    Moving faces Solved
    5 Posts 2 Posters 278 Views 2 Watching
    • N Offline
      Navop
      Not sure if that is what u call it. this is what i'm trying to do, not even sure how to explain.
      Trying to raise the skylight 35" with the roof staying in proportions.
      I have attached a pic of what i'm trying to do.
      Did all the rest but not sure on how to do this part.
      thanks
      design
        Don't understand and don't see the image πŸ˜„
        Is that?
        • N Offline
          Navop
          yes that is it, how did you do that?
            Select all the Skylight with for make a box selection with your mouse
            from the left to the right (normal selection = all in this box is selected)
            then take the move bouton (or press key M)
            make any move to the top (following Z axis blue line)
            type 35 on the numeric keyboard
            that all πŸ˜‰
            PS a box selection with your mouse
            from the right to the left (special selection = all that touch this box is selected)
            • N Offline
              Navop
              Thanks for info, it worked
