    Benefit of working with layers in SU
    11 Posts 8 Posters 1.5k Views 8 Watching
      remus
      For this project i think you would definitely benefit from using layers. As you mentioned in point 2, layers will let you hide parts of the model very quickly, in turn this will greatly improve the speed at which you can move around in the file.
      As for a city building workflow, i think the best way to do it would be to have one master file where you block out the whole city. If you then make each building a component, right click it->save as. You can then work on the building in a separate file. When youve finished the building, go back in to the master plan, right click the building you were working on->reload.
      Oh, and with regards to a file size increase when using layers, there is probably a marginal increase, nothing to worry about though, and certainly not enough to outweigh the benefits of using layers.
      • GaieusG
        More or less what Remus says. All the "tricky part" will come when you are in themiddleof it anyway. Some advice:
        • always model on Layer 0 and keep all"primitive" geometry - both undgrouped and what's inside the groups/components - on this layer
        • onlymove whole groups/components on other layers
        • don't even change the active layer (the round radio buttons) other than layer 0 - just play with the visibility (the square checkboxes) of the layers
        • DO use components for anything that will be present more than one instance in the model (THIS will save you filesize and time when editing them)
          Use the V7 for a more speedy Move / Rotation...best management of big file size!
          Don't forget to regulate the automatic save!
          A small time like all 5 minutes can stop for a long time and is very painful if the file is very big! 🤓
          • DavidBoulderD
            DavidBoulder
            Here are a few reasons you may want to use components even for objects that don't appear more than once.
            • you can save the component off to external file to archive various versions or progress models.
            • keep high and low polygon versions of components depending on what you need at the time
            • have multiple people work on model at same time (in separate components) or just for yourself, can work on individual components outside of the main file.
            David Goldwasser
            OpenStudio Developer
            National Renewable Energy Laboratory
            • W
              wiscifi
              That's an eyeopening statement: to model everything in Layer 0...I've never used that layer except for dwg imports and prefer to build models in their named layer and use the "color by layer" feature to make sure everything is placed correctly. If I need to texture and color later, I turn that preference off and "paint the town"
              • GaieusG
                If you don't model on Layer 0 (and leave all primitives there), you will likely to end up with geometry scattered all over different layers. Now imagine you have primitives on one layer maybe even grouped with other primitives on another layer and you want to put your group on a third layer. Soon you will end up with a big mess.
                  mac1
                  See this link, http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/working-with-large-models, 3d basecamp presentation re large models
                  • W
                    wiscifi
                    Gaeius,
                    Interesting re layer 0...
                    I have a possibility of doing a model for a 180,000SF sports medicine facility with three floors. The client only wants the interiors so that donors can see what they might contribute to.
                    On prob I have with scene transistions is that they go through walls..,is there a camera path setting? Or do I need to make many smaller scene variations to control the path?
                    Tx S
                    • GaieusG
                      Camera path settings and animation? There's a whole "chapter" for this in the Ruby Library Depot but also see this topic with some interesting ideas that may be useful.
                      • E
                        elemental
                        erick. A thought on your original post. Even if your windows are 2D flat squares make them coponents. That way you will be able to edit an entire buildings windows (or any other repetivly used geometry) by changing only one. Also, you can use simply constructed components as placemarkers for more elaboratly modeled versions. You can reload the fancy version when they are needed. This will save your CPU for zoom/pan/orbit while modeling the rest of your city.
                        Always always always model on layer0. Move only entire groups to a diferent layer. If you come from AutoCad forget everything you know about layers.
