    Voronoi, convex hull, geometry modification toolset
    27 Posts 12 Posters 16.1k Views 12 Watching
    • majidM
      majid
      dear a4chitect , thanks for your ruby ,but i had the same problem (voronoi doesnt work for me too ) maybe its because of operating system or something ( 32 or 64bit) dual prosseccoror... I dont know what! yours majid
        a4chitect
        please try this:
        windows - open command prompt and navigate to your sketchup\plugins\qhull
        (windows vista: it is easier to open qhull folder in windows explorer, press and hold shift and right-click anywhere inside empty space in qhull, choose 'Open Command Window Here')
        paste the following code 'qhull.exe TI points.txt v Qbb Qj o Fv' (without quotes) and press enter
        (paste works by clicking in the top left corner on the small black icon, choose edit>paste)
        let me know your results
        thanks
        • majidM
          majid
          dear a4chitetct , i did and here is the result ( i paste all the result in a text file and zipped)
          New Text Document (2).zip
            a4chitect
            from the file you have attached, it is clear that the voronoi computation is all right, I have copied the following part
            3
            19 12 1
            -10.101 -10.101 -10.101
            69.50972188371688 213.9843863157402 423.5501981233883
            5 8 10 0 4 3
            6 9 11 0 13 15 18
            and pasted into an empty sketchup\plugins\qhull\qvoronoi.txt
            then imported using a modified voronoi.rb (attached) which doesn't run the computation it only builds geometry from the qvoronoi.txt
            I am attaching the result as a .skp file
            the result in sketchup
            modified voronoi (replace your current but keep the original since this is for debugging)
            • N
              nerz
              hello a4chitect
              excuse me for havn't said a word these days (a virus strike in my school..)
              i have tried and tried different ways but nothing gets better. the file voronoi.txt (and convex hull too) is not created when i run voronoi (or convex hull)
              well i don't know how to do to attach a file... sorry..
              i'll keep on trying on an other computer..
              thanks for your work !!
              • CadFatherC
                CadFather
                Hi A4chitect,
                is there any way to have the export points script output in meters?
                (great set of rubys by the way)
                  minguinhirigue
                  Can't get this work well. Seems to be some problem to read my points.txt file !?
                  Command input :
                  ...Sketchup 6\Plugins\Qhull\qhull.exe" TI points.txt v Qbb Qj o Fv
                  Command output :
                  qhull error: could not open file "points.txt".
                  While executing: | qhull TI points.txt v Qbb Qj o Fv
                  Options selected for Qhull 2003.1 2003/12/30:
                  Could anybody help and or develop some direct and realtime approximate voronoi calculation in sketchup ? Like soap-skin-bubble plugin ?
                  File from the debug.skp file given by a4chitect... Do not work with my qhull.exe ?
                  • Chris FullmerC
                    There is another voronoi ruby script out there. And it seems to be much more reliable. I've never used either though.
                    Have you tried the onther one?
                    • Chris FullmerC
                      I even found the link to it:
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=19040&st=0&sk=t&sd=a
                        That links to qhull - the one that has the problems...
                        Looking at the points.txt file itself I see that each line has three space-separated numbers - I take these to be x y z values.
                        However, the first only has a pair !
                        3 13
                        try adding another value to that line ? say
                        3 13 0
                        The sets of other numbers are space separated
                        26.106198369 -27.800497953 0.0
                        Perhaps if they were comma separated it'd work ? Do a find+replace for " " to "," and see if that helps ???
                        Otherwise I'm stumped...
                        • F
                          ferenc0521
                          This is not for Mac OSX is it?
                          • 2 / 2
