[Plugin] Model Scrambler v1.0 UPDATED: (June 11, 2009)
22 Posts 9 Posters 18.0k Views
    BTM
    Before...
    After... (with softening)
    Before...
    After! (with softening)
    Version: 1.0
    Use: Rotates groups and Components slightly, explodes them, purges unused components, then takes all faces and reverses random ones, painting them as they were. each event can be turned on/off when the script is selected.
    UPDATE June 11, 2009:
    It is now able to explode all curves, and moves random points or all points by random vectors, based on a value input by the user, which dictates maximum distance in all directions ( I use 0.0001m).
    Description: It's meant as a way to scramble a model, to make it harder to edit. There are other uses too though.
    Things I'm trying to fix are:
    •To get all the text to appear in the inputbox.
    •To change the part that takes groups and components and rotates them slightly, so that it rotates them around the center of the bounding box, instead of the axes.
    •To soften all new lines made by the point scattering part.
    •... Suggestions?
    btm_Model_Scramble.rb
      Ha, that's great! Glad you got it working, and that's a great first plugin release, congratulations!
        bianhai
        Thank you very mach! 👍
          BTM
          I finally figured out how to get the last part working, and now it can scramble your models a whole lot more!
          ... I'm still looking for Ideas to add more features, as-well as reports of anyone who's having problems with it.
            http://code.google.com/apis/sketchup/docs/ourdoc/boundingbox.html#center ?
            ...I hope noone at my office gets hold of this script... smells evil...
              BTM
              I know about the group.bounds.center method, my biggest issue is how to rotate it around the center. I've tried a lot of times, and every time I fail miserably. 😞
                ` group = the group you want to transform
                group.transformation.zaxis #this gets the z axis for the group
                angle = rand()
                point = group.bounds.center
                t = Geom::Transformation.rotation point, vector, angle
                group.transform! t`
                That should do it more or less. Unless I've got some typos. And use rand90 however you would like. You could even randomize the vector. I just used the blue axis so it will rotate around that.
                  BTM
                  Thanks Chris; I'll try that 👍
                  ... I also (accidentally) found out another use for scattering points 💚
                  It looks like a crumpled can, doesn't it?
                  ... I'm now thinking of maybe putting in the option to either scramble selected objects, as-well as all entities...
                    Awesome, looks great! That's the way to do it, just keep adding features and simple scripts quickly can become very powerful.
                      Ben Ritter
                      No offense, but I can't see how and for what purpose would you would use this script? ☀
                        Ben Ritter
                        Whew! I thought I was missing something in your description. 💭
                        Thanks for the script, I guess 😉
                        Ben
                          BTM
                          ... And that's the evil part! 👿
                          There is (almost) no (constructive) use!
                          One reason would be if you wanted to send a model to someone to see how it looks, without them being able to use it at all; see link.
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=18227&st
                          ... Another could be for fun... 👿
                          ... Or using the scramble effect on objects to make things like water, rocks, clouds, or other randomly shaped objects...
                          ...or using it (minus the reverse faces) to make models appear old/ worn...
                            remus
                            Browsing through your code: you might want to change require "Sketchup.rb" to require "sketchup.rb" (no capital letter.)
                            You get a double entry for the ruby console otherwise.
                              BTM
                              I'll make sure to do that in the next version, remus. 👍
                              ... Also, in order for it to work properly for selections, I'd have to find a way to select the entities in a component after exploding it. I've found a way to do it with groups, but not components. 😕 Any ideas?
                                jcc
                                This post is almost a year old, but I'm hopeful that BTM is still working on this idea. I'm looking fo ra routine/script that will lock/secure the model from changes, but NOT from being viewed by a client.
                                Also need to allow clients to: display grade elevations with the "query" tool, and see saved views "scenes/pages".
                                Any help would be super.
                                Thanks,
                                mojo
                                  Hey Mojo, actually this thread is just a few days old, not a year. So you are right on time for the party.
                                  However, the problem with a script that keeps the client from changing anything - well all they would have to do is uninstall the script. Or more likely, never install it in the first place. There is no way to build that tpye of functionality into a model itself unfortunately.
                                  But this is exactly the type of conversation that spawned the script. Remus wanted something that would just mess up every vertex in the model so nothing would be accurate, thereby making it nearly impossible to build off of or steal.
                                  PS, I'm just through the tunnel in Berkeley.
                                    BTM
                                    … You sure? I remember once that CPhillips was going to try and embed sound files into skp files, maybe it's possible with ruby scripts. I'd have no Idea myself though, but you never know…
                                      You can store an script in an dictionary attribute, but it'd never trigger unless you have another script that executes it.
                                        MrPlanet
                                        In which menu is the option?
                                        I reject your reality and substitute my own.
                                          jcc
                                          I been off on other projects since June, and thought Id just see the status of the Scrambler. Any news?
                                          Sounds like it may develop into a kind of PGP, where the model is scrambled at the source before sending, and the Un-Scrambler, being embedded in the model, is triggered somehow. But I may be over-reaching -- is there such a thing as an Un-Scrambler?
                                          At any rate, what I was looking for originally, was some sort of lock to put on the model, to: 1) prevent changes by others, and 2) therefore to create a sort of brute force copyright.
                                          And another thang, Does anyone have any experience with adobe PDF in 3D? could that be a solution...
