    Render challenge - water caustics
    35 Posts 19 Posters 14.6k Views 19 Watching
    • soloS Offline
      Hell no, I am hoping to get my grubby hands on the beta next month however.
      The above was Modeled/rendered by Patrick Nieborg, he is the lucky one to have the opertunity to be playing with the alpha.
        Well, Patrick has done enough for Kerky so that he is a steady member of the dev/alpha/beta/minus gamma whatever team over the Aegean (or rather Adriatic) part of the world.
        • brodieB Offline
          brodie
          I'm interested in testing this out myself but in the meantime, here's a Maxwell render (not done by me)
          • majidM Offline
            majid
            interesting.... I've done some renders using KT ( it's start was the topic that is called as "KT under water" ) and then i've tried a detail , using Indigo.... both have real caustics... and also i've mimiced it using v-ray... but at the moment I'm going to re-render an old scene using KT... and soon will upload 😉
            • soloS Offline
              Vue is the only app I know of with real caustics, besides Thea and the new version of Indigo (which are still to be released I believe)
              Here is a simple SU setup that one can use to test caustics:
              http://img268.imageshack.us/img268/9190/lcausticsmodel.jpg
              Simply a water plane, with a ground plane for the refractive caustics to show on and a light source.
              Here is the Vue caustic:
              http://img190.imageshack.us/img190/6205/causticstest.jpg
                remus
                Heres my go in indigo. Taking a while to clear up though, so i'll post a (hopefully) cleaner version in the morning.
                  Out of challenge : Zbrush for the fun 😄
                  • majidM Offline
                    majid
                    real coustics , pure KT (modeling and rendering, both) ,redused noisetrue caustics out of kt
                      remus
                      heres it again after 11 hours.
                        samprocess
                        very cool thread, i'm also want to try some.
                          remus
                          Yeah, just a big volume:
                          Made using jim's randomise TIN script followed by 2 SDSs.
                          • 2 Offline
                            21D
                            this is my try....it's a simple box, with a flat rect. geo.
                            sent to modo401....textured and rendered
                            Modo 401 handels CAUSTICS now
                            screengrab for some SPECS
                            "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                            Le Corbusier
                            • soloS Offline
                              Excellent Modo 401 show piece, so how is the new Modo so far?
                              Here is a faked caustic I did in December 2006, using Podium version 1.0.
                              http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
                                sepo
                                This brings some memories 😄
                                • 2 Offline
                                  21D
                                  Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
                                  as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
                                  but all in all, amazing.
                                  it's a bit more aimed now for archvis with all the presets that can be used,
                                  i am definitly going to learn how to use it, so i can add it to my archvis workflow.
                                  Le Corbusier
                                  • majidM Offline
                                    majid
                                    congrats Solo... it is an art work, out of podium!!! 👍
                                    • daleD Offline
                                      dale
                                      Well not totally satisfied yet, but though I'd post the progression.
                                      Kerkythea
                                      Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
                                      Rendered with Preset 09 Photon Caustics Medium
                                      • majidM Offline
                                        majid
                                        Kerkythea
                                        if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
                                        http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
                                        also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
                                        also u may have your camera , just below water surface 😉 ( give it a try 👍 )
                                        • RichardR Offline
                                          Richard
                                          Hey those modo images are amazing!
                                          Maxwell - faked!
                                          http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
                                          http://img177.imageshack.us/img177/3204/70225399bt6.jpg
                                          Maxwell night - faked! 5 min test render! Needed longer!
                                          http://img185.imageshack.us/img185/485/pooltq6.jpg
                                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                          • majidM Offline
                                            majid
                                            here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
                                            from below water view
                                            • 2 / 2
