pieces use this:
      split(self,2)
      The "2" means split twice, so you'll get 4 pieces. If you use 3 you will get 16 pieces. 4=256. So dont go nuts. Also remember Sketchup will sometimes crash when you split. The more splits the more likely this is to happen.
        CPhillips
        I was going to do an example for split, but it turns out there are some more bugs with it. It wont work in "onstart" for example. use this instead:
        ontick{
           if(frame==1)
              split(self,2)#break into 4 pieces
              ontick{} #disable ontick
          phy
          Okay thanks.
          Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          • W Offline
            Wacov
            Got cloth smoothing working, and made it easier to change the scripting (everything's in the floor). Chris, it seems if there's a script error in onend, objects fail to move back to their starting positions... and it can't be undone 😕 Try sticking jargon in onend, and see for yourself.
            Anyway, the updated cloth!
            Cloth wth smooth faces.skp
              CPhillips
              Thanks. I fixed it.
                CPhillips
                This script is inspired by a new model on 3dwarehouse that ran really smooth... once I turned off shadows and edges.
                Paste this into one objects scripted field. It tries to speed up the rendering by disabling shadows and edges during the simulation. Don't worry if you dont understand it. It should be plug and play.
                onstart{
                      #save current settings
                   ropts=Sketchup.active_model.rendering_options
                   sopts=Sketchup.active_model.shadow_info
                   @saveROpts=ropts.collect{|k,v|[k,v]}
                   @saveSOpts=sopts.collect{|k,v|[k,v]}
                      #changes to speed up render
                   ropts["EdgeDisplayMode"]=0
                   sopts["DisplayShadows"]=false
                onend{
                      #restore render settings.
                   @saveROpts.each{|k,v|; Sketchup.active_model.rendering_options[k]=v}
                   @saveSOpts.each{|k,v|; Sketchup.active_model.shadow_info[k]=v}
                Original model. http://sketchup.google.com/3dwarehouse/details?mid=3107b3d9c4c935b2b006aed51312d6bb&prevstart=0
                  JaViXP
                  Thanks, that script will be really helpful 👍
                  The bot... Love playing with it! 😆 (I know it's Pecoler's)
                  By the way, how do you keep the breakable objects already broken? I mean, they are crashed and the simulation didn't start.
                  "Giving up is way harder than trying"
                  JaViXP's Rendering
                  • W Offline
                    Wacov
                    Uh... Chris... the Joystick commands don't work. I know you said it's all completely new, but that seems like a step backwards 😕
                    You can bridge the gap using global variables, but that's the only way I can find... here's a demo:
                    Fixed, hopefully
                      phy
                      Um, Wacov is the file supposed to not work?
                      Okay it works now.
                        phy
                        If you cut the script in box1, and run and reset the simulation, and then paste the script back into box1 it will work, I don't know why.
                          phy
                          Sketchyphysics isn't recognizing @@pos2 for some reason. To see for yourself open ruby console hit the play button.
                          • W Offline
                            Wacov
                            Thanks Phy! Since you pinpointed it, I found the problem. Seems it was trying to use @@pos2 before it had been created, I just had to add it into onstart and it worked fine!
                            • W Offline
                              Wacov
                              Okay, playing around with vectors (another toe in the API pond). Basically, I'm finding them, then changing their length with joystick inputs. I then use them to control the velocity of an object; in this case, the player in an FPS system; this works pretty sweet, so I'll continue to add features, and see where it takes me!
                              EDIT: Fixed. Tell me if it's not 😉
                              FPS Rig1.0.skp
                                Physicsguy1
                                there is an Error. double-clicking wont kick the object.
                                  CPhillips
                                  I removed double click = kick because it was seldom used and interfering with the new events.
                                    CPhillips
                                    Here is another useful script. It allows scripts to print text to the screen. In this case a log of whatever touches the floor.
                                       #add blank text to screen at 10,50
                                    @@log=SketchyPhysics;;addWatermarkText(10,50,"")
                                       #place to store lines
                                    @@lines=[]
                                    ontouch{|t,s,p|
                                          #add new line
                                       @@lines.push(t.name+" touched "+self.name)
                                          #ensure only 5 lines on screen at once.
                                       @@lines.shift if @@lines.length>5
                                          #display lines
                                       @@log.text=@@lines.join("\n")
                                    onend{
                                       @@log.erase!
                                       @@lines=nil
                                    logging.skp
                                      JaViXP
                                      Very nice script! 👍
                                      Can we upload with this version if we don't use the new features? 😉
                                      JaViXP's Rendering
                                        Physicsguy1
                                        Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
                                          JaViXP
                                          Nice question, what do you want it for? 😉
                                          Something like this should work (this one doesn't work, just play around with it):
                                          ontouch{|toucher,speed,pos|
                                             if(toucher.name=="box"){
                                                split(self,1)
                                          Hope this helps! 😄
                                          JaViXP's Rendering
                                          • W Offline
                                            Wacov
                                            Any SU ruby would work, ao you might be able to load an external .rb file as an ontick func, or whatever. But you don't need that to do what you're asking, as Jav has shown; and anything that SU can detect can be acted upon.
                                            • 3 / 5
