    [Plugin] Skin.rb
    237 Posts 66 Posters 181.2k Views 66 Watching
    • Chris FullmerC Offline
      Looks like April 12th was the last time he logged on. you could try PM'ing him or sending him an email through the forum. That might make it to his home email account if you'd like,
      • ely862meE Offline
        ely862me
        Any possibilities to make skin.rb working inside of groups/components?
        This will be very nice(i usually must copy the geometry outside of the groups and after running the skin taking it back into group or component)..
        Elisei (sketchupper)
        Come and See EliseiDesign
        • H Offline
          hygicell
          the skin.rb plugin is not working at all for me
          I installed the .23 version
          I am working with Sketchup 7.0.10247
          can anyone help?
          is there an alternative?
          frank
            christian_dl
            Hi All,
            I'm new but i think i fixed the MacProblem with Skin.rb
            Because of Sketchup V6 and V7 have no NamedOptions there was this NilObject Problem.
            Here is the latest Code (2.5) with changes to the Option related Sections.
            Should be also running under Windows.
            Best Regards
            skin-25Mac.rb
              christian_dl
              Hi Again,
              Here is the next Version. I call it -26, because it works now within Groups and Components.
              This was a very minor Change frome active_model.entities to active_model.activ_entities.
              Thanks to Thomas Thomassen for his clearly tt_cg2.rb
              Best Regards
              skin-26.rb
              • utilerU Offline
                utiler
                is this latest amendment only a MAC script?
                Just Curious...
                  christian_dl
                  No should be working on Windows too.
                  • mitcorbM Offline
                    mitcorb
                    @christian-dl:
                    Does skin26 have the toolbar icons? And can anyone confirm Windows operability?
                    • ely862meE Offline
                      ely862me
                      mitcorb-The toolbar is the same with previous skin22(or next) ... u need just to replace the skin22.rb(or next) with skin26.rb ..and yes works on windows too(i don t get it he(christian_dl) said clear it works why don t u give it a try huh??)
                      Thanks a bunch christian_dl ..it works very well in groups and components 👍
                      Additional thanks to Thomas Thomassen. 👍
                      Elisei
                      • mitcorbM Offline
                        mitcorb
                        Believe me. It is nothing personal. I had such difficulty before with getting the icons the ruby and the drop down menu entry in one package, I am just not interested in more of the same gymnastics.
                        Best regards,
                        mitcorb
                        • Bob JamesB Offline
                          Bob James
                          skin26.rb on iMac: sooooo useful in ducting construction and all sorts of other things!
                          Many, many thanks,christian_dl (and ThomThom) 👍
                          Also looking forward to Chris' ruby 🎉
                          • W Offline
                            watkins
                            Dear Christian,
                            Your skin-26 doesn't seem to be compatible with the icons for skin22. Only 2 of the 5 icons appear. Could you please produce a folder of icons which are compatible with your script?
                            Regards,
                            Bob
                            • utilerU Offline
                              utiler
                              I agree Bob. The skin ruby icons are the ones i always have trouble with...
                              Just Curious...
                              • mitcorbM Offline
                                mitcorb
                                Something makes me believe that Architectboy is no longer involved with Sketchup, or Ruby. He may have moved on to other interests as he got older. He just didn't resign formally. He certainly showed that he has the talent.
                                If one of the moderators cares to pursue this, I think I know his full name and what region he last resided. I otherwise will respect his privacy.
                                mitcorb
                                  christian_dl
                                  @watkins said:
                                  Dear Christian,
                                  Regards,
                                  Bob
                                  Dear Bob,
                                  As I found out.
                                  The v22 is the only one with a 5 icons Toolbar.
                                  Also in this Version there is no Settingdialog. I think thats the Reason for the 5 Icons.
                                  This Version also works within Groups and Components.
                                  All later Version have a three icons Toolbar and the Settings dialog.
                                  I don't know exactly why the Author of Skin changed this Behavior.
                                  Also he changed back to active_model.entitities. Why ever??
                                  With skin-26.rb i repair only the NamedOptions and changed back to active_model.active_entitities.
                                  Because on OSX, Skin doesn't work at all since v23.
                                  Because i'm not a mathematical genius i don't know very well about changes to the 3D Code.
                                  So If you satiesfied with v22, stay there.
                                  Best Regards
                                  Christian
                                  • utilerU Offline
                                    utiler
                                    good advice, Christian, Ta.
                                    Just Curious...
                                      Bob James
                                      This was done with skin26 on MacPro. There's no smoothing and there's one icon not showing (but it works - preferences). On my iMac at home all three icons show.
                                      The Skin folder has four icons in it.
                                      Settings
                                      • ToboboT Offline
                                        Tobobo
                                        I want to know where to author of the script is?
                                        I hope we have(Edit: n't) scared him off? If i remember he was a young lad. (Maybe)
                                        Dyslexics rule KO!!
                                        Toby
                                        Philippians 4:13
                                          Bob James
                                          This is an older version of the Skin folder that has six icons in it that results in three being shown with skin26.rb.
                                          Note that "Smooth" is unavailable (no other choice).
                                          I might add that it took several tries to get the result shown (all sorts of weird results).
                                            christian_dl
                                            Dear Bob,
                                            Thats the same Result as on my Mac. Should be 6 Icons.
                                            As I found out. The ..L.png's are for Windows. The ..S.png's are for OSX.
                                            The Smoothing Option is not implemented, because the Author promised this for a Version 3. See a Posting in this Thread before.
                                            I compared the Code v22 with v26 and there are a lot of changes to the 3D Routines as well.
                                            It tooks time to re-think (understanding) the Code. On the other Hand it's a good Way learning Ruby. May be any-one-other in this Forum has a brief Knowledge to interpret the Changes.
                                            Regards Christian
                                            • 11
                                            • 12
                                            • 10 / 12
