    Help...file size to big
    38 Posts 6 Posters 3.7k Views 6 Watching
      meister
      Hi Laura!
      I send for you Private message.
      You can see it on the top of page:control panel.JPG
      meister
        @gaieus said:
        increase compression (find out how to do it in your editor)
        While that decreases the file size - it does not decrease the amount of memory SU must allocate. When it loads the compressed files it needs to decompress it in order to use it. So a 100x100 image will take the same amount of memory no matter how much it's compressed on disk. Some times it might be better NOT to compress it as the images can be loaded directly in without decompressing.
          laura_aut
          @thomthom said:
          Right-click your Desktop
          Choose Properties from the menu
          Then go to the Settings tab and it should say your graphic card name under the monitor image.
          Ooook I found it: ATI Radeon 9200 pro family..... ๐Ÿ˜ณ oh god it's not old..it's jurassic ๐Ÿ˜ฎ
            I got an ATI Radeon 9800 on my old computer at home. Still handles SU very well. Though, I'm not sure the difference between the cards.
            Sketchupis known to have issues with certain ATI cards. And especially older drivers. You could be suffering from a bad driver.
              OK, it may be correct and thanks for that insight, Thom. Yet it would definitely decrease file size which is the basic issue here so that Laura can upload the model to the Warehouse.
              (Compressing for Google Earth can be crucial however but of course that's a whole different issue).
              However decreasing pixel size ("physical" size) of the images - i.e. resizing them - should still help both performance (if the card is crappy) and file size so I'm eagerly awaiting any results from that.
              Edit: I have this model (mae for GE) in the warehouse (please, don't look at the quality of it - it's only a kmz anyway so thank God you cannot download as an skp and criticise it):
              http://sketchup.google.com/3dwarehouse/details?mid=6a240c06f08e3ed1ee286df8eafd81ba
              Anyway, when I finished building the model and texturing, it was about 12-13 Mb. Then I edited the texture images (this workflow is much easier in SU 7) and it went down to 2Mb altogether (still big IMO) without any noticeable quality loss both in SU and GE.
                Ah yes. forgot about that.
                  laura_aut
                  However decreasing pixel size ("physical" size) of the images - i.e. resizing them - should still help both performance (if the card is crappy) and file size so I'm eagerly awaiting any results from that.<
                  I will decrease the pixel size of all the pictures and I hope it works ๐Ÿ˜‰
                  This bedroom took me so much time that it would be a pity to put it aside ๐Ÿ˜„
                    laura_aut
                    So I suppose I should update my graphic card drivers... ๐Ÿ˜ yheeeaaaaa!!!
                    • BurkhardB Offline
                      Burkhard
                      Two months ago I got a model with 118 MB and the client had the same problems. I have had reduced it to 1,36 MB without textures ( If he had let me finished some landscapes, I'm sure it would be under 1MB) Now it is completely finished ( by the client), including the textures and it is not more than 16 MB.
                      Purging and delete unneeded Geometrie reduce the file size only with 4MB.
                      After different steps with deleting textures, copying in a new instance and look for bad Geometrie I had success.
                      The most times I found that there is a lot bad Geometrie that forces Sketchup to long calculations which will multiplied with forthcoming modeling.
                      So, a new Graphiccard is just a short step in relation to a clean way to model.
                      http://www.ia-plus.de
                        laura_aut
                        Ohhhh DONE!! DONE.... DONE!!!
                        You were right, pictures were too big, oh guys thanks...thanks...thanks ๐Ÿ˜„
                        This is what I did: into the SU material menu i saved the pictures into another folder in Jpeg format, than I resized them into paint because they were too big for my model. If you see the model, on the desk there is a picture of a dog, the original one was a 7mpixel picture of 5Mb, an so were the other ones (4 or 2 Mb...too big). In this way I obtained pictures of the size I needed for my components and the right lightness (an average of 25 kb)without loosing quality.
                        This is the link to my model, if you want to criticize it...you can speak freely ๐Ÿ˜„
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                          laura_aut
                          I agree with you, who knows how many mistakes I've done, but I have this kind of problems even if I download any kind of model from the 3d gallery which is more complex...like an house, or a flat, etc.. As I wrote before, SU moves in jerks....even with modells drawn by others. I think this is due to the graphic card ๐Ÿ˜ž
                          If you have some time to waste, I'll be thankful if you could find out if my model has many bad geometries or not....but if you can't don't care about my request.
                          Thanks Laura ๐Ÿ˜„
                            Good to hear that it's worked out.
                            Though, it do sound you can benefit from some better hardware. Maybe a new card is all you need. It really depend in what your Sketchup usage is.
                              laura_aut
                              A new pc would be better ๐Ÿ˜„
                              Unfortunately this is only an hobby..I'm not an architect or a designer and I've never read a SU tutorial, so my usage is an amateur one.
                              Thanks again for your useful advices ๐Ÿ˜„
                                ๐Ÿ‘
                                When I have a little (more) time, I'll definitely download your model and criticise. (I knowthere are still problems in it)
                                ๐Ÿ˜„
                                • BurkhardB Offline
                                  Burkhard
                                  Be sure, I have found a lot.
                                  • 2 / 2
