    Size of files...
    4 Posts 3 Posters 499 Views 3 Watching
      bouillet
      Hi!
      I have a little problem of size in Sketchup:
      I have created a campus, with about 20 buildings, and the size of the file campus.skp is nearly 13Mb.
      Then, I want to put each building in one file, so I delete all the campus except the building I want to keep, I save as building.skp, but the size of the file is approximately 11Mb!
      Is there a way to obtain smaller files?
      Thank you very much
      Regards
        Hi Bouillet,
        Simply deleting parts of your model from the scene won't delete those parts (+materials, styles,layers whatnot) from the file, too.
        Most of what's listed above, you can "purge" from their respective browsers (like the component browser) but to make it simple, go to Window > Model info > Statistics and at the bottom, find the "Purge all" button.
          Maybe Menu Windows/Layers/Purge ?
            bouillet
            Thank you ! It works fine! πŸŽ‰
