    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 216.4k Views 65 Watching
    • broomstickB
      broomstick
      Chris, I never got to thank you for this script. It is a time and life saver when fast modeling stair railings!!!!
        driven
        Hi Chris
        the link appears to be broken, I've downloaded a couple of your others before and after getting "you do not have permission"
        html instead of this file, I'll try again next session, but it may need re-posting from your end.
        It looks great, and I do like your videos...
        • Chris FullmerC
          Hi John, the link is good. There have been reports of some people have issues downloading files from the sketchucation forum. I don't know if aynone has ever figured out what causes the error though. Please try to download it again. If it still is not working, let me know and I'll upload it to another place where you could download it. Just let me know either way,
            driven
            Hi Chris,
            Came down this session on second attempt (using a different download manager)... No idea why...
            This site may have Safari issues, Auto Login doesn't always work, and tab browsing seems to have me logged in at one page, but not another.
            It's not consistent so I can't quite figure out what's happening...
            I'll try these plugins now
            cheers
            John
            • kenK
              ken
              I noticed that “Perpendicular Face Tools” (PFT) will make squares that are in factions of an inch, such as 10 1/4" per side, however the circle tool always seems to round off, 10 1/4” becomes a 10” radius.
              Was this intentional, or is it an error with my computer?
              Would be nice if the circle tool would operate with factional inches.
              Thanks for all you plugins.
              Ken
              • Chris FullmerC
                Interesting, thats a good catch Ken. I tihnk its a bug.
                Also Ken, I am remembering you said you had two "Chris Fullmer Tools" menus. Is that still the case? And if so, do you mind listing what plugins are in each? I'd like to fix all that at some point.
                • kenK
                  ken
                  Thanks for remembering. However, it has changed from the original. It went to one menu item during one of your scripts install to now again two menu items. I have just learned to live with it.
                  Here are the two menu items as of now.
                  First Chris Fullmer Tools
                  1. Center on origin
                  2. Shape Bender
                  Second Chris Fullmer Tools – Well I’ll be darned, I have two Shape Benders. I never noticed that there was a duplicate menu item.
                  1. Components onto Face
                  2. Label Open Edges
                  3. Scale & Rotate
                  4. Select Lines by Length
                  5. Shape Bender
                  6. Loose Geometry to Groups
                  7. Perpendicular Face Tool
                  8. Line Tool
                  9. Arc Center Finder
                  10. Simple Loft
                  11. Extended Standard View
                  Also, Chris thanks for the tip on how to arrange menu items by adjusting you window size. So far it works great.
                    Suggestion (but seems very useful) 😉
                    perpendicular face tool with selection of some lines !
                    So no need to click line after line!!! 😎
                    • Chris FullmerC
                      I like that idea. That is one to implement on the next round. I'd also like to have better support for perpendicular lines coming off of simple arcs and circles.
                      I realy need a feature request tracker so that I have them all together for when I get ready to re-write some of these scripts! THanks for the great suggestions everyone, on all my scripts.
                      • P
                        publied
                        nice job! very useful plugin. thank you.
                        hire me@ http://www.publied.it !
                        • utilerU
                          utiler
                          Hi Chris, another idea....
                          Have you considered adding components and groups to this tool? as with your custom face tool, another option that I think people would find 'components perpendicular; tool handy....
                          Maybe another tool though as this is a 'perpendicular face' tool after all.
                          Cheers,
                          Just Curious...
                          • EdsonE
                            Edson
                            chris,
                            i have downloaded the latest version posted above and am having a number of problems:
                            1. on the text it says 1.1 not 1.2. could you have posted the wrong script?
                            2. the custom shape does not explode after it is placed;
                            3. all the faces get oriented parallel to the red axis;
                            4. control does not work as described;
                            5. the up arrow does not work as described.
                            i am on mac. could there be some incompatibility?
                            http://www.mahfuz.arq.br
                            • Chris FullmerC
                              Hmm, interesting. I know there were problems. Do you have sketchy physics installed? I know Chris implemented some things in SketchyPhysics that clash with the arrow keys. I'm not sure if ever fixed it. Perhaps try removing sketchyphysics if you have it.
                              If not, there was also a Mac issue, but I fixed that early on I think. But perhaps the wrong version is posted. I'll try to look into today for you.
                              • EdsonE
                                Edson
                                no sketchyphysics installed. the odd thing is that all your other scripts work for me.
                                • Chris FullmerC
                                  I have a feeling that I never got around to updating this script again after I found out that Macs and PC arrow keys are registered differently. I'll need to look at it again and figure out how to change it. I thought I had already, but it must be another script. Perhaps I remembering that I did it on shapebender, but never got around to fixing this one correctly.
                                  Sorry Edson, I'll try to get it working.
                                  Also, I don't think that I had planned on exploding the face once it gets put on the end of the line. If I explode it in the script, then if there is geometry in the way, it could clash. So I leave it up to the user to explode on their own, once they have verified that the shape does not intersect with other geometry.
                                  And I checked the version number. It is the right script, I just forgot to update that line in the code...sorry!
                                  And as for th3e red axis, there is a good chance that the up arrow keys are messing things up before the script aligns the face. I am really anxious to start coding again, I just need to get in and do it. So give me a few days and I'll see if I can bust out a new version of this.
                                  • EdsonE
                                    Edson
                                    take your time, chris. no hurry. we have a lot to thank you for already.
                                      markozeta
                                      7.1 bug perhaps? Entering in a fractional value for face size for the circular tool (e.g. 6 3/4") in the VCB results in the circle only coming out to 6" radius.
                                      And I use this thing all the time... help me out!
                                      BSME - Cal Poly Pomona
                                      Sketchup Pipe Maniac
                                      • Chris FullmerC
                                        Is this new to 7.1? Or was it like this before? It might just be me not coding it correctly. Try using a decmial instead of fraction for now. I think that should work. I'll look into when I get a a chance.
                                        And if it is a 7.1 thing, that is very interesting. I know that CadFather found some issue with units. And units and decimals and fractions are all connected.
                                        • K
                                          kwistenbiebel
                                          Hi there,
                                          Just wanted to drop in to say thank you to Chris.
                                          This is a wonderful tool. 👍
                                          I use it to position mesh lights perpendicular to the camera line (for rendering).
                                          The video in the first post is great. I especially like the sound of your wife doing the dishes while you recorded it. 😄
                                            mervin
                                            I found a bug. Nothing happened when I use "perpendicular circle" tool to place a circle whose radius is smaller enough, for example 10mm. Because of nothing happened, I did it many times, then it crash. Is there any way to fix this??
                                            • 11
                                            • 7 / 11
