    [Plugin] Point Merger tools v1.2 UPDATED@ 23/06/09
    68 Posts 20 Posters 47.1k Views 20 Watching
      chango70
      @chango70 said:
      1. I noticed that when I press undo after a point Merge operation it does not undo the entire procedure, rather breaks it down to individual line moves.
      I've got this working properly now, and it will be fixed in the next release for the tools.
      @chango70 said:
      1. I cannot get it to work if the geometry is inside a group.
      I'll try to get that fixed too, but maybe not for the next release.
      @chango70 said:
      Would be great if you can add a CTLR modifier to make the new mesh smooth.
      …I probably won't add this, but if I do decided to, it won't be anytime soon.
      Also as a side note, I'm planning on adding a toolbar for them, and am trying to figure out how to add a subfolder and a loader script. I've got the toolbar working, but not with a subfolder or loader, and having the files just sitting in the plugins folder is a bit annoying.
      Fantastic! I can't wait for the new version. Great work! 😎
      • CadFatherC Offline
        CadFather
        ..haven't tried the script yet so didn't notice there's two... coming soon....
          BTM
          …these are the icons it has right now, I'll wait to see how yours turn out πŸ‘
            CadFather
            i think these are very good BTM - no need of others.. πŸ‘
              BTM
              …I also have these ones though…
              …I'll go with your icons for 'Merge Points', but now for Merge Points to Selection (I changed the name, because it works when selecting faces now aswell), I don't know which one to pick πŸ˜„
              Oh, by the way, they work in groups and components now too. I should have put @model.active_entities instead of @model.entities 😳
              …I've also included a cursor for 'Merge Points'. It's ugly though, so I'm changing it, and I don't know what the new one should look like. 😐
                CadFather
                looking good..
                • Chris FullmerC Offline
                  Keep up the good work! I am repeatedly impressed with your scripting. You've picked up quickly, and seem to keep going. Now you've got toolbars and cursors. Well done!
                  • JClementsJ Offline
                    JClements
                    Thanks for considering my suggestions. I think these two scripts could prove to be "can't do withouts" for people working with terrans/TINs.
                    John
                      BTM
                      V 1.2 is now Up, and includes proper undo, a toolbar, and some other improvements, like the use of the VCB for 'Merge Points', and 'Merge Points to Selection', renamed because it now gets the points/ edges of selected faces now too. πŸ‘
                      • majidM Offline
                        majid
                        just to show my respect : thanx BTM
                          boilingsnow
                          Great! BTM, thank you.
                          Can you make it capable for snaping points such als construction points and lines?
                          • boofredlayB Offline
                            boofredlay
                            BTM, is there a way to have the unzip process work smoother? When I extracted the files I only had two folders in my Plugins menu. I had to grab the two rb files and move them into the main Plugins folder. I believe JClements had the same problem Here
                            Or maybe I did it wrong.
                            Oh, and the toolbar... I noticed it was checked as on but was not on my screen anywhere. I could not use it and ultimately removed the files from my plugins folder.
                            And upon loading SU after installing the script my toolbars wacked out again. Rearranged all over the screen. πŸ˜’
                            Please Google, fix the toolbar prob... oh forget it. They are not listening anymore.
                              BTM
                              That's strange πŸ˜• … First, the unzipped file should be a folder called btm_Point_Merger_Files, and it should contain btm_Point_Merger_Loader.rb and a folder called btm_Point_Merger_Tools. These should both go in the plugins folder. I know that it works fine with Archive Utility on my mac, and the files in btm_Point_Merger_Files should look like this:
                              Both these files should go into the plugins folder.
                              As for your toolbar problem, I have no idea why it would be doing that 😲 . It is possible that another ruby might have broken it, but from what you've described, I doubt it. All I can think of is that the files might not be in the right place, or are duplicated, or that another plugin is breaking it somehow. Other than that, my knowledge is very limited.
                                Macs like to add extra files to everything they do. So when PCs get Mac files, they always come attached with unnecessary files. So your zip files has all this inside it when opened on a PC
                                So its just a matter of deleting the Mac system files, then its like a regular plugin install.
                                  Nope, I take it back. I forgot that is worse than just that. You have to double click on the "btm_Point_Merger_Files" to get taken to the actual root of the zip file. But it still has extra files floating around in it.
                                  So you have to ignore the top level, double click on the "btm_Point_Merger_Files" folder, then delete the Mac system files and then copy and paste the rest into the plugins folder. 😞
                                    BTM
                                    Okay, is there any way for me to make zip files with my mac, that work properly on Windows too?
                                      That is a good question. Does your zip file maker have any settings you can change? If you find anything to tweak, upload a test version here and we'll let you know if it is any smoother.
                                        BTM
                                        … I use the built-in "compress" feature under the right click menu to compress files on my mac. I've been looking through System Preferences, and in quite a few other places, but can't find where to change any settings πŸ˜• .
                                        • V Offline
                                          velvia
                                          thanks for the plugin... πŸ˜‰
                                          i will have a try on it...
                                          My show room :smile:
                                          http://www.velviapersky.com/category/web-design/3d-design/
                                          • jeff hammondJ Offline
                                            fwiw, those extra files are all over the place on your mac but are kept hidden.. they're finder settings and resource forks which are basically used for remembering icon positioning and such (and maybe something to do with why osxSU doesn't have toolbar freakouts).. for instance, you could send me a folder with a bunch of pictures arranged in a certain order and i could see them in that order.. a windows user would see them alphabetically/numerically etc..
                                            the standard compressor will include these files but there are others you can get (for free) that won't include them (pretty much all of the mac archive apps have this option)
                                            [also] if you want to have easier access to the archive utility's preferences by placing them in the system prefs, do this..
                                            go:
                                            Macintosh HD/System/Library/CoreServices
                                            in there you'll see the Archive Utility.app.. you can either launch the app and change it's prefs as you would a normal app -or- unlock a hidden feature by right clicking the icon and choosing 'show package contents'.. go into the contents folder then into the resources folder and you'll see a file called 'Archives.prefPane'.. doubleclick that and you'll be given the option to add it to the standard system preferences..
                                            there's not many options and nothing to keep the mac only files out but you might like some of the choices..
                                            • 3 / 4
