    Rogue's W.I.P's!
    922 Posts 55 Posters 247.9k Views 55 Watching
    • Roguer1R Offline
      Roguer1
      Those are great renders, thanks Shams!
      I was really interested in the texture application process. I have all the render settings on their default but I don't really know what to do about the textures. If you could send me some info on what types of textures you use for what ad the levels you set them at. I just seem to get very rough metal and body paints...
      Find all my models on the 3D Warehouse
      • W Offline
        Wacov
        I've just starting to play around with Indigo. After a few attempts, I've settled with this render, at the max resolution the free version outputs. Finally finished, at 2000SPP! 1hr 30min.
          BLANK
          Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
          You should send me your procedures so I can see what you've done.
          @wacov said:
          1hr 30min.
          Holy s**t! I feel your pain. I thought 8 mins. was far too much...
          If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
            remus
            If you think 1 hour 30 is bad i recommend you stay away from sss and cauchy b for the moment ๐Ÿ˜„
              MrPlanet
              You should try 45 hours straight with a failed render ๐Ÿ’š
              I reject your reality and substitute my own.
              • W Offline
                Wacov
                Lol, I probably shoulda stopped at 1 hour. But it was still a little grainy ๐Ÿ˜„
                I could've done it in under 20 mins at a lower res, but it's just not the same... the time doesn't really bother me anyway, there are other things I can be getting on with. And Indigo's images are so perfect O_O
                  BLANK
                  Eeek, keep your horror stories to yourselves... ๐Ÿ˜ž
                  • Roguer1R Offline
                    Roguer1
                    Lol. ๐Ÿ˜„
                    Good render btw, very nice!
                    Very similar to my very old renders of my Maverick. I think I used Indigo too.
                    • Roguer1R Offline
                      Roguer1
                      Thanks for the render advice Shams.
                        MrPlanet
                        Holy **** That looks AWESOME! How much render time was there? If it was under 15min, i will be amazed ๐Ÿ˜„
                        • Roguer1R Offline
                          Roguer1
                          Here is another
                            BLANK
                            Nice! I'm still trying to work out how to make the lights "work", as if they're switched on; no success...
                            It must be. A similar render (background off; ground reflections on; 1600x1200 res.) took me 7-8 mins.
                              JaViXP
                              Those renders are awesome Ben!
                              "Giving up is way harder than trying"
                              JaViXP's Rendering
                              • Roguer1R Offline
                                Roguer1
                                Well Shams, your computer was most likely just doing the render. I had quite a lot else going on at the same time as the renders so they took about 50 minutes each. I only have a single core processor so nothing super fast.
                                Here are more renders
                                http://picasaweb.google.com/RogueAutomotiveDesign/Other3D
                                I'm so happy with the results
                                  BLANK
                                  Sweet renders!
                                  Oh, I see my problem. My pc is actually dual-core. It's just the RAM is below the minumum requirement. Looks like I bought the word "Vista" rather than the computer...
                                  Anyway, the Dorifto Cobra is done. Here's a screenshot of the awesomeness:
                                  Me pulling a Vaughn Gittin Jr. impression. Yes, those captions and smoke DO show up.
                                  The controls are a bit tricky. The controls on the left are inverse (S is forward; W is backward) - it's the only way I guess. I could've removed the controls on the left, but that would leave the car one-speed, thus making it harder to drift. Oh well, have fun.
                                  2009 Trojan Cobra (Dorifto Edition).skp
                                  • Roguer1R Offline
                                    Roguer1
                                    Fun game Shams. Although its a little odd without markers.
                                    Here is a little something people might be interested in:
                                    http://www.youtube.com/watch?v=sKQs9OU-Rig
                                    • Roguer1R Offline
                                      Roguer1
                                      BLAH, I'm soo board!
                                      More renders
                                      http://picasaweb.google.com/RogueAutomotiveDesign/Other3D#
                                      • alexandre skA Offline
                                        alexandre sk
                                        nice models ๐Ÿ˜ฎ
                                          JaViXP
                                          Cool thanks for the video Ben! I finally learnt how to do a good render
                                          JaViXP's Rendering
                                          • Roguer1R Offline
                                            Roguer1
                                            ๐Ÿ‘
                                            I just noticed what Crystal does; it projects whatโ€™s on the other side. I have started using Glass, as I should have XP. I noticed after looking at the render of my Falcon
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 46
                                            • 47
                                            • 20 / 47
