    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 92.2k Views 23 Watching
    • Chris FullmerC
      I think that error was already reported and fixed. Try re-downloading and installing it. Let me know if that does not work,
        mpowell1234567890
        I Tried re-downloading and installing it. I got the following errors:
        City Gen Module Error.
        Street Gen Path Error.
          Did you place it in the correct folder? It's going into the "Plugins\City_Gen" folder, not "Plugins".
          • Chris FullmerC
            So now its letting you know that you've got it installed in the wrong spot.
            put the city_gen.rb file in the plugins folder, then there should be a folder called City_Gen and the street file should go in there.
            This is project is in the VERY easrly development phases, so its buggy and not well organized. And its only going to get worse as we keep adding to it. Just a warning.
              mpowell1234567890
              Yes..
                And there isn't a copy left in the plugins folder?
                Is the Core file also updated?
                btw: are you on a mac?
                • B
                  beauphilippe
                  ok great , idea
                  i have to iterrest to help for project but iam not coder
                  i propose my help for test your module and make feedback
                  best regard
                  philippe BEAU
                    mpowell1234567890
                    I have an HP with Microsoft Windows Vista Home Premium 64-bit.
                    I finally figured it out, took a while. But, finally got it to work when putting the files in the correct place. I must of had it in reversed. Is this normal, I applied the street generator to the lines, I noticed that it left behind hidden geometry on each corner to where it bends, is that normal? I was checking. Thanks.
                      Yes. That's currently by design. it generates a road segment per edge. So if have two connected edges. and run the Make Street command on each of them separately, it'll still work.
                        mpowell1234567890
                        Cool. Thanks. ☀
                          rv1974
                          Hi Thomthom! Very powerfull tool indeed- I started to use it for handrailings and curtain walls 🙂
                          2 things:
                          1/ Could your baby keep last entered values (even more: to remember after the file is closed)?
                          2/ Are st.Andrew crosses unavoidable?
                          P.S. 2 threads about the same plug-in (with inner interchangeable links) is extremly confusing thing 👊
                            Yes. That's coming.
                            It is not the same plugin. CityGen is a collaboration project. Remus and Chris is working on modules to create buildings. I'm working on the module to create streets. All these modules need this 'core' file to load.
                            So actually, anything that relates to the street generator, should be posted in that thread.
                            This thread is intended for the core file.
                            Since this is a Work In Progress, we're in the very early alpha stages - testing ideas, things will be a wee bit messy. Once things start shaping up, we'll be able to organize these threads better and make packages that include all the modules for easier installation. So until this project reaches that stage, things will be in flux. And there will be things missing. It's probably worth skimming through the pages of replies to get an overview.
                              rv1974
                              I meant diagonal lines on crossroads. St. Andrew was crucified on X shaped cross. Now it's on the scottish and russian navy flags for example.
                                I had been thinking of a cleanup option. But I'll have to see how this fit in with the rest of the modules. We might end up needing them lines for further processing.
                                • B
                                  bianhai
                                  Nice plugin, Thanks!
                                    Can we make the Core and modules sticky so they always have their fixed position at the top? Preferable with the Core at the very top.
                                      remus
                                      Done, but i think the order depends on what has the most recent posts, so can't help there.
                                        Looks like it.
                                        Would it be possible for me to get some elevated access to this sub-section of the forum?
                                          remus
                                          Send Gai a PM. I cant imagine there would be a problem with it.
                                            Uploaded a new version to support StreetGen 0.5.x
                                            • 2 / 6
