    Ruby download
    31 Posts 9 Posters 4.1k Views 9 Watching
      Also note that a zip file has a name and that name is practically a folder name so Windows will (if automatically) unzip everything in a new folder named as the zip file instead of putting everything (incuding the rb file and subfolders) straight under the main Plugins directory. Make sure this doesn't happen.
      One version of windowizer at least goes into the contet (right click) menu if you cannot find it after proper installation.
      • Jean LemireJ Offline
        Jean Lemire
        Hi Rod, hi folks.
        Also, some Ruby scripts are treated as extensions, they need to be activated using the Extensions control pannel, like the Sandbox Tools, for example.
        Use Menu Window --> Preferences --> Extensions. Verify if there is an entry for Windowiser. If so, make sure that the checkbox next to it is checked.
        Close the window and, to be sure, quit SU and restart it.
        Just ideas.
          August
          @jean lemire said:
          ... some Ruby scripts ... need to be activated using the Extensions control pannel, like the Sandbox Tools, for example.
          Use Menu Window --> Preferences --> Extensions. Verify if there is an entry for Windowiser. ...
          Hi Jean,
          I just checked, and Windowizer (v3, the one I have) does not use the Extensions mechanism. That is done using Sketchup.register_extension which uses an object created by SketchupExtension.new which takes a title string and a path.
          Does anyone happen to know of any plugins, other than those that Google ships with the installation, that use the Extensions mechanism? I've been searching and have only found references like this one, that are more theoretical than practical.
          Thanks,
          August
          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
            Jim
            August,
            there are numerous plugins that use it, are you looking for an example? I know some of Chris Fullmer's tools use it.
              The following are listed under my Extensions tab in Preferences (apart from the original SU extensions):
              • shape bender (Chris Fullmer)
              • subdivide and smooth (Dale Martens)
              • free scale (Fredo) (oops, BTW it's now called "Fredo Scale")
              • soap skin and bubble (Josef Leibinger)
                remus
                A couple more to add to the list:
                -profile builder (whaat)
                -lightup (AdamB)
                  August
                  @jim said:
                  ... are you looking for an example? I know some of Chris Fullmer's tools use it.
                  Yes, I am looking for examples. Thanks.
                  I just received a list from Chris in another thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=19345.
                  @remus said:
                  • profile builder (whaat)
                  • lightup (AdamB)
                    Thank you both.
                  I also just found:
                  • Custom Toolbars (Jim Foltz)
                  I think I have enough examples now. I was initially having a very hard time finding any scripts that used it; randomly downloading my way through 678 scripts in the Extensions Index was not working and the only references I found in forum discussions were oblique references like the one earlier in this thread.
                  I'm writing an article on how to use the Registered Extensions system as a tutorial for Ruby beginners and I want to specifically mention developers and/or scripts who/which already use it.
                  And my apologies for hijacking the thread.
                  Thanks again,
                  August
                    Jim
                    And don't forget about Google's own Sandbox tools and Dynamic Components.
                      Then the ocean modelling tool (new to M1 of SU 7), utilities and one other I'm too lazy now to look up should also be counted.
                      • Chris FullmerC Offline
                        I think he is interested in who outside of Google is taking advantage of this feature - especially since it is relatively easy to write into a ruby script.
                        I'm curious if people ever disable extensions using the extensions enable/disable window?
                          Jim
                          I'm curious if the Extensions dialog will still be usable and easy-to-use if there were, let's say 25 or more extensions in there.
                            Exactly, thats another great question! It probably becomes just as unwieldly as the plugins menu does. If every plugin installs itself there, that could be rather tedious to work with.
                            But then again, if you're just turning some things on and off occasionally to keep the plugins menu clean and tidy, maybe its a good trade-off?
                            • Al HartA Offline
                              Al Hart
                              What is the effect of the second parameter (true/false) in Sketchup.register_extension
                              [edit]It looks like the .rb file gets loaded whether true or false is set.
                              Al Hart
                              IRender nXt from Render Plus
                                August
                                I found this page of doc:
                                http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#register_extension
                                which includes this section:
                                Sketchup.register_extension doc
                                Here's the text from that image (so that it is searchable), formatted as best as my experience with SCF will allow:
                                Sketchup.register_extensionSketchUp [6.0+]
                                The register_extension method is used to register an extension with SketchUp's extension manager (in SketchUp preferences).
                                Arguments:
                                • extension -- A SketchupExtension object.
                                • registered -- true if extension should be automatically
                                  loaded the first time it is registered.
                                Returns:
                                • status -- true if extension registered properly
                                utilitiesExtension = SketchupExtension.new "Utilities Tools",
                                  "Utilities/utilitiesTools.rb"
                                utilitiesExtension.description = "Adds Tools->Utilities to the " +
                                  "SketchUp inteface. The Utilities submenu contains two tools; " +
                                  "Create Face and Query Tool."
                                Sketchup.register_extension utilitiesExtension, false
                                That formatting is way too much trouble. Code boxes should be wider so it will display readably and there really should be some way of indenting, creating lists bullets, etc.
                                ANYBODY know of any doc for formatting SCF posts that goes beyond the buttons at the top of the text entry window?
                                I hope this helps,
                                August
                                  The SCF uses BBCode. When you are replying, over on the right, under all the smileys, there is a small section with this:
                                  BBCode is ON
                                  [img] is ON
                                  [flash] is ON
                                  [url] is ON
                                  Smilies are ON
                                  and the BBCode is a link to this:
                                  http://forums.sketchucation.com/faq.php?mode=bbcode
                                  So when you are posting, you can use that as a aguide to help with formatting.
                                    mirami
                                    Hi!
                                    I have loaded the soap bubble skin from tensil structure.de but cannot open it.. I am using Vista and SU6.
                                    I unzip the files as mentionned , I create C>program>google>su6>tools but get a message telling me the file cannot be created, immposible to open... I tried to unzip on the desktop, copied the files in su6, this worked fine. But np new toolbar in SU6 at all.. I tried to take away the anti virus and firewall, ,no results..
                                    Has anyone got this problem before ?
                                    Thanks a lot
                                      Hi Mirami,
                                      Even if successfully installed (you may have administration right issues with this on Vista), SSB needs to be activated from the Window > Preferences > Extensions tab. Also, you may need to activate the toolbar itself from View > Toolbars.
                                        mirami
                                        Hello!
                                        Well, could you be so kind to refresh my memory and explain me how to go in window>preference and what you excatly do one you are there ?
                                        In SU toolbar all is apparently activated..
                                        Thanks a lot
                                          See attached (I don't have it installed at the moment but it should be there)
                                            mirami
                                            ok you was right , both utility tools and sand box were not activated. There are now activated, I have got the sand box icons on the screen but nothing regarding SSB still!! I have redone the whole installation but still get the same message, it cannot create the path...
