    Can i make off snap for axe ?
    7 Posts 5 Posters 798 Views 5 Watching
    • B
      beauphilippe
      hello it is possible to make off a snap mode (for axe) and use only point snap mode
      In autocad you can choice beetween diffrentes snap mode , with sketchup can choice a diffrent snap mode ?
      Can you know a ruby script for this
      BEST REGARD
      philippe BEAU
        Nope. I'm afraid not.
        As a work around this those cases I temporarily set the model axis to a different angle that won't interfere.
        • B
          beauphilippe
          ok , i know but.....
          if i understand it is not posiible to have choice off mode snapping
          thank
          best regard
          • GaieusG
            No, the only snapping that you can disable (or fine tune) is length snapping and angle snapping at Window > Model info > Units. No other kinds of snapping can be set or disabled. You need to use Thom's workaround or zoom in pretty close to avoid snapping.
            • B
              beauphilippe
              ok , how create ruby srcipt for move axe when you click on key
              ex: i click to f1 and my axe rotate x:30 y:30z:30 and i click again on f1 my axe is reset to last pos
              my problemme is only a for optimise my workflow when is convert my model of quad for export 3d scult software or when i redraw plan
              best regard
              philippe BEAU
              • E
                ericschimel
                You could setup different scenes that have the axis set differently in each scene. If you uncheck all the options for each scene but the model axis, your scene buttons will do nothing except change the model axis.
                -Eric
                http://plugin.sketchthis.net
                Sketchup Kitchen Design Plugin
                Custom Models
                • chrisglasierC
                  chrisglasier
                  Interesting use of scenes - nota benissima
