    Render this: Stained glass
    66 Posts 27 Posters 30.2k Views 27 Watching
    • soloS
      I like the Artlantis one best, good start Mr WIP.
      • olisheaO
        olishea
        yeah the artlantis one looks great, is it easy to use?
        oli
        • T
          trillium
          hi solo, i can't believe you just posted this! 😍 for the last 2 weeks i've been thinking about posting a question for YOU on this topic! i' working on a design that two of the spaces is totally about the stained glass window. right now i'm just about to finish the house & site, interiors come next. i will post mine in 3 weeks (if it looks right!)
          hi MrWip, that looks great!! please post more!
          i have a question for you- is the glass panel made of several faces in sketchup or is it one face with transparent image? the reason i'm asking is that my tests showed that when it's different faces for different colors, podium can work too, but if it'a transparent texture or image the shadows don't have colors in podium and artlantis is able to produce colored light. but if the design is intricate, and not a cad file, it will be a lot of work to trace it on a face... thanks again!! ☀
          • daleD
            dale
            Off to a great start Mr Wip.
              MrWip
              Thanks you all for all your positive comments, It's really good to share with a community!
              So, about the render, here is the trick:
              -The glass is made of one high resol pict of a Stained glass.
              -The structure have been redraw over it to have a solid element casting shadows.
              -Vray does not cast automatically good caustics, or colored shadows linked to the color of the texture...
              -On the other hand Artlantis does, so I've switch to it, and after a bit of photoshop adjustment it gives this. (actually Artlantis 2 present some graphic bugs with complexe interactions, like a smooth "caustic" shadows on a reflective surface with bump for instance... so photoshop is necessary in that case)
              And, Oli, yes, it's really easy to get a grip on it. If you want to take a look, I've made a first tutorial of the basis here : http://forums.sketchucation.com/viewtopic.php?f=18&t=19361
              My technic does not work for unbiased renderer (at least not with indigo ) and I will have to separate and texturize each peace of glass if I want to get something out of it...
              http://www.wip-archi.com
              • soloS
                Quick first try, need to tweak a few settings still.
                SU and Vue (no post editing)
                http://img41.imageshack.us/img41/1636/stainglasstest.jpg
                Used a volumetric quadratic spot with dust enabled, low radiosity atmosphere.
                • arail1A
                  arail1
                  MrWip -
                  I wonder if there is a way to combine the two. The walls and floor are beautiful in the V-Ray version but the light on the walls and the window sill is more convincing in the Artlantis version.
                  Whatever, you've sure set the bar pretty high! Beautiful work.
                    dylan
                    Mr Wip, apart from great looking stained glass, the roof and wall textures are fantastic!
                    Where are they from?
                    Being a rendering noob, tell me, is this texture added in SU then rendered in your software?
                    http://dmdarchitecture.co.uk/
                    • olisheaO
                      olishea
                      WIP: nice tutorial, thanks a lot 👍 . think ill have a go with artlantis first then vray.
                      oli
                        MrWip
                        Ok, now let's try to improve the effect...
                        I modified the glass panel, applying a single texture to each element, making it able to be taken into consideration by other render engine.
                        I'done two test in Indigo, and here are the raw images, whithout any post process. I took about 20 minutes on an octocore to get that result (resol 1822x1031 originally).
                        First : same configuration of element than before...the caustics look a bit the same than in Artlantis.
                        Skp + Indigo
                        Second : I've increase radically the thickness of the glass (around 10cm on this one). The resulting lighting is interesting to observe...The caustics are far more effective, and some glass element are no longer transparent due to the too important thickness.
                        Skp + Indigo
                        Now I've to figure out why indigo just show the color and not the texture of my glass panels...
                        -- Dylan, the ceiling and wall are simple CGtextures images, apply has a texture, with a bump. Here is the pure skp image, so you can see how it looks without effects
                        Skp
                        • AdamBA
                          AdamB
                          Damn these displacement activities! 😄
                          Attempt using LightUp. (Lighting time: 11 seconds)
                          SU + LightUp, using sunlight, no post
                          • olisheaO
                            olishea
                            whats the difference between artlantis studio and artlantis render?
                            also do you have to have sketchup pro or will free version work (mac)
                            oli
                              dylan
                                MrWip
                                Oli, The Studio edition include animation tools that the render does not have, that's the only difference... so if you just want to make pictures you don't need the studio.
                                Adam, here is a try for you (the other one can also enjoy, of course!). It took about 1 minute with a 10x resolution, and the result is a simple screen grab without postprocess (appart from the watermark...) so, it's fully real time, as you like to precise 😄 (and you're right to do so!)... You can check the raw sketchup on the post above to see the lightup efficiency on that scene (the 'caustics' are a bit weak, but the overall sensation is really close to a real render)
                                Skp + LU
                                • AdamBA
                                  AdamB
                                  Whoa. Nice result!
                                  And such an elegant model too.
                                  BTW The next version of LU has a slightly different sunlight model which results in much bolder caustics.
                                  • T
                                    trillium
                                    solo, that's beautiful!! how did you get the shafts of colored light? have you tried to do this in Podium also
                                    • T
                                      trillium
                                      MrWip,
                                      i really like your new group of renders! especially the one where you increased the thickness of the glass! how can glass thickness be done in artlantis? or did you do that in SU? thanks!
                                        MrWip
                                        Trillium, if you take a closer look to the post, it was not done with Atl, but with indigo, an unbiased render.
                                        Artlantis does not take the glass thickness in consideration, but you can play with the index of refraction of the shader itself, and change is nature (airs, glass, plastic...). That should affect the resulting shadows...
                                        • B
                                          bubbalove
                                          Here is my half-ass attempt. I could've continued to get better results but I got lazy and quit trying. It was done in Kerky...
                                          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                          • E
                                            Eulgrand
                                            Rendered in Kerkythea
                                            Preset 20 - MLT (BPT), 30 passes.
                                            Noise removed with NeatImage
                                            Lit by the sun and an HDR global.
                                            Just added some procedural Perlin noise as bump map, on an image grabbed on the net. The glass has 5mm thickness, IoR 1.52
                                            • 1 / 4
