    • Anmelden
    Rogue's W.I.P's!
    Geplant Angeheftet Gesperrt Verschoben Gallery
    922 Beiträge 55 Kommentatoren 167.1k Aufrufe 55 Watching
    Lade mehr Beiträge
    • Älteste zuerst
    • Neuste zuerst
    • Meiste Stimmen
    Antworten
    • In einem neuen Thema antworten
    Anmelden zum Antworten
    Dieses Thema wurde gelöscht. Nur Nutzer mit entsprechenden Rechten können es sehen.
    • Roguer1R Offline
      Roguer1
      zuletzt editiert von
      Wow Shams, that’s looking really nice. I do appreciate what you’re doing very much 😄
      I just got a newer version of Hypershot, let’s see if it’ll work now
      EDIT: Yay! It works, absolutely no problems so far! But my texturing is a little sh!t
      Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
      1 Antwort Letzte Antwort Antworten Zitieren 0
      • Roguer1R Offline
        Roguer1
        Damn it! Why do my renders turn out crap! Shams, you need to show me all your settings 😉
          BLANK
          I use the "whitestudio" light setup, but I turn off the background. That's about it I guess.
          If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
          • Roguer1R Offline
            Roguer1
            I have tried that method but I think I’m doing the textures or render settings wrong. I have the render settings set to their defaults. Maybe it’s just my cr@p processor that can’t handle rendering. It seems to do the same thing no matter what program I use... 😞
            • Roguer1R Offline
              Roguer1
              A little more work...
                BLANK
                Awesome bonnet!
                I got half the renders up: http://picasaweb.google.com/shamscalade/RogueMilanoWIP
                Some aren't great... That's why I'm doing 16 so you can choose which ones you like and not run out of renders.
                On your comment of the Paramount render, I don't really do anything special. I just use the same lighting setup every time. If the renders turn out fine, I'm lucky. If not, then I just retouch them with Photoshop. The retouches aren't huge, it's just brightening, darkening and blurring. For example, on the Paramount renders, the headlights turned out completely black for some reason. So all I did was lighten it up a bit.
                Just tell me your procedures so I can check if they're similar to mine.
                • Roguer1R Offline
                  Roguer1
                  Those are great renders, thanks Shams!
                  I was really interested in the texture application process. I have all the render settings on their default but I don't really know what to do about the textures. If you could send me some info on what types of textures you use for what ad the levels you set them at. I just seem to get very rough metal and body paints...
                  • W Offline
                    Wacov
                    I've just starting to play around with Indigo. After a few attempts, I've settled with this render, at the max resolution the free version outputs. Finally finished, at 2000SPP! 1hr 30min.
                      BLANK
                      Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
                      You should send me your procedures so I can see what you've done.
                      @wacov said:
                      1hr 30min.
                      Holy s**t! I feel your pain. I thought 8 mins. was far too much...
                        remus
                        If you think 1 hour 30 is bad i recommend you stay away from sss and cauchy b for the moment 😄
                          MrPlanet
                          You should try 45 hours straight with a failed render 💚
                          I reject your reality and substitute my own.
                          • W Offline
                            Wacov
                            Lol, I probably shoulda stopped at 1 hour. But it was still a little grainy 😄
                            I could've done it in under 20 mins at a lower res, but it's just not the same... the time doesn't really bother me anyway, there are other things I can be getting on with. And Indigo's images are so perfect O_O
                              BLANK
                              Eeek, keep your horror stories to yourselves... 😞
                              • Roguer1R Offline
                                Roguer1
                                Lol. 😄
                                Good render btw, very nice!
                                Very similar to my very old renders of my Maverick. I think I used Indigo too.
                                • Roguer1R Offline
                                  Roguer1
                                  Thanks for the render advice Shams.
                                    MrPlanet
                                    Holy **** That looks AWESOME! How much render time was there? If it was under 15min, i will be amazed 😄
                                    • Roguer1R Offline
                                      Roguer1
                                      Here is another
                                        BLANK
                                        Nice! I'm still trying to work out how to make the lights "work", as if they're switched on; no success...
                                        It must be. A similar render (background off; ground reflections on; 1600x1200 res.) took me 7-8 mins.
                                          JaViXP
                                          Those renders are awesome Ben!
                                          "Giving up is way harder than trying"
                                          JaViXP's Rendering
                                          • Roguer1R Offline
                                            Roguer1
                                            Well Shams, your computer was most likely just doing the render. I had quite a lot else going on at the same time as the renders so they took about 50 minutes each. I only have a single core processor so nothing super fast.
                                            Here are more renders
                                            http://picasaweb.google.com/RogueAutomotiveDesign/Other3D
                                            I'm so happy with the results
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 46
                                            • 47
                                            • 19 / 47
                                            • Erster Beitrag
                                              Letzter Beitrag
