    Question about Microsoft Word
    15 Posts 7 Posters 1.0k Views 7 Watching
      kevsterman
      I've exported it as a PDF and the jpeg doesn't appear greyed out so looks as though I can use that method after all.
      Thanks for your help guys. Much appreciated as always 👍
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
        By the way, why don't you give a try to LayOut? I mean what we have with SU Pro? That's exactly for this kind of job.
          kevsterman
          Word is the only software I have access to where I'm working 😢
            OK, point taken. I used to work in such an office, too. 😒
            • DanielD Offline
              Daniel
              Kevin, depending on which version of WORD you are using, I believe the solution is:
              WORD 2003 and earlier: Create your template and save it (this will be your "template" document), then save it as a second document, which will be your final edited document. On this second document, when you add a page that requires that template, click on the INSERT tab and select FILE, then choose your template file. I've used this a lot in the past.
              WORD 2007 unfortunately will not insert another document file (oh, the humanity!). However, it does have what are called Quick Parts, reuseable pieces of content that can be stored and re-used at any time. Select those items you want saved, save it to the Quick Parts gallery (located on the Insert ribbon), and with one click you can add them to each new page you create. Your inquiry prompted me to learn this and play around with it - seems to work.
              Hope this helps.
              My avatar is an anachronism.
                Charlie__V
                Daniel,
                This piqued my interest as well, and it is possible to insert a word doc 'template"
                Though I would use MS Publisher myself to accomplish this as you can just add duplicate pages.
                To duplicate pages in Word 2007
                While on insert tab:
                1.) Insert blank page
                2.) Insert object…create from file tab
                3.) Browse……”look in” trusted templates
                4.) Select a template and insert.
                5.) Repeat
                Best,
                C
                • DanielD Offline
                  Daniel
                  Charlie,
                  I've tried adding files that way, but from what I can tell it transforms everything into an object, and as such it cannot be edited so easily (the object has to be opened separetly). Also, WORD 2007 will place that object within the current margins, which means it may shrink the object down to fit it within those margins.
                  That's not a problem with the "Quick Parts" - the different elements, wether they be pictures, text boxes, or plain text, remain as such after added and can be edited like any other element.
                  Admittedly, I haven't been using WORD 2007 that long, and it is very different from 3003 and previous versions, so I may be missing something.
                    Charlie__V
                    @daniel said:
                    Charlie,
                    Well....Slap me upside the HEAD! 😳
                    I admit I was hasty about it.......should have been thinking about "Object" insertion....as a clue.
                    Now I am even more puzzled as it would seem you should be able to simply add duplicate pages like you can in MS Publisher.
                    I'll look at the quick parts and what that is about......Thanks............and apologies for the mis-direct.
                    C
                    • DanielD Offline
                      Daniel
                      Charlie, no prob - it's been educational. It seems strange that one cannot directly insert another file in WORD 2007, but I guess they will need something to improve to justify their next version. 😉
                      Edit: it appears you CAN insert text from file in the insert object menu, but it screws up the formatting from the original file, so what good is that?
                      • Jean LemireJ Offline
                        Jean Lemire
                        Hi Kev, hi folks.
                        I see this possibility:
                        1 - Create the required page layout.
                        2 - At the end, Insert a Page Break.
                        3 - Use the command to Show All which shows special characters like Tabs, Paragraph Breaks, Page Breaks, etc.
                        4 - Select all of the page including the Page Break.
                        5 - Copy the selection.
                        6 - Paste as many times as you want to create as many pages as you want.
                        7 - Reset the visibility of special characters.
                        Just ideas.
